Discuss
Whirlpool does not fill with water; new inlet valve makes clicking sound
 in
Washer Repair
Hello, I hope that one of you experts can help me diagnose this issue. I am a newbie. I took
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool does not fill with water; new inlet valve makes clicking sound
  #1 (permalink)
Old 03-30-2017, 10:42 AM
Junior Member
jpg90 is on a distinguished road
Question Whirlpool does not fill with water; new inlet valve makes clicking sound
Model Number: WTW5590VQ1   Brand: Whirlpool   Age: More than 10 years
Hello,
I hope that one of you experts can help me diagnose this issue. I am a newbie. I took the time to record and edit a video that describes the problem fairly well, using captions. It is only 1:15 in duration. You can view it on YouTube, by clicking on this link:
YouTube video describing problem - click here
Current Symptoms:
  1. When temperature selector is set to HOT, only a little spurt of water comes in, and I hear a clicking noise coming from water inlet valve. It sounds like an old reel-to-reel movie projector.
  2. When temperature selector is set to COLD, no water comes in (or very little if there was some already in the compartment), and I do not hear a noise coming from water inlet valve.
Specifications:
  • Whirlpool Model = WTW5590VQ1.
  • Part number of new water inlet installed = W10144820.
Background Info:
  • A single valve shuts off supply to both hot and cold water hoses; this can be seen in the video.
  • Water pressure from the supply and through the hoses is excellent.
  • I bought and installed a new water inlet valve after a second incident of water overflowing the tub and leaking on the floor. Water would drip into the basket even when it was turned off, and would almost fill up the tub overnight. The first time this happened, I bought myself some time by ensuring / requesting that the valve to supply was in the off position when it was not being used.
  • After installing the new water inlet valve, the situation improved as follows: I could leave the water supply in the ON position, and water did not leak / drip into the basket overnight.
  • I did not try to let the washer continue on to the next phase of the cycle.
Questions:
  1. How can I test whether or not the new water inlet valve is defective, at least from an electrical perspective? All videos and instructions I have found online are for valves for which it appears to be easy to apply multi-meter test leads, that look similar to this:
    However, I cannot figure out how to do it with mine, which looks like this (see attached image please)
  2. Can you please provide other troubleshooting steps? I do not want to spend more money as things are tight financially.
Thank you so much for any and every tip. Much appreciated!
Best,
JPG.
Related Models
Whirlpool WTW5590VQ1 AUTOMATIC WASHER
Whirlpool WTW5600SQ0 AUTOMATIC WASHER
Whirlpool WTW5600VQ0 AUTOMATIC WASHER
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Whirlpool WTW6600SG2 AUTOMATIC WASHER
Whirlpool WTW6600SG3 AUTOMATIC WASHER
Whirlpool WTW6600SW0 AUTOMATIC WASHER
Whirlpool WTW6600SW1 AUTOMATIC WASHER
Whirlpool WTW6600SW2 AUTOMATIC WASHER
Whirlpool WTW6600SW3 AUTOMATIC WASHER
Whirlpool WTW6700TU1 AUTOMATIC WASHER
Whirlpool WTW6700TU2 AUTOMATIC WASHER
Whirlpool WTW6700TW0 AUTOMATIC WASHER
Whirlpool WTW6700TW1 AUTOMATIC WASHER
Whirlpool WTW6700TW2 AUTOMATIC WASHER
Whirlpool WTW6800WB1 AUTOMATIC WASHER
Whirlpool WTW6800WE1 RESIDENTIAL WASHER
Whirlpool WTW6800WL1 AUTOMATIC WASHER
Whirlpool WTW6800WU1 RESIDENTIAL WASHER
Whirlpool WTW6800WW1 AUTOMATIC WASHER
Whirlpool WTW7300XW0 AUTOMATIC WASHER
Whirlpool WTW7300XW1 AUTOMATIC WASHER
Whirlpool WTW7300XW2 AUTOMATIC WASHER
Whirlpool WTW7320YW0 WASHER
Whirlpool WTW7340XW0 AUTOMATIC WASHER
Whirlpool WTW7340XW1 AUTOMATIC WASHER
Whirlpool WTW7340XW2 AUTOMATIC WASHER
Whirlpool WTW7600XW0 AUTOMATIC WASHER
Whirlpool WTW7600XW1 AUTOMATIC WASHER
Whirlpool WTW7600XW2 AUTOMATIC WASHER
Whirlpool WTW7800XB0 AUTOMATIC WASHER
Whirlpool WTW7800XB1 AUTOMATIC WASHER
Whirlpool WTW7800XB2 AUTOMATIC WASHER
Whirlpool WTW7800XB3 AUTOMATIC WASHER
Whirlpool WTW7800XB4 AUTOMATIC WASHER
Whirlpool WTW7800XL0 AUTOMATIC WASHER
Whirlpool WTW7800XL1 AUTOMATIC WASHER
Whirlpool WTW7800XL2 AUTOMATIC WASHER
Whirlpool WTW7800XL3 AUTOMATIC WASHER
Whirlpool WTW7800XL4 AUTOMATIC WASHER
