Discuss
Tub/Basket turns and sqeaks during agitation cycle
 in
Washer Repair
during the agitation cycle, the basket will move with the agitation and squeak every time it moves. From reading, I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Tub/Basket turns and sqeaks during agitation cycle
  #1 (permalink)
Old 05-06-2017, 12:05 PM
Junior Member
dsuroviec is on a distinguished road
Default Tub/Basket turns and sqeaks during agitation cycle
Model Number: matv236aww   Brand: Maytag   Age: Less than 1 year
during the agitation cycle, the basket will move with the agitation and squeak every time it moves. From reading, I believe that a brake needs replaced or repaired? I am looking for the part and part number for what needs replaced.
Related Models
Maytag MAV1655AWW WASHER-TOP LOADING
Maytag MAV1755AWW WASHER-TOP LOADING
Maytag MAV208DAWW WASHER-TOP LOADING
Admiral MAV2200AJW WASHER-TOP LOADING
Maytag MAV2755AJW WASHER-TOP LOADING
Maytag MAV2755AWW WASHER-TOP LOADING
Maytag MAV2757AWW WASHER-TOP LOADING
Maytag MAV275SAWW WASHER-TOP LOADING
Maytag MAV308DAWW WASHER-TOP LOADING
Admiral MAV3350AGW WASHER-TOP LOADING
Maytag MAV3757AWW WASHER-TOP LOADING
Maytag MAV3758AWW WASHER-TOP LOADING
Maytag MAV3855AGW WASHER-TOP LOADING
Maytag MAV3855AKW WASHER-TOP LOADING
Maytag MAV3855AWW WASHER-TOP LOADING
Maytag MAV385SAWW WASHER-TOP LOADING
Maytag MAV3905AWW WASHER-TOP LOADING
Maytag MAV3955EWW WASHER-TOP LOADING
Maytag MAV4057AWQ WASHER, ATLANTIS
Maytag MAV4057AWW WASHER, ATLANTIS
Maytag MAV408DAWK WASHER-TOP LOADING
Maytag MAV408DAWW WASHER-TOP LOADING
Maytag MAV4500AWW WASHER, ATLANTIS
Maytag MAV4755AWW WASHER-TOP LOADING
Maytag MAV4757AWW WASHER-TOP LOADING
Maytag MAV4758AWW WASHER-TOP LOADING
Maytag MAV5000AWQ WASHER, ATLANTIS
Maytag MAV5000AWW WASHER, ATLANTIS
Maytag MAV5057AWQ WASHER, ATLANTIS
Maytag MAV5057AWW WASHER, ATLANTIS
Maytag MAV551EEWW WASHER-TOP LOADING
Maytag MAV5758EWW WASHER-TOP LOADING
Maytag MAV5920AGW WASHER-TOP LOADING
Maytag MAV5920EWK WASHER-TOP LOADING
Maytag MAV5920EWW WASHER-TOP LOADING
Maytag MAV5960AWW WASHER, ATLANTIS
Maytag MAV6000AWQ WASHER, ATLANTIS
Maytag MAV6000AWW WASHER, ATLANTIS
Maytag MAV6057AWQ WASHER, ATLANTIS
Maytag MAV6057AWW WASHER, ATLANTIS
Maytag MAV6200AWQ WASHER, ATLANTIS
Maytag MAV6200AWW WASHER, ATLANTIS
Maytag MAV6250AWQ WASHER, ATLANTIS
Maytag MAV6250AWW WASHER, ATLANTIS
Maytag MAV6257AWQ WASHER, ATLANTIS
Maytag MAV6257AWW WASHER, ATLANTIS
Maytag MAV6260AWW WASHER, ATLANTIS
Admiral MAV6300AGW WASHER-TOP LOADING
Maytag MAV6300AWQ WASHER, ATLANTIS
Maytag MAV6300AWW WASHER, ATLANTIS
Admiral MAV6300BGW WASHER-TOP LOADING
Admiral MAV6300CGW WASHER-TOP LOADING
Maytag MAV6357AWW WASHER, ATLANTIS
Maytag MAV6358AWW WASHER, ATLANTIS
Maytag MAV6451AGW WASHER, ATLANTIS
Maytag MAV6451AWQ WASHER, ATLANTIS
Maytag MAV6451AWW WASHER, ATLANTIS
Maytag MAV6457AWW WASHER, ATLANTIS
Maytag MAV6458AWW WASHER, ATLANTIS
Maytag MAV6548AWQ WASHER, ATLANTIS
Maytag MAV6548AWW WASHER, ATLANTIS
Maytag MAV6601AWQ WASHER, ATLANTIS
Maytag MAV6601AWW WASHER, ATLANTIS
Maytag MAV6650AWW WASHER, ATLANTIS
Maytag MAV7000AWQ WASHER, ATLANTIS
Maytag MAV7000AWW WASHER, ATLANTIS
Maytag MAV7057AWQ WASHER, ATLANTIS
Maytag MAV7057AWW WASHER, ATLANTIS
Maytag MAV7200AWQ WASHER, ATLANTIS
Maytag MAV7200AWW WASHER, ATLANTIS
Maytag MAV7257AWQ WASHER, ATLANTIS
Maytag MAV7257AWW WASHER, ATLANTIS
Maytag MAV7258AWQ WASHER, ATLANTIS
