Discuss
Won't drain,rinse or spin.
 in
Washer Repair
My machine started washing normally but, when it came time to drain..it didn't. Now, the only cycle that works is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Won't drain,rinse or spin.
  #1 (permalink)
Old 03-25-2017, 07:46 AM
Junior Member
dertikop is on a distinguished road
Default Won't drain,rinse or spin.
Model Number: LHW0050PQ4   Brand: Whirlpool   Age: More than 10 years
My machine started washing normally but, when it came time to drain..it didn't. Now, the only cycle that works is the wash cycle. Won't drain, rinse or spin. What, short of buying a new one, should I be looking at? Thx!
Related Models
Whirlpool LHW0050PQ4 COMPACT AUTOMATIC WASHER
General Electric LISR310CW0WW Washer
General Electric LISR310CW1WW Washer
Whirlpool LJD1306LQ0
Whirlpool LJD1306LT0
Bosch LK100-010
Bosch LK100-020
Bosch LK100-110
Bosch LK100-120
Bosch LK320-010
Bosch LK320-020
Bosch LK320-030
Bosch LK400-010
Bosch LK400-020
Bosch LK400-030
Amana LKG-170 ROOM AIR CONDITIONER
Amana LKG-171 ROOM AIR CONDITIONER
Amana LKG-240 ROOM AIR CONDITIONER
Amana LKG-240H ROOM AIR CONDITIONER
Amana LKG-241 ROOM AIR CONDITIONER
Amana LKG-241H ROOM AIR CONDITIONER
Amana LKG-300 ROOM AIR CONDITIONER
Amana LKG-300H ROOM AIR CONDITIONER
Amana LKG-340 ROOM AIR CONDITIONER
Amana LKG-340HE ROOM AIR CONDITIONER
Amana LKG-341 ROOM AIR CONDITIONER
Amana LKG-470 ROOM AIR CONDITIONER
Amana LKG-470HE ROOM AIR CONDITIONER
Amana LKG-471 ROOM AIR CONDITIONER
Amana LKG-471HE ROOM AIR CONDITIONER
Amana LKG-621 ROOM AIR CONDITIONER
Amana LKG601-617 ROOM AIR CONDITIONER
Amana LKG601H-617 ROOM AIR CONDITIONER
Amana LKI721 RANGE- F/S STD GAS
Amana LKU-617 RANGE- S/C S/I DDRAFT GAS
Amana LKU-617A RANGE- S/C S/I DDRAFT GAS
Bosch LL010-000
Whirlpool LLC7244AN0
Whirlpool LLC7244AQ0
Whirlpool LLC7244AW0
Whirlpool LLC7244AZ0
Whirlpool LLC7244BQ0
Whirlpool LLC7244BQ1
Whirlpool LLC7244BZ0
Whirlpool LLC7244BZ1
Whirlpool LLC8244DQ0
Whirlpool LLC8244DZ0
Whirlpool LLN8233BN0
Whirlpool LLN8233BN1
Whirlpool LLN8233BQ0
Whirlpool LLN8233BQ1
Whirlpool LLN8233BW0
Whirlpool LLN8233BW1
Whirlpool LLN8244AN0
Whirlpool LLN8244AW0
Whirlpool LLN8244BN0
Whirlpool LLN8244BW0
Admiral LLR1100AJQ RANGE- F/S STD GAS
Admiral LLR1100AJW RANGE- F/S STD GAS
Admiral LLR1415AJS RANGE- F/S STD GAS
Admiral LLR1415AJW RANGE- F/S STD GAS
Admiral LLR4451AJS RANGE- F/S STD GAS
Admiral LLR4451AJW RANGE- F/S STD GAS
Whirlpool LLR5144BQ0
Whirlpool LLR5144BQ1
Whirlpool LLR5144BW0
Whirlpool LLR6144AN0
Whirlpool LLR6144AQ0
Whirlpool LLR6144AW0
Whirlpool LLR6144BN0 WASHER
Whirlpool LLR6144BN1 AUTOMATIC WASHER
Whirlpool LLR6144BQ0 WASHER
Whirlpool LLR6144BQ1 AUTOMATIC WASHER
Whirlpool LLR6144BW0 WASHER
Whirlpool LLR6233AN0
Whirlpool LLR6233AN1
Whirlpool LLR6233AQ0
Whirlpool LLR6233AW0
Whirlpool LLR6233AW1
Whirlpool LLR7144DQ0
Whirlpool LLR7144DW0
Whirlpool LLR7144DZ0
Whirlpool LLR8233BN0 AUTOMATIC WASHER
Whirlpool LLR8233BN1 AUTOMATIC WASHER
Whirlpool LLR8233BQ0 AUTOMATIC WASHER
Whirlpool LLR8233BQ1 AUTOMATIC WASHER
Whirlpool LLR8233BW0 AUTOMATIC WASHER
Whirlpool LLR8233BW1 AUTOMATIC WASHER
Whirlpool LLR8233DQ0 AUTOMATIC WASHER
Whirlpool LLR8233DW0 AUTOMATIC WASHER
Whirlpool LLR8233DZ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ1 DIRECT-DRIVE WASHER
Whirlpool LLR8233EZ0 AUTOMATIC WASHER
Whirlpool LLR8233EZ1 DIRECT-DRIVE WASHER
Whirlpool LLR8245AW0 Washers
Whirlpool LLR8245BN0 AUTOMATIC WASHER
Whirlpool LLR8245BN1 AUTOMATIC WASHER
Whirlpool LLR8245BW0 AUTOMATIC WASHER
Whirlpool LLR8245BW1 AUTOMATIC WASHER
Whirlpool LLR8245DQ0 AUTOMATIC WASHER
Whirlpool LLR8245DZ0 AUTOMATIC WASHER
Whirlpool LLR9245AQ0
Whirlpool LLR9245BQ0
Whirlpool LLR9245BQ1 WASHERS DIRECT-DRIVE
Whirlpool LLR9245DQ0
Whirlpool LLR9245DQO WHIRLPOOL WASHER
Whirlpool LLR9245DZ0
Whirlpool LLR9245DZO WHIRLPOOL WASHER
Whirlpool LLT7144AN0 Washers*
Whirlpool LLT7144BN0
Whirlpool LLT7144BQ0
Whirlpool LLT7144BQ1
Whirlpool LLT7144BW0
Whirlpool LLT7144DQ0
Whirlpool LLT8233AN0
Whirlpool LLT8233AQ0
Whirlpool LLT8233AW0
Whirlpool LLT8233AW1 AUTOMATIC WASHER
Whirlpool LLT8233AW2
  #2 (permalink)
Old 03-26-2017, 12:26 PM
Junior Member
manfred63 is on a distinguished road
Default
If it just stops after the wash, it may have a blockage in the hoses or pump keeping the water from draining. Or, the pump its self could be bad. If there is a drain pump filter, try cleaning it out, it could be full of foreign objects, coins, etc. blocking it up.
Last edited by manfred63 : 03-26-2017 at 12:31 PM. Reason: Front load washer instead of top load instructions.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer not drain,rinse and spin simply Washer Repair 1 08-24-2012 07:24 PM
won't rinse, spin or drain dangie Washer Repair 2 06-19-2012 07:55 AM
washer won't spin, drain, or rinse crystal adkins Washer Repair 3 10-02-2011 06:33 AM
No spin, drain or rinse in washer budkoc Washer Repair 1 12-06-2010 07:30 AM
HELP: wash cycles won't drain/spin, manual rinse/drain works, manual drain/spin works cosmo99 Washer Repair 1 01-27-2010 12:33 PM
