Discuss
Whirlpool washer tub wont agitate or spin
 in
Washer Repair
I have a whirlpool washer LSB6200PQ1. it fills but wont agitate and makes noise. When placed on the spin cycle
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer tub wont agitate or spin
  #1 (permalink)
Old 04-06-2017, 11:36 PM
Junior Member
beachvillagers is on a distinguished road
Default Whirlpool washer tub wont agitate or spin
Model Number: LSB6200PQ1   Brand: Whirlpool   Age: 5 - 10 years
I have a whirlpool washer LSB6200PQ1. it fills but wont agitate and makes noise. When placed on the spin cycle , it drains but wont spin and makes noise again.
What may be the problem
Related Models
Whirlpool LSB6200PQ1 AUTOMATIC WASHER
Whirlpool LSB6200PQ2 AUTOMATIC WASHER
Whirlpool LSB6300LQ0 WASHER - DIRECT DRIVE
Whirlpool LSB6300LW0 WASHER - DIRECT DRIVE
Whirlpool LSB6300LW1 AUTOMATIC WASHER
Whirlpool LSB6300LW2 AUTOMATIC WASHER
Whirlpool LSB6300LW3 AUTOMATIC WASHER
Whirlpool LSB6300PW0 AUTOMATIC WASHER
Whirlpool LSB6300PW1 AUTOMATIC WASHER
Whirlpool LSB6300PW3 AUTOMATIC WASHER
Whirlpool LSB6300PW4 AUTOMATIC WASHER
Whirlpool LSB6400KQ0 WASHER
Whirlpool LSB6400KQ1 WASHER
Whirlpool LSB6400LW0 WASHER - DIRECT DRIVE
Whirlpool LSB6400LW1 AUTOMATIC WASHER
Whirlpool LSB6500PW0 AUTOMATIC WASHER
Whirlpool LSB6500PW1 AUTOMATIC WASHER
Whirlpool LSB6500PW2 AUTOMATIC WASHER
Whirlpool LSB6500PW3 AUTOMATIC WASHER
Whirlpool LSB6500PW4 AUTOMATIC WASHER
 LSC21943ST Refrigerator
 LSC26905SB Refrigerator
 LSC26905SW Refrigerator
 LSC26905TT Refrigerator
 LSC26945SW Refrigerator
 LSC26945TT Refrigerator
 LSC27910SB Refrigerator
 LSC27910ST Refrigerator
 LSC27910SW Refrigerator
 LSC27910TT Refrigerator
 LSC27926SB Refrigerator
 LSC27926ST Refrigerator
 LSC27926SW Refrigerator
 LSC27926TT Refrigerator
 LSC27931SB Refrigerator
 LSC27931ST Refrigerator
 LSC27931SW Refrigerator
 LSC27950SB Refrigerator
 LSC27950ST Refrigerator
 LSC27950SW Refrigerator
 LSC27970ST Refrigerator
 LSC27990TT Refrigerator
 LSC27991TT Refrigerator
Whirlpool LSC5000PQ0 AUTOMATIC WASHER
Whirlpool LSC5000PQ1 AUTOMATIC WASHER
Whirlpool LSC5000PQ2 AUTOMATIC WASHER
Whirlpool LSC6244AW0 Washers*
Whirlpool LSC6244BQ0 Washers*
Whirlpool LSC6244BW0 Washers*
Whirlpool LSC8244BG0 AUTOMATIC WASHER
Whirlpool LSC8244BG1 AUTOMATIC WASHER
Whirlpool LSC8244BN0 AUTOMATIC WASHER
Whirlpool LSC8244BN1 AUTOMATIC WASHER
Whirlpool LSC8244BQ0 AUTOMATIC WASHER
Whirlpool LSC8244BQ1 AUTOMATIC WASHER
Whirlpool LSC8244BW0 AUTOMATIC WASHER
Whirlpool LSC8244BW1 AUTOMATIC WASHER
Whirlpool LSC8244BZ0 AUTOMATIC WASHER
Whirlpool LSC8244BZ1 AUTOMATIC WASHER
Whirlpool LSC8244DQ0 AUTOMATIC WASHER
Whirlpool LSC8244DZ0 AUTOMATIC WASHER
Whirlpool LSC8244EQ0 WASHER
Whirlpool LSC8244EQ1 WASHER
Whirlpool LSC8244EZ0 WASHER
Whirlpool LSC8244EZ1 WASHER
Whirlpool LSC8245AN0 AUTOMATIC WASHER
Whirlpool LSC8245AQ0 AUTOMATIC WASHER
Whirlpool LSC8245AW0 Washers*
Whirlpool LSC8245BW0 Washers*
Whirlpool LSC9000PW0 AUTOMATIC WASHER
Whirlpool LSC9000PW1 AUTOMATIC WASHER
Whirlpool LSC9000PW2 AUTOMATIC WASHER
Whirlpool LSC9245BN0 AUTOMATIC WASHER
Whirlpool LSC9245BN1 AUTOMATIC WASHER
