Discuss
Bad drain pump or something else
 in
Washer Repair
My Whirlpool Duet stopped working today. Error code F09 / E01. I used a shop vac to remove the water
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Bad drain pump or something else
  #1 (permalink)
Old 04-30-2017, 08:37 PM
Junior Member
JH69 is on a distinguished road
Post Bad drain pump or something else
Model Number: WFW94HEXW0   Brand: Whirlpool   Age: 5 - 10 years
My Whirlpool Duet stopped working today. Error code F09 / E01. I used a shop vac to remove the water out of the drain lines (no problem). While there was some lint / debris build up, nothing that indicated a clogged line. So I tested the machine again and found the same issue. I opened the machine and removed and cleaned the drain filter. While I had access, I pulled the pump (which was very warm) and tested the motor (Askoll M75). I found continuity and a resistance of 17.4 Ohms. The impeller isn't blocked and will turn. So I tested the power to the motor and found 118 volts. My instinct is this motor is going bad.
Questions:
1. Is 17.4 Ohms too high for the pump motor?
2. If so, does anyone sell just the pump motor and not the entire assembly?
Related Models
Whirlpool WFW94HEXW0 WASHER
Whirlpool WFW94HEXW1 AUTOMATIC WASHER
Whirlpool WFW94HEXW2 AUTOMATIC WASHER
Whirlpool WFW9500TC00 AUTOMATIC WASHER
Whirlpool WFW9500TC01 AUTOMATIC WASHER
Whirlpool WFW9500TC02 AUTOMATIC WASHER
Whirlpool WFW9500TC03 AUTOMATIC WASHER
Whirlpool WFW9500TW00 AUTOMATIC WASHER
Whirlpool WFW9500TW01 AUTOMATIC WASHER
Whirlpool WFW9500TW02 AUTOMATIC WASHER
Whirlpool WFW9500TW03 AUTOMATIC WASHER
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
Whirlpool WFW9550WW10 AUTOMATIC WASHER
Whirlpool WFW95HEXL0 WASHER
Whirlpool WFW95HEXL1 AUTOMATIC WASHER
Whirlpool WFW95HEXL2 AUTOMATIC WASHER
Whirlpool WFW95HEXR0 WASHER
Whirlpool WFW95HEXR1 AUTOMATIC WASHER
Whirlpool WFW95HEXR2 AUTOMATIC WASHER
Whirlpool WFW95HEXW0 WASHER
Whirlpool WFW95HEXW1 AUTOMATIC WASHER
Whirlpool WFW95HEXW2 AUTOMATIC WASHER
Whirlpool WFW9600TA00 AUTOMATIC WASHER
Whirlpool WFW9600TA01 AUTOMATIC WASHER
Whirlpool WFW9600TA02 AUTOMATIC WASHER
Whirlpool WFW9600TB00 AUTOMATIC WASHER
Whirlpool WFW9600TC00 AUTOMATIC WASHER
Whirlpool WFW9600TU00 AUTOMATIC WASHER
Whirlpool WFW9600TW00 AUTOMATIC WASHER
Whirlpool WFW9600TW01 AUTOMATIC WASHER
Whirlpool WFW9600TW02 AUTOMATIC WASHER
Whirlpool WFW9600TZ00 AUTOMATIC WASHER
Whirlpool WFW9640XW00 AUTOMATIC WASHER
Whirlpool WFW9700VA00 AUTOMATIC WASHER
Whirlpool WFW9700VA01 AUTOMATIC WASHER
Whirlpool WFW9700VW00 AUTOMATIC WASHER
Whirlpool WFW9700VW01 AUTOMATIC WASHER
Whirlpool WFW9750WL00 AUTOMATIC WASHER
Whirlpool WFW9750WL01 AUTOMATIC WASHER
Whirlpool WFW9750WL02 AUTOMATIC WASHER
Whirlpool WFW9750WR00 AUTOMATIC WASHER
Whirlpool WFW9750WR01 AUTOMATIC WASHER
Whirlpool WFW9750WR02 AUTOMATIC WASHER
Whirlpool WFW9750WW00 AUTOMATIC WASHER
Whirlpool WFW9750WW01 AUTOMATIC WASHER
