Discuss
Bad Resistor on Inverter Board f/ Midea Washer+Dryer
 in
Washer Repair
Hello, I have a used Midea Washer Dryer combo in a closet on 120V in RV with surge protection and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Bad Resistor on Inverter Board f/ Midea Washer+Dryer
  #1 (permalink)
Old 04-24-2017, 11:49 AM
Junior Member
twscfltx is on a distinguished road
Question Bad Resistor on Inverter Board f/ Midea Washer+Dryer
Model Number: MFL70-D1211S   Brand: -brand-   Age: Less than 1 year
Hello,
I have a used Midea Washer Dryer combo in a closet on 120V in RV with surge protection and 20 Amp breaker. Error E64 started after we used it for three months. E64 means "Signal between Main PCB and Inverter PCB abnormal". I removed the inverter board and found a burned / blown out thermal resistor. I cannot tell the type or specs, so I'm not sure how to replace it. Midea said replacement parts were designed and made in China. Midea has replacement for $135. I found replacement part on Google search with a 820 Ohm resistor in place of the thermal resistor.
The resistor is in parallel between the relay and rectifier and in parallel with transformer and rectifier. I think the replacement resistor is a 4 band Grey/Red/Brown/Gold, but I do not know what the power requirements need to be. If it is 820 Ohms at 120V, then that would be .15 Amps and 18 Watts.
I would like to replace the resistor and add a fan to circulate air around the W/D.
Any suggestions?
Thank you,
Tyler
Related Models
Maytag MFR18MCAAS MANUAL, PARTS (WASHER)
Maytag MFR18MCAVS MANUAL, PARTS (WASHER)
Maytag MFR18PCAAS MANUAL, PARTS (WASHER)
Maytag MFR18PCAVS MANUAL, PARTS (WASHER)
Maytag MFR18PDAAS MAYTAG LAUNDRY (WASHER)
Maytag MFR18PDAVS MAYTAG LAUNDRY (WASHER)
Maytag MFR18PDCWS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR25MCATS MANUAL, PARTS (WASHER)
Maytag MFR25MCAVS MANUAL, PARTS (WASHER)
Maytag MFR25PCATS MANUAL, PARTS (WASHER)
Maytag MFR25PCAVS MANUAL, PARTS (WASHER)
Maytag MFR25PDATS MAYTAG LAUNDRY (WASHER)
Maytag MFR25PDAVS MAYTAG LAUNDRY (WASHER)
Maytag MFR25PDCWS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR30PDCTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR30PNCTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR35MCATS MANUAL, PARTS (WASHER)
Maytag MFR35MCAVS MANUAL, PARTS (WASHER)
Maytag MFR35MNATS MANUAL, PARTS (COMMERCIAL) (WASHER)
Maytag MFR35MNAVS MANUAL, PARTS (COMMERCIAL) (WASHER)
Maytag MFR35PCATS MANUAL, PARTS (WASHER)
Maytag MFR35PCAVS MANUAL, PARTS (WASHER)
Maytag MFR35PDATS MAYTAG LAUNDRY (WASHER)
Maytag MFR35PDAVS MAYTAG LAUNDRY (WASHER)
Maytag MFR35PNAVS MANUAL, PARTS (WASHER)
Maytag MFR35PNBVS MAYTAG LAUNDRY (WASHER)
Maytag MFR40PDCTS MAYTAG LAUNDRY CATALOG (WASHER)
Maytag MFR40PNCTS MAYTAG LAUNDRY CATALOG (WASHER)
Maytag MFR50MCATS MANUAL, PARTS (WASHER)
Maytag MFR50MCAVS MANUAL, PARTS (WASHER)
Maytag MFR50MNAVS MANUAL, PARTS (COMMERCIAL) (WASHER)
Maytag MFR50PCATS MANUAL, PARTS (WASHER)
Maytag MFR50PCAVS MANUAL, PARTS (WASHER)
Maytag MFR50PDATS MAYTAG WASHER (WASHER)
Maytag MFR50PDAVS MAYTAG WASHER (WASHER)
Maytag MFR50PDCTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR50PNAVS MANUAL, PARTS (WASHER)
Maytag MFR50PNBVS MAYTAGLAUNDRY (WASHER)
Maytag MFR60PDCTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR60PNCTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR80PCAVS MANUAL, PARTS (WASHER)
Maytag MFR80PDAVS MANUAL, PARTS (WASHER)
Maytag MFR80PDCTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR80PNCTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFS100PAVS MANUAL, PARTS (WASHER)
Maytag MFS100PFVS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFS125PAVS MANUAL, PART (WASHER)