Whirlpool LSC9245BQ0 AUTOMATIC WASHER
Whirlpool LSC9245BQ1 AUTOMATIC WASHER
Whirlpool LSC9245BW0 AUTOMATIC WASHER
Whirlpool LSC9245BW1 AUTOMATIC WASHER
Whirlpool LSC9245BZ0 AUTOMATIC WASHER
Whirlpool LSC9245BZ1 AUTOMATIC WASHER
Whirlpool LSC9355AG0 AUTOMATIC WASHER
Whirlpool LSC9355AN0 AUTOMATIC WASHER
Whirlpool LSC9355AW0 Washers*
Whirlpool LSC9355BN0 AUTOMATIC WASHER
Whirlpool LSC9355BN1 AUTOMATIC WASHER
Whirlpool LSC9355BQ0 AUTOMATIC WASHER
Whirlpool LSC9355BQ1 AUTOMATIC WASHER
Whirlpool LSC9355BW0 AUTOMATIC WASHER
Whirlpool LSC9355BW1 AUTOMATIC WASHER
Whirlpool LSC9355BZ0 AUTOMATIC WASHER
Whirlpool LSC9355BZ1 AUTOMATIC WASHER
Whirlpool LSC9355DQ0 AUTOMATIC WASHER
Whirlpool LSC9355DZ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ1 DIRECT-DRIVE WASHER
Whirlpool LSC9355EZ0 AUTOMATIC WASHER
Whirlpool LSC9355EZ1 DIRECT-DRIVE WASHER
Admiral LSD2615HEB REF - SXS/I&W
Admiral LSD2615HEW REF - SXS/I&W
Admiral LSD2615HEZ REF - SXS/I&W
Maytag LSE1000 STACKED LAUNDRY- ELE
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-8 STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-C STACKED LAUNDRY- ELE
Jenn-Air LSE2704W STACKED LAUNDRY- ELE
Jenn-Air LSE2704W-8 STACKED LAUNDRY- ELE
Maytag LSE7800 STACKED LAUNDRY- ELE
Maytag LSE7800ACE STACKED LAUNDRY- ELE
Maytag LSE7800ACL STACKED LAUNDRY- ELE
Maytag LSE7800ACW STACKED LAUNDRY- ELE
Maytag LSE7800ADE STACKED LAUNDRY- ELE
Maytag LSE7800ADL STACKED LAUNDRY- ELE
Maytag LSE7800ADW STACKED LAUNDRY- ELE
Maytag LSE7800AEE STACKED LAUNDRY- ELE
Maytag LSE7800AEL STACKED LAUNDRY- ELE
Maytag LSE7800AEW STACKED LAUNDRY- ELE
Admiral LSE7800AGE STACKED LAUNDRY- ELE
Admiral LSE7800AGL STACKED LAUNDRY- ELE
Maytag LSE7804ACE STACKED LAUNDRY- ELE
  #2 (permalink)
Old 04-07-2017, 12:02 PM
Junior Member
manfred63 is on a distinguished road
Default
Sounds like the coupling between the motor and transmission shafts is broken. You will have to unplug machine, remove cabinet, and then remove water pump from the motor, then unplug motor and remove it from the transmission. You will see a 3 prong plastic piece on the shaft of the motor, and another one on the shaft of the transmission. And, a rubber coupling that both insert into so the motor can turn the transmission shaft. If the pins broke off of one of them, or if one of them cracked in the center and no longer grips the shaft, it wont be able to make transmission turn anymore. Part number from FSP is 285753A
Ken's Appliance Repair
  #3 (permalink)
Old 04-07-2017, 03:30 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Probably the coupling. There is a video on the page with the part.
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool wont agitate will drain and low speed spin mark6200 Washer Repair 3 02-14-2016 06:42 AM
GE washer fills wont agitate, drains but wont spin DUB C Washer Repair 1 06-24-2015 02:47 PM
washer wont agitate or spin bjsmith7 Washer Repair 3 03-22-2014 03:23 AM
whirlpool washer will agitate, but wont spin or drain robert garbacz Washer Repair 5 04-11-2011 07:26 AM
Whirlpool washer wont spin or agitate. sillyman Washer Repair 2 08-03-2010 12:29 PM
