Discuss
Help! Problem Installing New Bearings in Maytag Bravos Washer
 in
Washer Repair
Everything was going smoothly. Used the recommended bearing press tool to install the bearings. I installed the new drive shaft.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Help! Problem Installing New Bearings in Maytag Bravos Washer
  #1 (permalink)
Old 04-10-2017, 04:26 PM
Junior Member
Twang is on a distinguished road
Default Help! Problem Installing New Bearings in Maytag Bravos Washer
Model Number: MVWB750WQ0   Brand: Maytag   Age: 5 - 10 years
Everything was going smoothly. Used the recommended bearing press tool to install the bearings. I installed the new drive shaft. Used a hammer and block of wood to ensure the drive shaft bottomed out on the top bearing. Instructions said to "tap" with hammer. It required a few strokes a bit harder than a "tap" to get the drive shaft to bottom out flat against the bearing. I installed new shaft nut, stator back plate, and stator. I checked the drive shaft by turning it with my hand. It turned freely. I installed the rotor and then checked the drive shaft again by turning it by hand. The rotor turns part of a revolution freely than exhibits a firm resistance. It still turns but much harder. Frees up again as I continue turning it by hand, then resistance again. When I remove the rotor, the shaft turns freely. Put the rotor back on, free movement then resistance. Any ideas what could be causing the rotor to bind against the stator? I would really appreciate some help. Thanks so much.
Related Models
Maytag MVWB750WQ0 AUTOMATIC WASHER
Maytag MVWB750WQ1 AUTOMATIC WASHER
Maytag MVWB750WR0 AUTOMATIC WASHER
Maytag MVWB750WR1 AUTOMATIC WASHER
Maytag MVWB800VB0 AUTOMATIC WASHER
Maytag MVWB800VQ0 AUTOMATIC WASHER
Maytag MVWB800VU0 AUTOMATIC WASHER
Maytag MVWB850WB0 AUTOMATIC WASHER
Maytag MVWB850WB1 AUTOMATIC WASHER
Maytag MVWB850WL0 AUTOMATIC WASHER
Maytag MVWB850WL1 AUTOMATIC WASHER
Maytag MVWB850WQ0 AUTOMATIC WASHER
Maytag MVWB850WQ1 AUTOMATIC WASHER
Maytag MVWB850WR0 AUTOMATIC WASHER
Maytag MVWB850WR1 AUTOMATIC WASHER
Maytag MVWC300VW0 AUTOMATIC WASHER
Maytag MVWC300VW1 AUTOMATIC WASHER
Maytag MVWC400VW0 AUTOMATIC WASHER
Maytag MVWC400VW1 AUTOMATIC WASHER
Maytag MVWC450WW0 AUTOMATIC WASHER
Maytag MVWC500VW0 AUTOMATIC WASHER
Maytag MVWC500VW1 AUTOMATIC WASHER
Maytag MVWC5ESXW0 AUTOMATIC WASHER
Maytag MVWC6ESWW0 AUTOMATIC WASHER
Maytag MVWC6ESWW1 AUTOMATIC WASHER
Maytag MVWC700VJ0 AUTOMATIC WASHER
Maytag MVWC700VJ1 AUTOMATIC WASHER
Maytag MVWC700VW0 AUTOMATIC WASHER
Maytag MVWC700VW1 AUTOMATIC WASHER
Maytag MVWC7ESWW0 AUTOMATIC WASHER
Maytag MVWX500XL0 AUTOMATIC WASHER
Maytag MVWX500XW0 AUTOMATIC WASHER
Maytag MVWX550XW0 AUTOMATIC WASHER
Maytag MVWX600XW0 AUTOMATIC WASHER
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
Whirlpool MW3200XW0 Microwave
Whirlpool MW3500XM0 Microwaves*
Whirlpool MW3500XM1 Microwaves*
Whirlpool MW3500XP1 Microwaves*
Whirlpool MW3500XP2 Microwaves*
Whirlpool MW3500XP3 Microwaves*
Whirlpool MW3500XS0 Microwaves*
Whirlpool MW3500XW0 Microwaves*
Whirlpool MW3520XP1 Microwaves*
Whirlpool MW3520XP2 Microwaves*
Whirlpool MW3520XP3 Microwaves*
Whirlpool MW352EXP1 Microwaves*
Whirlpool MW3600XS0 Microwaves*
Whirlpool MW3600XW0 Microwaves*
Whirlpool MW3600XW1 Microwaves*
Whirlpool MW3601XS0 Microwaves*
Whirlpool MW3601XW0 Microwaves*
Whirlpool MW3601XW1 Microwaves*
Amana MW41 MWAVE- CNTRTP / STAND ALONE
Amana MW42 MWAVE- CNTRTP / STAND ALONE
Amana MW43 MWAVE- CNTRTP / STAND ALONE
Amana MW500.000 COMMERCIAL MICROWAVES
 MW5380W MWAVE- CNTRTP / STAND ALONE
Roper MW557 Microwave
Roper MW5571 Microwaves
 MW5592W MWAVE- CNTRTP / STAND ALONE
 MW5592W/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW56 MWAVE- CNTRTP / STAND ALONE
Amana MW57 MWAVE- CNTRTP / STAND ALONE
Amana MW58 MWAVE- CNTRTP / STAND ALONE
Amana MW600.000 COMMERCIAL MICROWAVES
 MW640BA MWAVE- CNTRTP / STAND ALONE
  #2 (permalink)
Old 04-12-2017, 01:52 PM
wbr wbr is offline
Junior Member
wbr is on a distinguished road
Default
It's possible you are experiencing magnetic resistance. Some front loaders (my LG does this) have a damping effect, when you try to spin the drum by hand - even when the machine is unplugged. After about 1/3 of a rotation, the electro-magnets in the stator oppose the motion of the rotor and drum. I don't know if it's an intentional feature, or just a byproduct of the motor design, but it is perfectly normal.
Is the resistance you're feeling smooth and quiet? Or is there a mechanical sound like grinding or scratching or scraping? Magnetic resistance should be silent and smooth.
  #3 (permalink)
Old 04-16-2017, 04:47 PM
Junior Member
Default
wbr, Thank you very much for your response. Mine is a top loader. The resistance is smooth and quiet. I wonder how I would go about confirming that the resistance is normal. Surprised no one else mentioned it. I was afraid to continue with the installation for fear of wasting the seal, adhesive, and grease if I had to pull it all out again.
  #4 (permalink)
Old 04-20-2017, 04:20 PM
Junior Member
Default
wbr,, you were absolutely correct. The washer is up and running like new! Thanks to you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Can the Maytag Bravos Tub Bearings be Installed Without the Bearing Driver Tool? Twang Washer Repair 2 03-13-2017 04:28 AM
Can the Maytag Bravos Tub Bearings be Installed Without the Bearing Driver Toool? Twang Washer Repair 0 03-10-2017 09:20 AM
Can the Maytag Bravos Tub Bearings be Removed Without the Bearing Driver Toool? Twang Washer Repair 0 03-10-2017 09:17 AM
Problem with Maytag Bravos EcoConserve tncatsfan Washer Repair 0 10-23-2016 10:08 AM
Maytag Bravos Washer Problem Mortimerlj Washer Repair 0 01-04-2016 12:07 PM
