Discuss
Whirlpool top loader not spinning on final rinse
 in
Washer Repair
My washer will work as normal until it"s time for the final rinse. It seems to drain fine but the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool top loader not spinning on final rinse
  #1 (permalink)
Old 05-10-2017, 09:22 PM
Junior Member
staton4 is on a distinguished road
Default Whirlpool top loader not spinning on final rinse
Model Number: LSR8233EQO   Brand: Whirlpool   Age: More than 10 years
It seems to drain fine but the clothes are still pretty wet. This happens on the Normal cycle for sure. So I have been using the Permanent Press cycle and all works fine. Is this a timer issue?
Related Models
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JQ1 WASHER
Whirlpool LSR8233JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JT1 WASHER
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 AUTOMATIC WASHER
Whirlpool LSR9434PQ1 AUTOMATIC WASHER
Whirlpool LSR9434PQ3 AUTOMATIC WASHER
Whirlpool LSR9434PQ4 AUTOMATIC WASHER
Whirlpool LSR9434PT0 AUTOMATIC WASHER
Whirlpool LSR9434PT1 AUTOMATIC WASHER
Whirlpool LSR9434PT3 AUTOMATIC WASHER
Whirlpool LSR9434PT4 AUTOMATIC WASHER
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
General Electric LSS25XSWASS REFRIGERATOR W SERIES
General Electric LSS25XSWCSS REFRIGERATOR W SERIES
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0 WASHER
Whirlpool LSS9244EZ0 WASHER
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
 LSU090HE Air Conditioner
 LSU092CE Air Conditioner
 LSU092HE Air Conditioner
 LSU120HE Air Conditioner
 LSU122CE Air Conditioner
 LSU122HE Air Conditioner
 LSU180HE Air Conditioner
 LSU182CE Air Conditioner
 LSU182HE Air Conditioner
  #2 (permalink)
Old 05-10-2017, 11:13 PM
Senior Member
PNWDrew is on a distinguished road
Default
Edit - removed multiple copies
  #3 (permalink)
Senior Member
Default
Edit - removing multiple copies of same post
  #4 (permalink)
Old 05-10-2017, 11:14 PM
Senior Member
Default
Edit: I don't know why this posted multiple times---sorry.
If it truly isn't spinning during only one cycle that is probably the timer.
Here's a simple test, it sounds worse when written than it will be in reality; you just will take 15 minutes of standing there.
The lid has a pin that pushes through a hole in the cabinet to depress the lid switch. That hole is on the right side of where the lid sits in the top. You can use a pencil or other slim object to push that switch (it'll click when the switch closes) and trick it into allowing you to run it with the lid open. Let it run normally through a cycle that seems to not spin out. When it reaches rinse and has filled and begun agitating, open the lid and manually push that lid switch so it'll move on to drain and spin as if the lid is closed. It'll take a few minutes of holding it but you want to let it progress as the cycle normally does.
After a few minutes of agitation, the timer should end the agitation part and reverse the motor to run neutral drain prior to spinning in order to empty the machine. Ideally if you continue to hold that switch down a minute or 2 later the timer should briefly kill the motor. Upon restarting it should start spinning. If you release the switch briefly during neutral drain it'll also start spinning when you depress it again.
Caveat - It may not do neutral drain properly and begin spinning early, that isn't a major problem in itself as long as it isn't sloshing water over the top. It's extra wear on the clutch but not worth addressing on it's own as it means a new gearcase.
If it doesn't progress into spin at all and just ends after 6-8 minutes of neutral drain (when it should have been spinning) you have a bad timer that isn't opening the motor circuit to flip the gearcase into spin. If it spins lazily you probably have a bad clutch. The timer is easy to change but the clutch is cheaper.
If permanent press works and you do not want to spend $ on it just use that cycle. It spins slower I think but otherwise you wont notice much difference.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Washer not spinning on wash/rinse sniper82 Washer Repair 0 11-19-2015 01:55 PM
Frigidaire front load not spinning on final rinse 6kimas Washer Repair 0 10-07-2014 02:54 PM
whirlpool Top loader not spinning or agitating jimmriley Washer Repair 16 06-26-2013 05:09 PM
Whirlpool Washer won't drain final rinse ntom908 Washer Repair 2 05-31-2011 06:25 AM
Whirlpool no final spin-spins form wash to rinse fairgrove Washer Repair 3 01-23-2009 07:17 PM
