Discuss
Fill valve cycles on and off causing hammering in pipes
 in
Washer Repair
Hi When you start a cycle the water fill valve opens and closes repeatedly at about one second interval. On
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Fill valve cycles on and off causing hammering in pipes
  #1 (permalink)
Old 03-30-2017, 03:16 PM
Junior Member
apeck is on a distinguished road
Default Fill valve cycles on and off causing hammering in pipes
Model Number: WTW5700SW0   Brand: Whirlpool   Age: 5 - 10 years
Hi
When you start a cycle the water fill valve opens and closes repeatedly at about one second interval. On off on off, etc. Eventually the machine fills to the correct level and runs normally.
This caused hammering in the pipes so I put hammer arrestors on the hoses into the washer.
replaced the water fill valve, same problem, even slightly worse.
Checked fill switch, it is functioning normally
Tried bypassing lid switch, no effect.
Changing the temp select switch does route the power for hot or cold or both but then just the one solenoid goes on and off.
Running out of ideas and don't want to keep buying parts just to try and see if it works. Anyone seen this before? I have never.
THanks
Andrew
Related Models
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Whirlpool WTW6600SG2 AUTOMATIC WASHER
Whirlpool WTW6600SG3 AUTOMATIC WASHER
Whirlpool WTW6600SW0 AUTOMATIC WASHER
Whirlpool WTW6600SW1 AUTOMATIC WASHER
Whirlpool WTW6600SW2 AUTOMATIC WASHER
Whirlpool WTW6600SW3 AUTOMATIC WASHER
Whirlpool WTW6700TU1 AUTOMATIC WASHER
Whirlpool WTW6700TU2 AUTOMATIC WASHER
Whirlpool WTW6700TW0 AUTOMATIC WASHER
Whirlpool WTW6700TW1 AUTOMATIC WASHER
Whirlpool WTW6700TW2 AUTOMATIC WASHER
Whirlpool WTW6800WB1 AUTOMATIC WASHER
Whirlpool WTW6800WE1 RESIDENTIAL WASHER
Whirlpool WTW6800WL1 AUTOMATIC WASHER
Whirlpool WTW6800WU1 RESIDENTIAL WASHER
Whirlpool WTW6800WW1 AUTOMATIC WASHER
Whirlpool WTW7300XW0 AUTOMATIC WASHER
Whirlpool WTW7300XW1 AUTOMATIC WASHER
Whirlpool WTW7300XW2 AUTOMATIC WASHER
Whirlpool WTW7320YW0 WASHER
Whirlpool WTW7340XW0 AUTOMATIC WASHER
Whirlpool WTW7340XW1 AUTOMATIC WASHER
Whirlpool WTW7340XW2 AUTOMATIC WASHER
Whirlpool WTW7600XW0 AUTOMATIC WASHER
Whirlpool WTW7600XW1 AUTOMATIC WASHER
Whirlpool WTW7600XW2 AUTOMATIC WASHER
Whirlpool WTW7800XB0 AUTOMATIC WASHER
Whirlpool WTW7800XB1 AUTOMATIC WASHER
Whirlpool WTW7800XB2 AUTOMATIC WASHER
Whirlpool WTW7800XB3 AUTOMATIC WASHER
Whirlpool WTW7800XB4 AUTOMATIC WASHER
Whirlpool WTW7800XL0 AUTOMATIC WASHER
Whirlpool WTW7800XL1 AUTOMATIC WASHER
Whirlpool WTW7800XL2 AUTOMATIC WASHER
Whirlpool WTW7800XL3 AUTOMATIC WASHER
Whirlpool WTW7800XL4 AUTOMATIC WASHER
Whirlpool WTW7800XW0 AUTOMATIC WASHER
Whirlpool WTW7800XW1 AUTOMATIC WASHER
Whirlpool WTW7800XW2 AUTOMATIC WASHER
Whirlpool WTW7800XW3 AUTOMATIC WASHER
Whirlpool WTW7800XW4 AUTOMATIC WASHER
Whirlpool WTW7990XG0 AUTOMATIC WASHER
Whirlpool WTW7990XG1 AUTOMATIC WASHER
Whirlpool WTW8200YW0 AUTOMATIC WASHER
Whirlpool WTW8240YW0 AUTOMATIC WASHER
Whirlpool WTW8600YW0 AUTOMATIC WASHER
Whirlpool WTW8800YC0 WASHER
Whirlpool WTW8800YW0 WASHER
Bosch WTZ1170
Bosch WTZ1210
Roper WU0800B UNDERCOUNTER DISHWASHER
Roper WU0800XX0 Dishwasher
Roper WU0800XX1 UNDERCOUNTER DISHWASHER
Maytag WU100 DISHWASHER- UNDERCOUNTER
Maytag WU1000 DISHWASHER- UNDERCOUNTER
Roper WU1000X0 Dishwasher
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch groan/squeak noise during fill cycles. Valve? Ricehead Dishwasher Repair 0 11-04-2016 07:51 PM
adding water to fill cycles to diagnose fill valve tsquilanti Dishwasher Repair 0 05-16-2014 10:32 AM
Washer will not fill after replacing fill valve toddf Washer Repair 1 12-03-2010 01:39 PM
washer will not fill or go through cycles allen9258 Washer Repair 6 04-15-2009 08:14 AM
wont fill is it the fill valve acman727 Dishwasher Repair 1 03-14-2009 05:40 PM
