JORAMIREZ@MTAHQ
#1 Posted : Sunday, May 21, 2017 3:44:13 PM(UTC)
JORAMIREZ@MTAHQ
Hi, My Washer Will Not Go Into The High Speed Spin At The End Of Any Cycle. It Will Fill Up, Wash And Drain Fine. When It Completes The Cycle It Appears To Be Agitating Back And Forth.
When It Hits Final Spin And Completes The Cycle And You Can Open The Door, The Clothing Is Completely Saturated And Their Is A Small Amount Of Soap Residue On The Window.
I Have Checked And Cleaned The Drain Pump And Replaced The Door Locking Mechanism Including The Wax Motor As The Washer Wouldnt Originally Complete The Cycle And Would Get Stuck After The Initial Wash And Drain.
Now, The Dial Will Complete The Cycle But As I've Said Above It Appears To Be Still Agitating As The Timer Hits Final Spin.
Is This Possibly A Problem With The Control Panel Or Something Else?
Any Assistance Would Be Greatly Appreciated As We Just Can't Afford To Buy A New Washer Dryer Now After Just Having Bought Our First Home. Thank You!
