Discuss
Code F3E2 Water Temp Sensor Error
 in
Washer Repair
Repaired broken wire to Water Temp Sensor. Checked continuity from Water Temp Sensor to CCU. 14 k ohm at 70
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Code F3E2 Water Temp Sensor Error
  #1 (permalink)
Old 04-14-2017, 05:59 PM
Junior Member
ldbeng@verizon.net is on a distinguished road
Default Code F3E2 Water Temp Sensor Error
Model Number: WFW9151YW00   Brand: Whirlpool   Age: 1 - 5 years
Repaired broken wire to Water Temp Sensor. Checked continuity from Water Temp Sensor to CCU. 14 k ohm at 70 F - good.
Ran through Diagnostic Test - Cleared codes - 88 displayed.
Unplugged from power.
Plugged back in..
Same code F3E2.
Is there a way to do a "hard reset"?
Dan
Related Models
Whirlpool WFW9151YW00 WASHER
Whirlpool WFW9200SQ00 AUTOMATIC WASHER
Whirlpool WFW9200SQ01 AUTOMATIC WASHER
Whirlpool WFW9200SQ02 AUTOMATIC WASHER
Whirlpool WFW9200SQ03 AUTOMATIC WASHER
Whirlpool WFW9200SQ04 AUTOMATIC WASHER
Whirlpool WFW9200SQ10 AUTOMATIC WASHER
Whirlpool WFW9200SQA10 AUTOMATIC WASHER
Whirlpool WFW9200SQA11 AUTOMATIC WASHER
Whirlpool WFW9200SQA12 AUTOMATIC WASHER
Whirlpool WFW9250WL00 AUTOMATIC WASHER
Whirlpool WFW9250WL01 AUTOMATIC WASHER
Whirlpool WFW9250WL02 AUTOMATIC WASHER
Whirlpool WFW9250WR00 AUTOMATIC WASHER
Whirlpool WFW9250WR01 AUTOMATIC WASHER
Whirlpool WFW9250WR02 AUTOMATIC WASHER
Whirlpool WFW9250WW00 AUTOMATIC WASHER
Whirlpool WFW9250WW01 AUTOMATIC WASHER
Whirlpool WFW9250WW02 WASHER
Whirlpool WFW9300VU02 AUTOMATIC WASHER
Whirlpool WFW9300VU03 AUTOMATIC WASHER
Whirlpool WFW9300VU04 AUTOMATIC WASHER
Whirlpool WFW9351YL00 AUTOMATIC WASHER
Whirlpool WFW9351YW00 AUTOMATIC WASHER
Whirlpool WFW9400SB00 AUTOMATIC WASHER
Whirlpool WFW9400SB01 AUTOMATIC WASHER
Whirlpool WFW9400SB02 AUTOMATIC WASHER
Whirlpool WFW9400SBA10 AUTOMATIC WASHER
Whirlpool WFW9400ST00 AUTOMATIC WASHER
Whirlpool WFW9400ST01 AUTOMATIC WASHER
Whirlpool WFW9400ST02 AUTOMATIC WASHER
Whirlpool WFW9400STA10 AUTOMATIC WASHER
Whirlpool WFW9400SU00 AUTOMATIC WASHER
Whirlpool WFW9400SU01 AUTOMATIC WASHER
Whirlpool WFW9400SU02 AUTOMATIC WASHER
Whirlpool WFW9400SW00 AUTOMATIC WASHER
Whirlpool WFW9400SW01 AUTOMATIC WASHER
Whirlpool WFW9400SW02 AUTOMATIC WASHER
Whirlpool WFW9400SW03 AUTOMATIC WASHER
Whirlpool WFW9400SW04 AUTOMATIC WASHER
Whirlpool WFW9400SWA10 AUTOMATIC WASHER
Whirlpool WFW9400SZ00 AUTOMATIC WASHER
Whirlpool WFW9400SZ01 AUTOMATIC WASHER
Whirlpool WFW9400SZ02 AUTOMATIC WASHER
Whirlpool WFW9400SZ03 AUTOMATIC WASHER
Whirlpool WFW9400SZ04 AUTOMATIC WASHER
Whirlpool WFW9400SZA10 AUTOMATIC WASHER
Whirlpool WFW9400VE01 AUTOMATIC WASHER
Whirlpool WFW9400VE02 AUTOMATIC WASHER
Whirlpool WFW9400VE03 AUTOMATIC WASHER
Whirlpool WFW9410XW00 WASHER
Whirlpool WFW9450WL00 AUTOMATIC WASHER
Whirlpool WFW9450WR00 AUTOMATIC WASHER
Whirlpool WFW9450WW00 AUTOMATIC WASHER
Whirlpool WFW9451XW00 AUTOMATIC WASHER
Whirlpool WFW9470WL00 AUTOMATIC WASHER
Whirlpool WFW9470WL01 AUTOMATIC WASHER
Whirlpool WFW9470WR00 AUTOMATIC WASHER
Whirlpool WFW9470WR01 AUTOMATIC WASHER
Whirlpool WFW9470WW00 AUTOMATIC WASHER
Whirlpool WFW9470WW01 AUTOMATIC WASHER
Whirlpool WFW94HEXL0 WASHER
Whirlpool WFW94HEXL1 AUTOMATIC WASHER
Whirlpool WFW94HEXL2 AUTOMATIC WASHER
Whirlpool WFW94HEXR0 WASHER
Whirlpool WFW94HEXR1 AUTOMATIC WASHER
Whirlpool WFW94HEXR2 AUTOMATIC WASHER
Whirlpool WFW94HEXW0 WASHER
