Discuss
Frigidaire Affinity will not fully spin
 in
Washer Repair
My washer started leaving clothes very wet. At first I thought drainage system was clogged - but I checked that
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire Affinity will not fully spin
  #1 (permalink)
Old 06-02-2017, 08:32 AM
Junior Member
MIrland is on a distinguished road
Default Frigidaire Affinity will not fully spin
Model Number: FAFS4474LR0   Brand: Frigidaire   Age: 1 - 5 years
At first I thought drainage system was clogged - but I checked that and it is totally clear, and it is completely clearing all water.
In diagnostic mode all functions seem to work correctly except high spin. The machine will only spin a few times slowly then stop.
The door lock seems to be working appropriately - both in diagnostic mode and regular use- I can hear it lock and I can never open to door at an inappropriate time.
The only error code I have gotten is E59
The motor and the washer drum both spin freely. The motor does not hum when not in motion. The belt is in perfect shape.
If I try to run a cycle the machine fills with some water, then agitates a little (slowly), then sits for a long time with a light buzzing noise (I can't tell what's buzzing - it's not the motor, it's something towards the front of the washer but I can't remove the front panel and run the washer at the same time). The later it will fill with more water and lightly agitate. It seems to complete the cycle but never fully spins (it only once stopped cycle early with error code E59 displayed).
I'm torn between replacing the door lock anyway - as I see this has helped others (but all those other stated that high spin worked fine in diagnostic mode which mine does not) vs replacing the control board or the motor control.
I would really appreciate any assistance!
Related Models
Frigidaire FAFS4474LR0 WASHER
Frigidaire FAFS4474LW0 WASHER
Frigidaire FAFW3511KB0 WASHER
Frigidaire FAFW3511KR0 WASHER
Frigidaire FAFW3511KW0 WASHER
Frigidaire FAFW3511KW1 WASHER
Frigidaire FAFW3514KA0 WASHER
Frigidaire FAFW3514KA1 WASHER
Frigidaire FAFW3514KN0 WASHER
Frigidaire FAFW3514KN1 WASHER
Frigidaire FAFW3517KA1 WASHER
Frigidaire FAFW3517KB0 WASHER
Frigidaire FAFW3517KB1 WASHER
Frigidaire FAFW3517KN0 WASHER
Frigidaire FAFW3517KN1 WASHER
Frigidaire FAFW3517KR0 WASHER
Frigidaire FAFW3517KR1 WASHER
Frigidaire FAFW3517KT1 WASHER
Frigidaire FAFW3517KW0 WASHER
Frigidaire FAFW3517KW1 WASHER
Frigidaire FAFW3574KA0 FRONT LOAD WASHER
Frigidaire FAFW3574KB0 FRONT LOAD WASHER
Frigidaire FAFW3574KN0 FRONT LOAD WASHER
Frigidaire FAFW3574KR0 WASHER
Frigidaire FAFW3574KW0 FRONT LOAD WASHER
Frigidaire FAFW3577KA0 WASHER
Frigidaire FAFW3577KA1 WASHER
Frigidaire FAFW3577KB0 WASHER
Frigidaire FAFW3577KB1 WASHER
Frigidaire FAFW3577KN0 WASHER
Frigidaire FAFW3577KN1 WASHER
Frigidaire FAFW3577KR0 WASHER
Frigidaire FAFW3577KR1 WASHER
Frigidaire FAFW3577KW0 WASHER
Frigidaire FAFW3577KW1 WASHER
Frigidaire FAFW3801LB0 WASHER
Frigidaire FAFW3801LW0 WASHER
Frigidaire FAFW4011LB0 WASHER
Frigidaire FAFW4011LW0 WASHER
Frigidaire FAFW4221LB0 WASHER
Frigidaire FAFW4221LW0 WASHER
Frigidaire FAH085N1T Frigidaire/air Conditioner
Frigidaire FAH085N1T2 Frigidaire/air Conditioner
Frigidaire FAH085P1T1 Frigidaire/air Conditioner
Frigidaire FAH086J1T1 Frg/room Air Conditioner
Frigidaire FAH086J1T2 Frg/room Air Conditioner
Frigidaire FAH086M1T1 Frigidaire/air Conditioner
Frigidaire FAH086N1T1 Frigidaire/air Conditioner
Frigidaire FAH086R1T1 Frigidaire/air Conditioner
Frigidaire FAH086S1TA ROOM AIR CONDITIONER
