Discuss
Clothes are too wet after final spin
 in
Washer Repair
Clothes are too wet after final spin. Belt still looks new. Machine is less than five years old. No standing
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Clothes are too wet after final spin
  #1 (permalink)
Old 05-10-2017, 10:51 AM
Junior Member
weidnerr is on a distinguished road
Default Clothes are too wet after final spin
Model Number: Mav3758aww   Brand: Maytag   Age: 1 - 5 years
Clothes are too wet after final spin. Belt still looks new. Machine is less than five years old. No standing water in tub after final spin.
Related Models
Maytag MAV3758AWW WASHER-TOP LOADING
Maytag MAV3855AGW WASHER-TOP LOADING
Maytag MAV3855AKW WASHER-TOP LOADING
Maytag MAV3855AWW WASHER-TOP LOADING
Maytag MAV385SAWW WASHER-TOP LOADING
Maytag MAV3905AWW WASHER-TOP LOADING
Maytag MAV3955EWW WASHER-TOP LOADING
Maytag MAV4057AWQ WASHER, ATLANTIS
Maytag MAV4057AWW WASHER, ATLANTIS
Maytag MAV408DAWK WASHER-TOP LOADING
Maytag MAV408DAWW WASHER-TOP LOADING
Maytag MAV4500AWW WASHER, ATLANTIS
Maytag MAV4755AWW WASHER-TOP LOADING
Maytag MAV4757AWW WASHER-TOP LOADING
Maytag MAV4758AWW WASHER-TOP LOADING
Maytag MAV5000AWQ WASHER, ATLANTIS
Maytag MAV5000AWW WASHER, ATLANTIS
Maytag MAV5057AWQ WASHER, ATLANTIS
Maytag MAV5057AWW WASHER, ATLANTIS
Maytag MAV551EEWW WASHER-TOP LOADING
Maytag MAV5758EWW WASHER-TOP LOADING
Maytag MAV5920AGW WASHER-TOP LOADING
Maytag MAV5920EWK WASHER-TOP LOADING
Maytag MAV5920EWW WASHER-TOP LOADING
Maytag MAV5960AWW WASHER, ATLANTIS
Maytag MAV6000AWQ WASHER, ATLANTIS
Maytag MAV6000AWW WASHER, ATLANTIS
Maytag MAV6057AWQ WASHER, ATLANTIS
Maytag MAV6057AWW WASHER, ATLANTIS
Maytag MAV6200AWQ WASHER, ATLANTIS
Maytag MAV6200AWW WASHER, ATLANTIS
Maytag MAV6250AWQ WASHER, ATLANTIS
Maytag MAV6250AWW WASHER, ATLANTIS
Maytag MAV6257AWQ WASHER, ATLANTIS
Maytag MAV6257AWW WASHER, ATLANTIS
Maytag MAV6260AWW WASHER, ATLANTIS
Admiral MAV6300AGW WASHER-TOP LOADING
Maytag MAV6300AWQ WASHER, ATLANTIS
Maytag MAV6300AWW WASHER, ATLANTIS
Admiral MAV6300BGW WASHER-TOP LOADING
Admiral MAV6300CGW WASHER-TOP LOADING
Maytag MAV6357AWW WASHER, ATLANTIS
Maytag MAV6358AWW WASHER, ATLANTIS
Maytag MAV6451AGW WASHER, ATLANTIS
Maytag MAV6451AWQ WASHER, ATLANTIS
Maytag MAV6451AWW WASHER, ATLANTIS
Maytag MAV6457AWW WASHER, ATLANTIS
Maytag MAV6458AWW WASHER, ATLANTIS
Maytag MAV6548AWQ WASHER, ATLANTIS
Maytag MAV6548AWW WASHER, ATLANTIS
Maytag MAV6601AWQ WASHER, ATLANTIS
Maytag MAV6601AWW WASHER, ATLANTIS
Maytag MAV6650AWW WASHER, ATLANTIS
Maytag MAV7000AWQ WASHER, ATLANTIS
Maytag MAV7000AWW WASHER, ATLANTIS
Maytag MAV7057AWQ WASHER, ATLANTIS
Maytag MAV7057AWW WASHER, ATLANTIS
Maytag MAV7200AWQ WASHER, ATLANTIS
Maytag MAV7200AWW WASHER, ATLANTIS
Maytag MAV7257AWQ WASHER, ATLANTIS
Maytag MAV7257AWW WASHER, ATLANTIS
Maytag MAV7258AWQ WASHER, ATLANTIS
Maytag MAV7258AWW WASHER, ATLANTIS
Maytag MAV7260AWW WASHER, ATLANTIS
Maytag MAV7260BWW WASHER, ATLANTIS
Maytag MAV7357AWQ WASHER, ATLANTIS
Maytag MAV7357AWW WASHER, ATLANTIS
Maytag MAV7358AWQ WASHER, ATLANTIS