Whirlpool WFW94HEXW1 AUTOMATIC WASHER
Whirlpool WFW94HEXW2 AUTOMATIC WASHER
Whirlpool WFW9500TC00 AUTOMATIC WASHER
Whirlpool WFW9500TC01 AUTOMATIC WASHER
Whirlpool WFW9500TC02 AUTOMATIC WASHER
Whirlpool WFW9500TC03 AUTOMATIC WASHER
Whirlpool WFW9500TW00 AUTOMATIC WASHER
Whirlpool WFW9500TW01 AUTOMATIC WASHER
Whirlpool WFW9500TW02 AUTOMATIC WASHER
Whirlpool WFW9500TW03 AUTOMATIC WASHER
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
Whirlpool WFW9550WW10 AUTOMATIC WASHER
Whirlpool WFW95HEXL0 WASHER
Whirlpool WFW95HEXL1 AUTOMATIC WASHER
Whirlpool WFW95HEXL2 AUTOMATIC WASHER
Whirlpool WFW95HEXR0 WASHER
Whirlpool WFW95HEXR1 AUTOMATIC WASHER
Whirlpool WFW95HEXR2 AUTOMATIC WASHER
Whirlpool WFW95HEXW0 WASHER
Whirlpool WFW95HEXW1 AUTOMATIC WASHER
Whirlpool WFW95HEXW2 AUTOMATIC WASHER
Whirlpool WFW9600TA00 AUTOMATIC WASHER
Whirlpool WFW9600TA01 AUTOMATIC WASHER
Whirlpool WFW9600TA02 AUTOMATIC WASHER
Whirlpool WFW9600TB00 AUTOMATIC WASHER
Whirlpool WFW9600TC00 AUTOMATIC WASHER
Whirlpool WFW9600TU00 AUTOMATIC WASHER
Whirlpool WFW9600TW00 AUTOMATIC WASHER
Whirlpool WFW9600TW01 AUTOMATIC WASHER
Whirlpool WFW9600TW02 AUTOMATIC WASHER
Whirlpool WFW9600TZ00 AUTOMATIC WASHER
Whirlpool WFW9640XW00 AUTOMATIC WASHER
Whirlpool WFW9700VA00 AUTOMATIC WASHER
Whirlpool WFW9700VA01 AUTOMATIC WASHER
Whirlpool WFW9700VW00 AUTOMATIC WASHER
Whirlpool WFW9700VW01 AUTOMATIC WASHER
Whirlpool WFW9750WL00 AUTOMATIC WASHER
Whirlpool WFW9750WL01 AUTOMATIC WASHER
Whirlpool WFW9750WL02 AUTOMATIC WASHER
Whirlpool WFW9750WR00 AUTOMATIC WASHER
Whirlpool WFW9750WR01 AUTOMATIC WASHER
Whirlpool WFW9750WR02 AUTOMATIC WASHER
Whirlpool WFW9750WW00 AUTOMATIC WASHER
Whirlpool WFW9750WW01 AUTOMATIC WASHER
Whirlpool WFW9750WW02 AUTOMATIC WASHER
Whirlpool WFW97HEXL0 WASHER
  #2 (permalink)
Old 07-24-2017, 11:21 PM
Junior Member
barona1 is on a distinguished road
Default Wfw9151yw00 - F3e2 - Solved
My washer has the F3E2 error.
It is the temperature sensor.
In my case, it was the wire going to the temp sensor which broke when I touched it.
1) Remove the top panel
2) Remove the rear panel
3) Looking in the rear of the machine, there is a small bundle of wires
going from the lower left towards the tub.
The two black wires go to the sensor which is on the tub rear.
Follow the black wires and 'man-handle' them a little bit.
For me, one of the black wires broke right at a zip-tie.
The wire on the 'tub-side' of the zip-wire broke because it needs to flex ad
the tub vibrates...just like bending a paper-clip repeatedly. It will break.
Fix by removing a little bit of insulation, twist together, solder or do something
to keep them together.
And CUT that one particular zip tie.
Ta-Da!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
error code f3e2 David Sandberg Washer Repair 0 07-27-2015 11:53 AM
Code F3E2 flashes after replacing oven heat sensor unit 2 times lorrainebirkett Oven Repair (including Ranges and Cooktops) 0 09-07-2011 01:08 PM
Magic Chef F3 error code even after temp sensor replacement ponderitsome Oven Repair (including Ranges and Cooktops) 3 07-22-2011 10:24 AM
Frigidaire F1 Error Code with a beep//EOC or Temp sensor pteaster Oven Repair (including Ranges and Cooktops) 0 03-15-2010 10:43 PM
Dacor Epicure wall oven error code L-34 Temp sensor HDK Oven Repair (including Ranges and Cooktops) 8 12-21-2009 05:45 PM