Frigidaire FAH086S1TA11 ROOM AIR CONDITIONER
Frigidaire FAH086S1TA12 ROOM AIR CONDITIONER
Frigidaire FAH086S1TA13 ROOM AIR CONDITIONER
Frigidaire FAH086S1TB ROOM AIR CONDITIONER
Frigidaire FAH086T1T0 ROOM AIR CONDITIONER
Frigidaire FAH086T1T10 ROOM AIR CONDITIONER
Frigidaire FAH08EJ1T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH08EM1T1 Frigidaire/air Conditioner
Frigidaire FAH08EN1T Frigidaire/air Conditioner
Frigidaire FAH08EN1T2 Frigidaire/air Conditioner
Frigidaire FAH08EN1T3 Frigidaire/air Conditioner
Frigidaire FAH08EP1T1 Frigidaire/air Conditioner
Frigidaire FAH08ER1T1 Frigidaire/air Conditioner
Frigidaire FAH08ES1TA ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA11 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA12 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA13 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TB ROOM AIR CONDITIONER
Frigidaire FAH08ET1T0 ROOM AIR CONDITIONER
Frigidaire FAH08ET1T10 ROOM AIR CONDITIONER
Frigidaire FAH096J2T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH096J2T2 Frg(v0) / Room Air Conditioner
Frigidaire FAH096J2T3 Frigidaire/air Conditioner
Frigidaire FAH096M2T1 Frigidaire/air Conditioner
Frigidaire FAH105N1T Frigidaire/air Conditioner
Frigidaire FAH105N1T2 Frigidaire/air Conditioner
Frigidaire FAH105N2T Frigidaire/air Conditioner
Frigidaire FAH105N2T2 Frigidaire/air Conditioner
Frigidaire FAH105P1T1 Frigidaire/air Conditioner
Frigidaire FAH105P2T1 Frigidaire/air Conditioner
Frigidaire FAH106J1T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH106J1T2 Frigidaire/air Conditioner
Frigidaire FAH106J2T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH106J2T2 Frigidaire/air Conditioner
Frigidaire FAH106M1T1 Frigidaire/air Conditioner
Frigidaire FAH106M2T1 Frigidaire/air Conditioner
Frigidaire FAH106N1T1 Frigidaire/air Conditioner
Frigidaire FAH106N2T1 Frigidaire/air Conditioner
Frigidaire FAH106R1T1 Frigidaire/air Conditioner
Frigidaire FAH106R2T1 Frigidaire/air Conditioner
Frigidaire FAH106S1TA ROOM AIR CONDITIONER
Frigidaire FAH106S1TA11 ROOM AIR CONDITIONER
Frigidaire FAH106S1TA12 ROOM AIR CONDITIONER
Frigidaire FAH106S1TA13 ROOM AIR CONDITIONER
Frigidaire FAH106S1TB ROOM AIR CONDITIONER
Frigidaire FAH106S2TA ROOM AIR CONDITIONER
Frigidaire FAH106S2TA11 ROOM AIR CONDITIONER
Frigidaire FAH106S2TA12 ROOM AIR CONDITIONER
Frigidaire FAH106S2TA13 ROOM AIR CONDITIONER
Frigidaire FAH106S2TB ROOM AIR CONDITIONER
Frigidaire FAH106T1T0 ROOM AIR CONDITIONER
Frigidaire FAH106T1T10 ROOM AIR CONDITIONER
Frigidaire FAH106T2T0 ROOM AIR CONDITIONER
Frigidaire FAH106T2T10 ROOM AIR CONDITIONER
Frigidaire FAH10EJ2T2 Frigidaire/air Conditioner
Frigidaire FAH10EM2T1 Frigidaire/air Conditioner
Frigidaire FAH10EN2T Frigidaire/air Conditioner
Frigidaire FAH10EN2T2 Frigidaire/air Conditioner
Frigidaire FAH10EN2T3 Frigidaire/air Conditioner
Frigidaire FAH10EP2T1 Frigidaire/air Conditioner
Frigidaire FAH10ER2T1 Frigidaire/air Conditioner
Frigidaire FAH10ES2TA ROOM AIR CONDITIONER
Frigidaire FAH10ES2TA11 ROOM AIR CONDITIONER
Frigidaire FAH10ES2TA12 ROOM AIR CONDITIONER
Frigidaire FAH10ES2TA13 ROOM AIR CONDITIONER
Frigidaire FAH10ES2TB ROOM AIR CONDITIONER
Frigidaire FAH10ET2T0 ROOM AIR CONDITIONER
Frigidaire FAH10ET2T10 ROOM AIR CONDITIONER
Frigidaire FAH124N2T Frigidaire/air Conditioner
Frigidaire FAH124S1TA ROOM AIR CONDITIONER
  #2 (permalink)
Old 06-02-2017, 09:36 AM
Senior Member
brobriffin is on a distinguished road
Default
1st try resetting the machine by disconnecting the power wait for at least one minute then reconnect the power and try a wash cycle.