Maytag MAV7358AWW WASHER, ATLANTIS
Maytag MAV7450AWQ WASHER, ATLANTIS
Maytag MAV7450AWW WASHER, ATLANTIS
Maytag MAV7501EWW WASHER, ATLANTIS
Maytag MAV7504EWW WASHER, ATLANTIS
Maytag MAV7550AWQ WASHER, ATLANTIS
Maytag MAV7550AWW WASHER, ATLANTIS
Maytag MAV7551AWQ WASHER, ATLANTIS
Maytag MAV7551AWW WASHER, ATLANTIS
Maytag MAV7557EWQ WASHER, ATLANTIS
Maytag MAV7557EWW WASHER, ATLANTIS
Maytag MAV7580EWQ WASHER, ATLANTIS
Maytag MAV7580EWW WASHER, ATLANTIS
Admiral MAV7600ACQ WASHER-TOP LOADING
Admiral MAV7600AGW WASHER-TOP LOADING
Maytag MAV7600AWQ WASHER, ATLANTIS
Maytag MAV7600AWW WASHER, ATLANTIS
Admiral MAV7600BGW WASHER-TOP LOADING
Admiral MAV7600CGW WASHER-TOP LOADING
Maytag MAV7650AWQ WASHER, ATLANTIS
Maytag MAV7650AWW WASHER, ATLANTIS
Maytag MAV7657EWQ WASHER, ATLANTIS
Maytag MAV7657EWW WASHER, ATLANTIS
Maytag MAV7700AWQ WASHER, ATLANTIS
Maytag MAV7700AWW WASHER, ATLANTIS
Admiral MAV7750AGW WASHER-TOP LOADING
Admiral MAV7750BGW WASHER-TOP LOADING
Admiral MAV7750CGW WASHER-TOP LOADING
Maytag MAV7757AWQ WASHER, ATLANTIS
Maytag MAV7757AWW WASHER, ATLANTIS
Maytag MAV8000AWQ WASHER, ATLANTIS
Maytag MAV8000AWW WASHER, ATLANTIS
Maytag MAV8057AWQ WASHER, ATLANTIS
Maytag MAV8057AWW WASHER, ATLANTIS
Maytag MAV8260AWQ WASHER, ATLANTIS
Maytag MAV8260AWW WASHER, ATLANTIS
Maytag MAV8500AWQ WASHER, ATLANTIS
Maytag MAV8500AWW WASHER, ATLANTIS
Maytag MAV8551AWQ WASHER, ATLANTIS
Maytag MAV8551AWW WASHER, ATLANTIS
Maytag MAV8557AWQ WASHER, ATLANTIS
Maytag MAV8557AWW WASHER, ATLANTIS
Maytag MAV8600AWQ WASHER, ATLANTIS
Maytag MAV8600AWW WASHER, ATLANTIS
Maytag MAV8601AWQ WASHER, ATLANTIS
Maytag MAV8601AWW WASHER, ATLANTIS
Maytag MAV8757AWQ WASHER, ATLANTIS
Maytag MAV8757AWW WASHER, ATLANTIS
Maytag MAV9501EWQ WASHER, ATLANTIS
Maytag MAV9501EWW WASHER, ATLANTIS
Maytag MAV9504EWQ WASHER, ATLANTIS
Maytag MAV9504EWW WASHER, ATLANTIS
  #2 (permalink)
Old 05-11-2017, 12:56 AM
Senior Member
PNWDrew is on a distinguished road
Default
FYI: That machine is certainly older than 5 years if that is correct model #. Hasn't been made since 2005-6. Whirlpool bought Maytag and discontinued all Maytag designs. That is a Maytag design. I can look up actual manufacture date if you post the serial #.
If there are no abnormal noises, no heavy rattles and it seems to be pumping the water out normally here's the list.
Possible parts:
#1 is the thrust bearing not releasing brake. Common on these, it sometimes isn't an easy job but a determined DIYer can do it. Lean it back and turn the big pulley by hand. One direction should free spin, the other should cause the thrust bearing / cam to release the brake. This means the transmission can spin. You'll need front off to see the whole trans spin. If it doesn't try turning it faster, if still no trans motion you probably need this kit. You can pop the white plastic dust cap off the pulley and see an alignment arrow on the inner cam that should release the brake within the two lines on the pulley that indicate normal travel. It may not be easy to see them as it will be greasy.