Whirlpool WFW9750WW02 AUTOMATIC WASHER
Whirlpool WFW97HEXL0 WASHER
Whirlpool WFW97HEXL1 WASHER
Whirlpool WFW97HEXL2 AUTOMATIC WASHER
Whirlpool WFW97HEXR0 WASHER
Whirlpool WFW97HEXR1 WASHER
Whirlpool WFW97HEXR2 AUTOMATIC WASHER
Whirlpool WFW97HEXW0 WASHER
Whirlpool WFW97HEXW1 WASHER
Whirlpool WFW97HEXW2 AUTOMATIC WASHER
Amana WG1010.000 COMMERCIAL MICROWAVES
Amana WG1010.010 COMMERCIAL MICROWAVES
Amana WG1010.200 COMMERCIAL MICROWAVES
Amana WG1021.000 COMMERCIAL MICROWAVES
Amana WG1021.200 COMMERCIAL MICROWAVES
Amana WG1065.000 COMMERCIAL MICROWAVES
Amana WG1120.500 COMMERCIAL MICROWAVES
Amana WG1120.600 COMMERCIAL MICROWAVES
Amana WG1121.000 COMMERCIAL MICROWAVES
Amana WG1165.000 COMMERCIAL MICROWAVES
Amana WG1165.700 COMMERCIAL MICROWAVES
Amana WG1166.500 COMMERCIAL MICROWAVES
 WG1804R Air Conditioner
 WG1805RY6 Air Conditioner
Jenn-Air WG200 WALLOVEN- CONT CLEAN GAS
Jenn-Air WG206 WALLOVEN- CONT CLEAN GAS
Jenn-Air WG24000B WALLOVEN- STD GAS
Jenn-Air WG24000W WALLOVEN- STD GAS
Jenn-Air WG30100B WALLOVEN- S/C GAS
Jenn-Air WG30100W WALLOVEN- S/C GAS
Amana WG445.1 COMMERCIAL MICROWAVES
Amana WG445.2 COMMERCIAL MICROWAVES
 WG5200R Air Conditioner
Whirlpool WGD4750XQ0 29" GAS DRYER
Whirlpool WGD4750XQ1 29" GAS DRYER
Whirlpool WGD4800XQ0 DRYER
Whirlpool WGD4850XQ0 29" GAS DRYER
Whirlpool WGD4890XQ0 29" GAS DRYER
Whirlpool WGD4900XW0 29" GAS DRYER
Whirlpool WGD4910XQ0 29" GAS DRYER
Whirlpool WGD5000VQ1 29" GAS DRYER
Whirlpool WGD5100SQ0 29" GAS DRYER
Whirlpool WGD5100VQ0 29" GAS DRYER
Whirlpool WGD5100VQ1 29" GAS DRYER
Whirlpool WGD5200TQ0 29" GAS DRYER
Whirlpool WGD5200VQ0 29" GAS DRYER
Whirlpool WGD5200VQ1 29" GAS DRYER
Whirlpool WGD5300SQ0 29"GAS DRYER
Whirlpool WGD5300ST0 29"GAS DRYER
Whirlpool WGD5300VW0 29" GAS DRYER
Whirlpool WGD5300VW1 29" GAS DRYER
Whirlpool WGD5310SQ0 29"GAS DRYER
Whirlpool WGD5320SQ0 29"GAS DRYER
Whirlpool WGD5321SQ0 29"GAS DRYER
Whirlpool WGD5500SQ0 29"GAS DRYER
Whirlpool WGD5500ST0 29"GAS DRYER
Whirlpool WGD5500XL0 27" ELECTRIC DRYER
Whirlpool WGD5500XL1 27" ELECTRIC DRYER
Whirlpool WGD5500XW0 27" ELECTRIC DRYER
Whirlpool WGD5500XW1 27" ELECTRIC DRYER
Whirlpool WGD5510VQ0 29"GAS DRYER
Whirlpool WGD5510VQ1 29"GAS DRYER
Whirlpool WGD5520SQ0 29" GAS DRYER
Whirlpool WGD5521SQ0 29"GAS DRYER
Whirlpool WGD5530SQ0 29"GAS DRYER
Whirlpool WGD5540SQ0 29"GAS DRYER
Whirlpool WGD5540ST0 29"GAS DRYER
Whirlpool WGD5550SQ0 29" GAS DRYER
Whirlpool WGD5550ST0 29" GAS DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
BAFFLED!! LG Washer won't drain. Drain clear, pump works. SimplyBaffled Washer Repair 2 04-20-2016 04:38 PM
Dish washer won't drain after replace the drain pump Bryanhouston Dishwasher Repair 0 03-09-2015 08:56 PM
bosch shu9925 - drain pump works, won't drain after cycle mjbarr Dishwasher Repair 0 10-16-2009 01:11 PM
will this pump also pump the drain water out Paul Radovsky Dishwasher Repair 5 07-20-2008 01:41 PM