E59 means that the control board has not received a tachometer signal for at least 3 seconds.
In essence the machine doesn't know if the basket is spinning properly.
The reset may work. If not it may be a bad motor or sensor in the motor, bad motor control board or the main control board.
  #3 (permalink)
Old 06-02-2017, 10:34 AM
Junior Member
Default Frigidaire reset
Thanks for the reply!
It has definitely been unplugged for that long as I had it unplugged the whole time I was cleaning out the drainage system/filter.
No improvement on restart. The only thing I didn't do is clear the error from the system - but I didn't think the residual error being saved on there would prevent further normal function. I will try clearing it just in case.
If not improvement, any suggestion on how to tell which part is the issue?
I haven't found many instructions and how to test each part separately!
THanks!
  #4 (permalink)
Old 06-02-2017, 12:01 PM
Senior Member
Default
Look inside the cabinet of your machine. On the inside of the walls or under the lid you should find a plastic ziplock looking bag attached. In it you will find the tech manual. It should lead you in the right direction to test those components.
  #5 (permalink)
Old 06-06-2017, 11:05 PM
Junior Member
Default Replaced motor control board and door lock sensor...No improvement
I performed the full diagnostic and tests from the service manual inside the washer.
The motor seemed to test fine, so it recommended replacing the motor control board (there is no specific testing listed to check the control board, seems to be a matter of exclusion). I had read that the door lock was a common issue, so I tested that and it tested 1100 ohms and I read it should be 1500...so I ordered both the door lock and the motor control board. I installed each, and for each initially there was improvement but eventually errors started coming up again.
Initially it was E59 again, then E52 and E58. Then I got E9F. I thought maybe a wire was loose so I carefully checked them from motor control to control board. I found nothing loose, but it tested better after so I tried to run a load. It ran halfway through, then I got E59 again and it wouldn't finish.
Very frustrated.
The motor tested ok, and turns pretty freely so I don't think it's the problem...but most of the codes point to that.
I'm also considering the control board as it was throwing so many codes and a few times had an issue where the door stayed locked too long and I had to unplug it (before and after new door lock installed).
Appreciate any thoughts on all this!
  #6 (permalink)
Old 06-07-2017, 07:07 AM
Senior Member
Default
Communication errors occur often where the wire connections tend to oxidize and or corrode being used in a moist environment.
I recommend disconnecting and cleaning all connections to and from the CCU and MCU as well as the other components.
Clean both the connector ends as well as the terminal points on each board. I use a wire / connector cleaner.
  #7 (permalink)
Old 10-06-2017, 02:21 PM
Junior Member
Mattina51 is on a distinguished road
Default E21
Hi, I've cleaned out the draining pump, but it still gives me this error. It washes the clothes, and drains most of the water out, but doesn't fully spin the final spin.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Affinity Washer not fully draining kimps84 Washer Repair 1 04-26-2015 05:02 PM
Spin cycle drains, but doesn't spin (Frigidaire Affinity) tsteinruck Washer Repair 6 03-27-2014 03:39 PM
Frigidaire Affinity washer will not spin at full speed distressed2 Dryer Repair 0 02-09-2014 02:27 PM
Frigidaire Affinity Won't Spin Out or Drain not.a.fan Washer Repair 1 08-22-2013 08:57 PM
Frigidaire Affinity Won't Spin JohnnyG 9 Washer Repair 10 07-06-2013 06:00 PM
