Discuss
Basket/spinner full of water, not drum
 in
Washer Repair
The basket/spinner of our washer is holding water. There NO water in the drum. I have completely removed the pump
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Basket/spinner full of water, not drum
  #1 (permalink)
Old 05-18-2017, 08:25 AM
Junior Member
Mikeistrying is on a distinguished road
Default Basket/spinner full of water, not drum
Brand: Whirlpool   Age: 1 - 5 years
The basket/spinner of our washer is holding water. There NO water in the drum. I have completely removed the pump and the water doesn't drain. Again, it's in the basket/spinner, I can hear and feel it sloshing around inside the walls of the basket.
How do I get the water to release??
Thanks for the help, greatly appreciated.
  #2 (permalink)
Old 05-18-2017, 09:44 AM
Senior Member
brobriffin is on a distinguished road
Default
Likely the water you hear sloshing around is in the balancing ring at the top of the basket. This is not anything you can or should drain. The system is designed that way. If the water does leak out of the balancing ring you would have to replace it or else the tub may shake out of balance during spin cycle.
Again this is normal you needn't worry.
  #3 (permalink)
Old 05-18-2017, 02:46 PM
Junior Member
Default
Thanks brobriffin!
So this water in the balancing ring, is that self-contained? We're actually gutting the machine for the motor and basket for our farm to turn it into a salad spinner/dryer. We're using a food-grade liner basket within the washing machine basket. So the water in the balancing ring doesn't need to release or cleaned or cycled, right? It's just a permanent, self-contained feature that I don't need to worry about molding or anything?
  #4 (permalink)
Old 05-18-2017, 02:58 PM
Senior Member
Default
Correct it comes from the factory sealed that way....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front Load Washer Clothes Basket (Drum) just Floats around Freely wyocwboy Dryer Repair 0 09-15-2012 10:57 AM
Spinner Block Stuck in Basket beekins Washer Repair 1 05-20-2011 02:52 AM
Drum/Basket fredwilli Washer Repair 1 03-17-2009 05:31 AM