Maytag MFS125PFVS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFS25PNAVS MAYTAG LAUNDRY (WASHER)
Maytag MFS25PNFTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFS35PNAVS MAYTAG LAUNDRY (WASHER)
Maytag MFS35PNDVS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFS35PNFTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFS50PNAVS MANUAL, PARTS (PRIMUS) (WASHER)
Maytag MFS50PNDVS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFS50PNFVS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFS50PNJVS COMMERCIAL INDUSTRIAL WASHER
Maytag MFS55PNAVS COMMERCIAL INDUSTRIAL WASHER
Maytag MFS75PNAVS MANUAL, PARTS (PRIMUS) (WASHER)
Maytag MFS80PNAVS MANUAL, PARTS (WASHER)
Maytag MFS80PNDVS COMMERCIAL LAUNDRY (WASHER)
Maytag MFS80PNFVS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFS90PNAVS MANUAL, PART (WASHER)
Maytag MFT2771WEB0 REFRIGERATOR
Maytag MFT2771WEB1 REFRIGERATOR
Maytag MFT2771WEM0 REFRIGERATOR
Maytag MFT2771WEM1 REFRIGERATOR
Maytag MFT2771WEM2 REFRIGERATOR
Maytag MFT2771WEW0 REFRIGERATOR
Maytag MFT2771WEW1 REFRIGERATOR
Frigidaire MFU05M3AW0 Frg(v1) / Upright Freezer
Frigidaire MFU05M3AW1 Frg(v0) / Upright Freezer
Frigidaire MFU07M3AW0 Frg(v1) / Upright Freezer
Frigidaire MFU07M3AW1 Frg(v0) / Upright Freezer
Frigidaire MFU09M2AW0 Tap(v7) / Upright Freezer
Frigidaire MFU09M2AW1 Tap(v8) / Upright Freezer
Frigidaire MFU09M2BW0 Tap(v4) / Upright Freezer
Frigidaire MFU09M2BW1 Frg(v1) / Upright Freezer
Frigidaire MFU09M2BW2 Frg(v0) / Upright Freezer
Frigidaire MFU09M2BW3 Frg(v0) / Upright Freezer
Frigidaire MFU09M2BW4 Frg(v0) / Freezer
Frigidaire MFU09M2GW0 Frg(v0)
Frigidaire MFU09M2GW2 Frg(v0) / Freezer
Frigidaire MFU09M2GW3 Frg(v0) / Freezer
Frigidaire MFU09M2GW4 Frg(v0) / Freezer
Frigidaire MFU09M2GW5 Frg/freezer
Frigidaire MFU09M2GW6 Frigidaire/freezer
Frigidaire MFU12M0BW0 Tap(v4) / Upright Freezer
Frigidaire MFU12M0BW1 Frg(v1) / Upright Freezer
Frigidaire MFU12M0BW2 Frg(v0) / Upright Freezer
Frigidaire MFU12M0BW3 Frg(v0) / Upright Freezer
Frigidaire MFU12M0BW4 Frg(v0) / Freezer
Frigidaire MFU12M0GW0 Frg(v0)
Frigidaire MFU12M0GW2 Frigidaire/freezer
Frigidaire MFU12M2AW0 Tap(v10) / Upright Freezer
Frigidaire MFU12M2AW1 Tap(v11) / Upright Freezer
Frigidaire MFU12M2AW2 Tap(v12) / Upright Freezer
Frigidaire MFU12M2BW0 Tap(v4) / Upright Freezer
Frigidaire MFU12M2BW1 Frg(v1) / Upright Freezer
Frigidaire MFU12M2BW2 Frg(v0) / Upright Freezer
Frigidaire MFU12M2BW3 Frg(v0) / Upright Freezer
Frigidaire MFU12M2BW4 Frg(v0) / Freezer
Frigidaire MFU12M2GW0 Frg(v0)
Frigidaire MFU12M2GW1 Frigidaire/freezer
Frigidaire MFU12M2GW2 Frigidaire/freezer
Frigidaire MFU14D2FW0 Frg(v0) / Freezer
Frigidaire MFU14D2FW1 Frg(v0) / Freezer
Frigidaire MFU14D2GW0 Frg(v0)
Frigidaire MFU14F1EW0 Frg(v0) / Upright Freezer
Frigidaire MFU14F1EW1 Frg(v0) / Upright Freezer
Frigidaire MFU14F1EW2 Frg(v0) / Freezer
Frigidaire MFU14F1GW0 Frg(v0)
Frigidaire MFU14F1GW1 Frg(v1)
Frigidaire MFU14F1GW2 Frg(v2)
Frigidaire MFU14F3BW0 Frg(v1) / Upright Freezer
Frigidaire MFU14F3BW1 Frg(v1) / Upright Freezer
Frigidaire MFU14F3BW2 Wwh(v0) / Freezer
Frigidaire MFU14F3BW3 Frg(v0) / Upright Freezer
Frigidaire MFU14F3BW4 Frg(v0) / Upright Freezer
Frigidaire MFU14F3BW5 Frg(v0) / Upright Freezer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Resistor values on motor control board Coolbaja Washer Repair 2 11-21-2016 08:32 AM
Kenmore Gas Range Fried Resistor on Control Board toddo03 Oven Repair (including Ranges and Cooktops) 0 11-17-2015 02:27 PM
Inverter board moleary Microwave Repair 5 06-13-2011 09:16 AM
GE Washer, No Spin, Inverter or Control Board ?? onetech Washer Repair 1 06-10-2010 04:45 AM
Bad Resistor in control board? Will this create a spin issue? Brandon Washer Repair 3 03-03-2008 02:40 AM
