Discuss
New knob doesn't fit
 in
Washer Repair
The timer knob for my washing machine has a tiny crack in the connector opening and now pulls off when
Appliance Repair Forum > Appliance Repair Help > Washer Repair » New knob doesn't fit
  #1 (permalink)
Old 11-03-2009, 02:33 PM
kathleena505 kathleena505 is offline
Junior Member
kathleena505 is on a distinguished road
Cool New knob doesn't fit
Model Number: AWE550VAL0   Brand: Kitchen Aid   Age: More than 10 years
The timer knob for my washing machine has a tiny crack in the connector opening and now pulls off when I try to turn on the machine. The part you sent screws on to the shaft - but the shaft on my machine has lengthwise grooves down the shaft, so this knob does not fit.
Is there a way I can repair this knob without replacing the whole timer mechanism (which has been redesigned according to your information)? Any other suggestions?
Thanks!
Related Models
Amana AWE852 Washer - Top Loading
Amana AWE931 Washer - Top Loading
Amana AWE951 Washer - Top Loading
Whirlpool AWH08020
Whirlpool AWH10520
Whirlpool AWH10640
Whirlpool AWH14140
Whirlpool AWH18030
Whirlpool AWH18031
Whirlpool AWH22030
Whirlpool AWH27030
General Electric AWK18D1V1 Room air conditioner
Whirlpool AWL17930
Whirlpool AWL17933
Whirlpool AWL18040
Whirlpool AWL18041
Whirlpool AWL18140
Whirlpool AWL18240
Whirlpool AWL21030
Whirlpool AWL21031
Frigidaire AWL210S3D Kel(v1) / 28 " Washer
Frigidaire AWL210S3F Kel(v2) / 28 " Washer
Frigidaire AWL210S3T Kel(v3) / 28 " Washer
Frigidaire AWL210S3V Kel(v4) / 28 " Washer
Frigidaire AWL210S3W Kel(v5) / 28 " Washer
Whirlpool AWL22030
Whirlpool AWL22031
Whirlpool AWL22033
Whirlpool AWL22130
Whirlpool AWL23030
Whirlpool AWL23031
Whirlpool AWL23032
Whirlpool AWL23040
Frigidaire AWL230S3D Kel(v6) / 28 " Washer
Frigidaire AWL230S3F Kel(v7) / 28 " Washer
Frigidaire AWL230S3T Kel(v8) / 28 " Washer
Frigidaire AWL230S3V Kel(v9) / 28 " Washer
Frigidaire AWL230S3W Kel(v10) / 28 " Washer
Whirlpool AWL23230
Whirlpool AWL23340
Frigidaire AWL250S3D Kel(v11) / 28 " Washer
Frigidaire AWL250S3F Kel(v12) / 28 " Washer
Frigidaire AWL250S3T Kel(v13) / 28 " Washer
Frigidaire AWL250S3V Kel(v14) / 28 " Washer
Frigidaire AWL250S3W Kel(v15) / 28 " Washer
Whirlpool AWL28030
Whirlpool AWL28031
Whirlpool AWL32030
Amana AWL50AW  Washer - Top Loading
Whirlpool AWM06021
Whirlpool AWM06022
Whirlpool AWM06023
Whirlpool AWM06123
Whirlpool AWM06223
Whirlpool AWM07920
Whirlpool AWM08020
Whirlpool AWM08021
Whirlpool AWM08120
Whirlpool AWM08220
Whirlpool AWM08323
Whirlpool AWM09521
Whirlpool AWM10020
Amana AWM190W Washer - Top Loading
Amana AWM190W2 Washer - Top Loading
Amana AWM230 Washer - Top Loading
Amana AWM250 Washer - Top Loading
Amana AWM270W Washer - Top Loading
Amana AWM270W2 Washer - Top Loading
Amana AWM290L Washer - Top Loading
Amana AWM290L2 Washer - Top Loading
Amana AWM290W Washer - Top Loading
Amana AWM290W2 Washer - Top Loading
Amana AWM331 Washer - Top Loading
Amana AWM332 Washer - Top Loading
Amana AWM351 Washer - Top Loading
Amana AWM352 Washer - Top Loading
Amana AWM371W2 Washer - Top Loading
Amana AWM372W Washer - Top Loading
Amana AWM372W2 Washer - Top Loading
Amana AWM373W Washer - Top Loading
Amana AWM373W2 Washer - Top Loading
Amana AWM392L Washer - Top Loading
Amana AWM392L2 Washer - Top Loading
