Discuss
loud noise when washing, cam nut fell on the floor
 in
Washer Repair
Here is the information related to my question. 1. The model number of my maytag bravos top loading washer is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » loud noise when washing, cam nut fell on the floor
  #1 (permalink)
Old 04-04-2017, 12:03 PM
Junior Member
carleson is on a distinguished road
Default loud noise when washing, cam nut fell on the floor
Model Number: MVWX550XW1   Brand: Maytag   Age: 5 - 10 years
MVWX550XW1.
2. The parts diagrams can be found at
Parts for Maytag MVWX550XW1 / : Gearcase, Motor and Pump Parts - AppliancePartsPros.com
I'm referring to the diagram that is
04-Gearcase=Motor=Pump Parts
3. I found 2 videos of the replacement of the splutch cam kit that
is the one that my model uses, and am basing my questions on what
I've seen in those videos.
https://www.youtube.com/watch?v=TaNJ4CArjLo
https://www.youtube.com/watch?v=RKcsfGpk1xs
4. There has recently been a louder noise during the wash cycle.
(its has an impeller, not an older style agitator)
but the cycle does complete.
There is no unusual noise during the spin.
5. I see on the floor under the washer a bolt or nut that looks like the part
#14, on the parts diagram and listing on the above web page, which is called a nut in that
listing.
part #14 attaches to the cam that holds one end of the belt.
(those videos show that nut and how its removed from the part #13)
It fell on the floor exactly under where it would have been if its indeed the part #13)
6. My guess is that the nut had come loose and fell off after almost
6 years
but that the part #13, the part that holds one end of the belt,
was held in place by the plastic cover, part #20
and perhaps thats why the brief wash I did after the noise had gotten worse,
why it still worked - with the louder noise happening about 20%
of the wash cycle time.
that is, that the plastic cover held part #13 on enough to still
let it work, though it was struggling to do it since not being held
by the nut.
7. But since am not able to tip over the washer to see things,
I wanted to ask some questions to see what you thought, which could give me
some clues if this might be a high or low cost repair.
a. does it seem logical that that nut came loose and fell off,
versus it falling off cause the shaft it was on broke ?
If that whole shaft had broken, I don't know if wash or spin cycle would
have happened at all ?
b. Is it logical that the louder noise is due to the nut being off,
but the part #13 still being held on more or less by being
so close to the plastic cover ? (and thus thats why the cycle
did complete although with the louder noise at times)
or could it be that the part #13 has been damaged itself also
by not being held by the nut - if it had been, would the wash
cycle (or spin cycle) have even happened ?
or that other parts further up like 9, 10, 11, 12 might have been damaged
as a result - or would the wash or spin cycle have not worked at all if those
parts had been damaged ?
c. Am assuming that the belt is still working ok since the wash and spin cycles
completed ? (I realize a new belt might be needed in any case but trying
to understand here about the nut falling off situation re the louder noise.)
(That is, if the belt itself had broken, it would not have fallen on the floor
but would still be within that plastic cover, but in that case, I don't think
the wash or spin cycles would have happened ?
===> Of course I hope it would be as simple as just having that
nut, #14 scewed back on, and then things would work as before,
but I realize things are not always so easy.
I apolgize for the poor formatting of this post, I had to copy and paste from another editor.
Related Models
Maytag MVWX600XW0 AUTOMATIC WASHER
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
Whirlpool MW3200XW0 Microwave
Whirlpool MW3500XM0 Microwaves*
Whirlpool MW3500XM1 Microwaves*
Whirlpool MW3500XP1 Microwaves*
Whirlpool MW3500XP2 Microwaves*
Whirlpool MW3500XP3 Microwaves*
Whirlpool MW3500XS0 Microwaves*
Whirlpool MW3500XW0 Microwaves*
Whirlpool MW3520XP1 Microwaves*
Whirlpool MW3520XP2 Microwaves*
Whirlpool MW3520XP3 Microwaves*
Whirlpool MW352EXP1 Microwaves*
Whirlpool MW3600XS0 Microwaves*
Whirlpool MW3600XW0 Microwaves*
Whirlpool MW3600XW1 Microwaves*
Whirlpool MW3601XS0 Microwaves*
Whirlpool MW3601XW0 Microwaves*
Whirlpool MW3601XW1 Microwaves*
Amana MW41 MWAVE- CNTRTP / STAND ALONE
Amana MW42 MWAVE- CNTRTP / STAND ALONE
Amana MW43 MWAVE- CNTRTP / STAND ALONE
Amana MW500.000 COMMERCIAL MICROWAVES
 MW5380W MWAVE- CNTRTP / STAND ALONE
Roper MW557 Microwave
Roper MW5571 Microwaves
 MW5592W MWAVE- CNTRTP / STAND ALONE
 MW5592W/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW56 MWAVE- CNTRTP / STAND ALONE
Amana MW57 MWAVE- CNTRTP / STAND ALONE
Amana MW58 MWAVE- CNTRTP / STAND ALONE
Amana MW600.000 COMMERCIAL MICROWAVES
 MW640BA MWAVE- CNTRTP / STAND ALONE
 MW640WA MWAVE- CNTRTP / STAND ALONE
Amana MW700.000 COMMERCIAL MICROWAVES
Amana MW72 MWAVE- CNTRTP / STAND ALONE
 MW730BB MWAVE- CNTRTP / STAND ALONE
 MW735WB MWAVE- CNTRTP / STAND ALONE
 MW735WB/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW7400XW0 Microwaves*
Whirlpool MW7500XW0 Microwaves*
 MW7695GS MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8100XL0 MICROWAVE
Whirlpool MW8100XL1 MICROWAVE
Whirlpool MW8100XL2 MICROWAVE
Whirlpool MW8100XP0 MICROWAVE
Whirlpool MW8100XR0 MICROWAVE
Whirlpool MW8200XL0 Microwaves*
Whirlpool MW8200XL1 Microwaves*
Whirlpool MW8200XL2 Microwaves*
Whirlpool MW8200XP0 Microwaves*
Whirlpool MW8200XR0 Microwaves*
Whirlpool MW8300XL0 Microwaves*
Whirlpool MW8300XL2 Microwaves*
Whirlpool MW8300XP0 Microwaves*
 MW830BA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW830EXP0 Microwaves*
 MW830WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8400XL0 Microwaves*
Whirlpool MW8400XL2 Microwaves*
Whirlpool MW8400XR0 Microwaves*
Whirlpool MW8400XS0 Microwaves*
Whirlpool MW8400XS1 Microwaves*
Whirlpool MW8400XS2 Microwaves*
Whirlpool MW8400XW0 Microwaves*
 MW840BC MWAVE- CNTRTP / STAND ALONE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge washer makes loud noise while washing help tiffany w Washer Repair 10 01-24-2018 04:50 PM
Washing Machine - loud noise when aggitate. km7288 Washer Repair 1 06-25-2014 01:53 AM
Washing machine loud noise then stops in cycle Bridgetz4 Washer Repair 0 12-17-2013 06:30 PM
Washing Machine Loud Noise greekguy7 Washer Repair 1 03-27-2012 02:27 PM
ge washer makes loud grinding noise while washing ruthmccoy Washer Repair 0 04-25-2010 09:44 AM