Whirlpool 12002213 Thrust Bearing Kit - AppliancePartsPros.com
#2 is transmission itself. This would require a special tool, is pricey, and is not a DIY job. It is pretty complex and by now you may need to drill the basket bolts out. I've never known an owner to do it, though it is possible if you can find the brake rotor tool and are very determined.
Whirlpool 35-6615 Ht Trans S - AppliancePartsPros.com
#3 belt slipping - not real common, you stated it looked fine but I'd look if I came out no matter what cust said... no offense to you. What we look for and what you look for may not be the same thing at all. This usually comes with a nasty odor from the overheating belt. I'd look for damage from heat, greasiness, oil leakage from transmission, etc..
  #3 (permalink)
Old 05-11-2017, 10:44 AM
Junior Member
Default
Thanks for the info. I took the belt to an Appliance repair business and he said the belt looked brand new and must be something else. Im guessing number 1...Saturday I will be checking it out. Wife said it's not spinning as fast. Im thinking of filling it up with water and watching it do a cycle
  #4 (permalink)
Old 05-11-2017, 10:46 AM
Junior Member
Default
Does this model have a clutch?
  #5 (permalink)
Old 05-11-2017, 11:12 AM
Senior Member
Default
No clutch like the later Whirlpool design Maytag would have.
Instead when that big pulley is turned it pushes a cam that lifts the brake rotor off of the stator to allow the gearcase to spin. The whole gearcase spins.
If you pop that white plastic dust cover off you'll see at least part of that mechanism. The cam is the white plastic piece right above the washer and e-clip. The repair kit includes everything you would need except a fair amount of patience because getting the e-clip and washer back on can be a lot of fun.
It's hard to describe exactly but once that dust cover is off and you turn the pulley by hand it will make more sense. It's a fairly quick test.
There is another possibility that you can look for while you have that little cover off. Sometimes as those gearcases fail the drive shaft that the pulley drives will develop some free play so instead of lifting the brake, that cam pulls the shaft downward an eighth or quarter inch. The thrust bearing kit contains two different thickness washers that you can use either or both as needed. You must use one though.
The parts aren't that expensive so unless there is obvious shaft freeplay it might be worth doing. Like I said though getting it reassembled is not always an easy job.
  #6 (permalink)
Old 05-12-2017, 06:53 AM
Junior Member
Default
Thank you very much PNWDrew
  #7 (permalink)
Old 05-13-2017, 01:49 PM
Junior Member
Default Big pulley on the bottom spinning free in both directions
MAV3758aww
I turn the big transmission pulley on the bottom and the agitator is spinning freely in both direction with the belt off. Should there be resistance in one direction. At first glance I didn't see any marking like I have seen on the bearing kit replacement.
Regards,
Robert
  #8 (permalink)
Old 05-14-2017, 08:45 AM
Junior Member
Default
There is a round hole about the size of the snap ring straight through the dust cover. I wanted to add a pic but don't have a web link. Something has caused the shaft to drop I guess?
  #9 (permalink)
Old 05-14-2017, 09:03 AM
Junior Member
Default
Bearing and cam parts all still look good. Bearing is spinning free with no noise. Only one washer. Wondering why the shaft dropped and spun a hole in the dust cover? The hole is the diameter of the snap ring.
  #10 (permalink)
Old 05-14-2017, 09:08 AM
Junior Member
Default Hole in bearing kit dust cover
Pulled the cover off the large pulley. There is a round hole in it about the size of the snap ring. All the pieces look fine and the bearing is spinning freely with no noises. What could have caused the shaft to drop into the dust cover? Do you think the transmission is shot? When I spin the large pulley there is no resistance either way I spin the pulley. The agitator spins in the tub.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
clothes too wet after final spin lzob1c Washer Repair 1 02-20-2011 08:12 AM
Clothes still WET after final spin HandyHubby1963 Washer Repair 1 07-02-2010 10:19 AM
Clothes are wet after final spin Jsmmons Washer Repair 4 02-05-2010 02:40 PM
wet clothes at end of final spin seb19591986 Washer Repair 5 04-27-2009 03:40 PM
Wet clothes after final spin AbleJohn Washer Repair 0 03-19-2009 09:29 AM