Maytag MAV7258AWW WASHER, ATLANTIS
Maytag MAV7260AWW WASHER, ATLANTIS
Maytag MAV7260BWW WASHER, ATLANTIS
Maytag MAV7357AWQ WASHER, ATLANTIS
Maytag MAV7357AWW WASHER, ATLANTIS
Maytag MAV7358AWQ WASHER, ATLANTIS
Maytag MAV7358AWW WASHER, ATLANTIS
Maytag MAV7450AWQ WASHER, ATLANTIS
Maytag MAV7450AWW WASHER, ATLANTIS
Maytag MAV7501EWW WASHER, ATLANTIS
Maytag MAV7504EWW WASHER, ATLANTIS
Maytag MAV7550AWQ WASHER, ATLANTIS
Maytag MAV7550AWW WASHER, ATLANTIS
Maytag MAV7551AWQ WASHER, ATLANTIS
Maytag MAV7551AWW WASHER, ATLANTIS
Maytag MAV7557EWQ WASHER, ATLANTIS
Maytag MAV7557EWW WASHER, ATLANTIS
Maytag MAV7580EWQ WASHER, ATLANTIS
Maytag MAV7580EWW WASHER, ATLANTIS
Admiral MAV7600ACQ WASHER-TOP LOADING
Admiral MAV7600AGW WASHER-TOP LOADING
Maytag MAV7600AWQ WASHER, ATLANTIS
Maytag MAV7600AWW WASHER, ATLANTIS
Admiral MAV7600BGW WASHER-TOP LOADING
Admiral MAV7600CGW WASHER-TOP LOADING
Maytag MAV7650AWQ WASHER, ATLANTIS
Maytag MAV7650AWW WASHER, ATLANTIS
Maytag MAV7657EWQ WASHER, ATLANTIS
Maytag MAV7657EWW WASHER, ATLANTIS
Maytag MAV7700AWQ WASHER, ATLANTIS
Maytag MAV7700AWW WASHER, ATLANTIS
Admiral MAV7750AGW WASHER-TOP LOADING
Admiral MAV7750BGW WASHER-TOP LOADING
Admiral MAV7750CGW WASHER-TOP LOADING
Maytag MAV7757AWQ WASHER, ATLANTIS
Maytag MAV7757AWW WASHER, ATLANTIS
Maytag MAV8000AWQ WASHER, ATLANTIS
Maytag MAV8000AWW WASHER, ATLANTIS
Maytag MAV8057AWQ WASHER, ATLANTIS
Maytag MAV8057AWW WASHER, ATLANTIS
Maytag MAV8260AWQ WASHER, ATLANTIS
Maytag MAV8260AWW WASHER, ATLANTIS
Maytag MAV8500AWQ WASHER, ATLANTIS
Maytag MAV8500AWW WASHER, ATLANTIS
Maytag MAV8551AWQ WASHER, ATLANTIS
Maytag MAV8551AWW WASHER, ATLANTIS
Maytag MAV8557AWQ WASHER, ATLANTIS
  #2 (permalink)
Old 05-07-2017, 10:02 AM
Senior Member
PNWDrew is on a distinguished road
Default
It's either your brake rotor or stator probably. maybe both. Neither is a difficult change but require a special tool to remove due to a large spring that must be compressed during the process. You may be able to just sand or clean them and stop the squeak if you can find/borrow/steal the tool. Your local appliance repair parts shop might have a tool loan program also.
There also may be a way to do it without the tool, I've never had to try. Look on youtube, I'm sure someone has worked out a way, safety be damned!
It'll be #13 and 15 on this diagram
Parts for Maytag MAVT236AWW: Transmission Parts - AppliancePartsPros.com
It's also possible that your brake cam is misbehaving due to wear, lean the machine back so it is safe to work under. You'll need to pop the white cap off to view the cam under it. The white plastic pulley should rotate easily in one direction but the other it has to lift the brake rotor off the stator to allow the machine to spin. There is a arrow molded in that indicates how far it can travel under normal operation. There is a kit for this repair also on that page I linked above.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer turns off mid cycle and then turns itself back on acosto04 Dryer Repair 3 12-08-2017 12:38 PM
Maytag sqeaks during wash cycle showtime13 Washer Repair 0 02-13-2015 12:49 PM
GE washer making noise when basket turns honey_dave Washer Repair 4 09-04-2014 07:32 AM
Washer pulses lights while agitation cycle, but turns very little manram Washer Repair 17 08-19-2013 02:48 PM
metallic scraping sound when basket turns ddixon Washer Repair 3 10-17-2009 02:56 PM
