Register | FAQ's | New Posts | Today's Posts | Extras |
» Electrolux washer trickle fill and drain |
![]() Model Number: EWFLS70JSS0 Brand: Electrolux Age: 5 - 10 years
![]() I have a 7 year old electrolux washing machine. For several months, it would often display an error message indicating it was not able to get enough water into the machine. The first time or two, cleaning the screen seemed to help. But recently that stopped working as the solution. In addition, the machine would often display error code E21 and has difficulty draining. I've ordered a new pump, which should solve my draining issue. However, after replacing the water valves yesterday, I was hoping it would solve the fill issue and it did not. I'm still getting just a tiny trickle of water into the tub and the trickle is very sudsy, even when I'm using the rinse and drain cycle. I had a repairman suggest I need to replace the control board but my question is would I get ANY water at all into the tub if the control board was the problem? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Electrolux will not fill with water | TowDawg | Dishwasher Repair | 0 | 08-14-2015 08:31 AM |
Washer will fill and drain bot nothing else | Jarhead1216 | Washer Repair | 2 | 12-16-2013 07:30 PM |
Ge washer will fill and drain only | Nthqtr | Washer Repair | 0 | 07-08-2012 07:06 AM |
Washer fills with only a trickle of water | Ada Wilson | Washer Repair | 1 | 07-06-2010 01:18 PM |
Water coming into washer is at a trickle both hot and cold | hleira | Washer Repair | 0 | 05-14-2008 10:35 AM |