Amana AWM392W Washer - Top Loading
Amana AWM392W2 Washer - Top Loading
Amana AWM393L Washer - Top Loading
Amana AWM393L2 Washer - Top Loading
Amana AWM393W Washer - Top Loading
Amana AWM393W2 Washer - Top Loading
Amana AWM432 Washer - Top Loading
Amana AWM452 Washer - Top Loading
Amana AWM472W Washer - Top Loading
Amana AWM472W2 Washer - Top Loading
Amana AWM473W Washer - Top Loading
Amana AWM473W2 Washer - Top Loading
Amana AWM492 Washer - Top Loading
Amana AWM493 Washer - Top Loading
Amana AWM531 Washer - Top Loading
Amana AWM551 Washer - Top Loading
Amana AWM572 Washer - Top Loading
Amana AWM573W Washer - Top Loading
Amana AWM573W2 Washer - Top Loading
Amana AWM592 Washer - Top Loading
Amana AWM593L Washer - Top Loading
Amana AWM593L2 Washer - Top Loading
  #2 (permalink)
Old 11-03-2009, 02:53 PM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
I could not find info on this unit so am not sure if the below is applicable.
Get some fiber tape or any type of tape that will not stretch lengthwise.
Wrap it around the knob shaft/tube a couple times as tight as you can to keep the crack closed.
Then get a small zip tie and tighten that around the shaft at the cracked area.
Also am not sure this will work as you may not have enough clearance.
Another possibility is take the knob to a decent sized parts supplier, they may be able to match it up with a knob from another unit. All will depend on how good/knowledgeable/nice the counter person you is.
__________________
  #3 (permalink)
Old 11-03-2009, 03:29 PM
Junior Member
Default Further question about washer knob
Thanks for your quick reply!
It is the plastic knob that has a tiny crack - not the shaft that extends from the control panel. I looked at the diagram for the timer and see that there is a screw that can be purchased separately. Is this the screw that the knob would fasten onto? The screw is item #22 and the timer is #4 of the available parts listed for model KAWE550V.
Thanks!!!!!
  #4 (permalink)
Old 11-03-2009, 08:32 PM
Senior Expert
APP Volunteer
Default
Yes, I understood you were referring to the knob and not the timer.
I do not know if what I was referring to even has a name but it is the tube which is part of the knob and fits over the timer shaft.
I do not think so. If you click on the picture of the timer, a new page will come up with more views of it. Click on these pictures and it will expand. The timer shaft with the screw end is part of the timer itself.
Note that 22 comes up as the knob, so I assume you meant 25 which looks like it just holds the timer to the mounting plate.
__________________
  #5 (permalink)
Old 11-04-2009, 09:10 AM
Junior Member
Default
Got it! Many thanks for your expert help!!
  #6 (permalink)
Old 11-04-2009, 09:57 AM
Senior Expert
APP Volunteer
Default
You are welcome.
I do not know about the expert part, an real expert would have had a solution for you.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Knob - Time ehamilton Washer Repair 1 10-02-2009 08:03 AM
timer knob danmacy Washer Repair 2 05-14-2009 11:25 AM
Exhaust fan knob Ron Crane Oven Repair (including Ranges and Cooktops) 3 05-13-2009 08:48 AM
broken knob explorer309 Washer Repair 1 04-20-2008 09:25 PM
knob won't come off problemchild Washer Repair 4 03-19-2008 06:13 AM