Whirlpool WTW7800XW0 AUTOMATIC WASHER
Whirlpool WTW7800XW1 AUTOMATIC WASHER
Whirlpool WTW7800XW2 AUTOMATIC WASHER
Whirlpool WTW7800XW3 AUTOMATIC WASHER
Whirlpool WTW7800XW4 AUTOMATIC WASHER
Whirlpool WTW7990XG0 AUTOMATIC WASHER
Whirlpool WTW7990XG1 AUTOMATIC WASHER
Whirlpool WTW8200YW0 AUTOMATIC WASHER
  #2 (permalink)
Old 03-31-2017, 07:55 AM
Junior Member
apeck is on a distinguished road
Default Similar problem with whirlpool washer uses same fill valve
HI;
Just posted a similar problem. I also changed the fill valve with no result. Your overfilling issue suggest the water pressure switch occasional malfunction as it shuts off the valve and triggers the wash cycle. My washer has not overflowed and the switch seems to be working. Maybe the diaphragm could 'flutter' and cause power to go on and off rapidly? Not sure and it is a $100 part to buy just to see if that is the issue.
I am looking at the ATC switch ($50) and may replace it. If this works will let you know, am trying to find instructions on testing the switch first.
Andrew
  #3 (permalink)
Old 04-01-2017, 03:26 PM
Junior Member
Default Thanks - some follow up questions
Hi Andrew,
Thanks so much for your reply. Do you have experience working with this kind of stuff? I don't.
Regarding:
Quote:
Originally Posted by apeck View Post
HI;
I just read it. At first glance it does not seem to be the same issue I am experiencing due to the fact that your pipes are hammering, and that your washer eventually fills with water.
I've not let the clicking / ticking sound coming from the inlet valve continue for more than 30 - 60 seconds. Would it be worth to let it run for a few minutes to see what would happen, or would that risk breaking something?
Regarding:
It does not overfill any more after replacing the water inlet valve. In fact, only a little bit of water comes out, and only when selecting hot water. No water comes out (practically) when selecting cold water.
I tested the water pressure switch for continuity and it passed, and it seems like the circuit opened when I blew on the other end of the hose, and closed back up when I was done. So it seems to be behaving correctly, right? What do you think?
Regarding:
Andrew
A few hours ago I had a neighbor come over who is an electrical / electronics technician. I asked how I could test the water temperature switch and he said it did not seem possible with a simple multi-meter (then started explaining something about the changing of the shape of the waves and completely lost me). Have you found instructions?
Thanks,
JPG.
  #4 (permalink)
Old 04-01-2017, 08:53 PM
Junior Member
Default Sounds like the ATC Switch
I bypassed my ATC switch and the washer filled and cycled normally. I have set it to fill with warm water on every fill. Both valves open and stay open till the fill setting is reached, no on/off stuttering or any other repetitive noises.
Am going to order the replacement ATC switch and see if that restores temp selectability.
Hope that helps.
Did you already open your console? If so did you find a circuit diagram? Send me a scan of the diagram and I will tell you which wires to jump to bypass your ATC switch.
Andrew
  #5 (permalink)
Old 04-01-2017, 09:05 PM
Junior Member
Default How?
I bypassed my ATC switch ...
Andrew
How did you do it? There's like 7 or 8 wires going into mine. Is there an online video that shows how?
  #6 (permalink)
Old 04-01-2017, 10:18 PM
Junior Member
Default
There was a circuit diagram under the console when I opened it. It gave me me the correct wire colours to jump to enable both hot and cold valves. Your machine should have one or it should be available online. Easy test to do once you know which wires.
A.
  #7 (permalink)
Old 04-01-2017, 10:22 PM
Junior Member
Default
Just watched your video, my problem is almost exactly the same.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool oven igniter makes clicking sound but no spark Jander605 Oven Repair (including Ranges and Cooktops) 0 11-30-2016 10:19 PM
Whirlpool makes clicking sound top center when on rookiefixer Microwave Repair 0 01-16-2012 09:03 AM
Whirlpool Water Inlet Valve Paulus Refrigerator & Freezer Repair 6 05-31-2011 04:37 PM
Whirlpool spins slow and makes clicking sound seynett Washer Repair 8 11-17-2009 03:45 PM
Whirlpool inlet water valve leaking booney3us Refrigerator & Freezer Repair 2 03-16-2009 11:02 AM
