Discuss
whirlpool Ultimate Care II
 in
Washer Repair
My whirlpool Ultimate Care II fills with water but wont spin. It makes a humming sound like its trying to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool Ultimate Care II
  #1 (permalink)
Old 04-19-2017, 07:21 PM
Junior Member
johnep33333 is on a distinguished road
Default whirlpool Ultimate Care II
Brand: Whirlpool   Age: More than 10 years
My whirlpool Ultimate Care II fills with water but wont spin. It makes a humming sound like its trying to spin. I checked the pump and it is clear. If I disconnect the motor I can spin it by hand and it starts spinning. All the connectors are in good shape. I replaced the timer switch and get the same problem. I bypassed the lid switch and same problem. I would think it had to be the motor but it will work if i give it a spin start by hand. Any help would be appreciated!!!!
  #2 (permalink)
Old 04-21-2017, 10:57 AM
Junior Member
manfred63 is on a distinguished road
Default
Sounds like either the pump is too hard to spin, such as the middle part that spins the impeller is stuck or frozen somewhat in place. OR, it could be a bad capacitor. Remove the water pump from the shaft, then see if it will spin normally. If it will, I would look closer at the pump, try spinning the impeller manually to see if it is easy to spin or very hard to spin. Replace pump if cant spin easily. If pump is good, test the capacitor, and replace it if it tests bad.
This video might help you out with that https://youtu.be/KXoxCVG_NBo
Ken's Appliance Repair
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool ultimate care II smith96 Washer Repair 7 05-28-2014 12:45 AM
whirlpool ultimate care ii. Blackgrass Washer Repair 1 01-18-2013 06:01 PM
Whirlpool Ultimate Care II Oakrad1 Washer Repair 0 04-07-2012 05:18 AM
Whirlpool Ultimate Care II fayef Washer Repair 3 10-29-2011 02:02 AM
whirlpool ultimate care 2 higleyml Washer Repair 4 07-05-2009 11:04 AM
