Have Frigidaire Affinity washer FAFW3577KA1 which starts to fill washer with water at onset but stops after approximately 5 seconds. The timer appears to eventually continue the count down while this is happening but no further progress with operation. Sometimes the machine will timeout and shut off and other times it just sits with the display lit up. Only error code noticed was E38 but can't find this code in the error lists I've seen. Whenever I am lucky enough to finally get the machine to operate again by cancelling and restarting, the following washing loads that day appear to operate normally although one time the the clothes were wetter than normal when removed.
