Discuss
Troubleshooting help before I order parts
 in
Washer Repair
Hello everyone. My roommate is moving out in May and is taking the washer, so I was looking for used
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Troubleshooting help before I order parts
  #1 (permalink)
Old 03-16-2017, 09:40 PM
Junior Member
GoogleAndroid is on a distinguished road
Question Troubleshooting help before I order parts
Model Number: WA456DRHDSU/AA   Brand: Samsung   Age: 1 - 5 years
Hello everyone. My roommate is moving out in May and is taking the washer, so I was looking for used ones. One posted to Facebook, the Samsung washer listed, for very cheap so I snatched it up. I was a little suspicious getting as new and nice of a washer as I did for as little as I paid, but I took the risk. I tried it out today and it has some problems.
The washer does not know when to stop filling. It will fill up until it throws an NF error code(which is the result of taking too long to fill), and if I continue the cycle, it eventually fills the entire drum until water begins spilling out of the sides. The first thing I read to test was the water inlet valve, so I unplugged the washer while it was filling. The water stopped as it should so I know the water inlet valve is functioning. Then I took the back apart and saw that the water pressure sensor hose was disconnected from the bottom of the drum. I reconnected it, tried again, and it did the same thing. So, I took the whole sensor out, cleaned the hose and checked for leaks clogs and kinks, and tested that the sensor moves as it should. I put it all back together and it still overfills.
I would suspect that it is the water pressure sensor, but one thing makes me question that. I noticed that the cold and hot water are reversed, even though the hoses are definitely in correct locations. If I use tap cold, the water is tap cold. Yet using the cold setting gives me hot water, and the hot setting gives cold water. I would think that if the hoses were internally reversed, using the tap cold setting would also give hot water. I will test this again to be sure, and perhaps take it apart again and see if the internal hoses are reversed.
So, I am at a loss of what to do. Part of me wants to try to sell it and recoup my costs, but I'm not sure how easy that will be considering the issue. Then there is the part of me that wants to try to fix it and hopefully get it working and keep it. Could the hot and cold reversal mean that the water inlet valve is broken and causing the overfill, even though it stops when power is removed? Is it just that the pressure sensor needs replaced? Or could it be something more serious, like the main PCB?
Related Models
Frigidaire WA4720RW1 Frg(v1) / 27 " Washer
Frigidaire WA4720RW2 Frg(v1) / 27 " Washer
Frigidaire WA4900ADD1 Frg(v2) / 27 " Washer
Frigidaire WA4900ADD2 Frg(v2) / 27 " Washer
Frigidaire WA4900ADD3 Frg(v2) / 27 " Washer
Frigidaire WA4900AWW1 Frg(v1) / 27 " Washer
Frigidaire WA4900AWW2 Frg(v1) / 27 " Washer
Frigidaire WA4900AWW3 Frg(v3) / 27 " Washer
Frigidaire WA4900RW1 Frg(v1) / 27 " Washer
Frigidaire WA5800ADD1 Frg(v4) / 27 " Washer
Frigidaire WA5800ADD2 Frg(v4) / 27 " Washer
Frigidaire WA5800ADD3 Frg(v1) / 27 " Washer
Frigidaire WA5800AWW1 Frg(v3) / 27 " Washer
Frigidaire WA5800AWW2 Frg(v3) / 27 " Washer
Frigidaire WA5800AWW3 Frg(v2) / 27 " Washer
Frigidaire WA5800RW1 Frg(v2) / 27 " Washer
Frigidaire WA5820RW1 Frg(v1) / 27 " Washer
Frigidaire WA5820RW2 Frg(v1) / 27 " Washer
Frigidaire WA6500ADD1 Frg(v2) / 27 " Washer
Frigidaire WA6500ADD2 Frg(v2) / 27 " Washer
Frigidaire WA6500ADD3 Frg(v3) / 27 " Washer
Frigidaire WA6500AWW1 Frg(v1) / 27 " Washer
Frigidaire WA6500AWW2 Frg(v1) / 27 " Washer
Frigidaire WA6500AWW3 Frg(v4) / 27 " Washer
Frigidaire WA6520AL1 Frg(v2) / 27 " Washer
Frigidaire WA6520AL2 Frg(v2) / 27 " Washer
Frigidaire WA6520AW1 Frg(v1) / 27 " Washer
Frigidaire WA6520AW2 Frg(v1) / 27 " Washer
Frigidaire WA6620RW1 Frg(v1) / 27 " Washer
Frigidaire WA6620RW2 Frg(v1) / 27 " Washer
Frigidaire WA6900RW1 Frg(v3) / 27 " Washer
Frigidaire WA7200ADD1 Frg(v2) / 27 " Washer
Frigidaire WA7200ADD2 Frg(v2) / 27 " Washer
Frigidaire WA7200ADD3 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW1 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW2 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW3 Frg(v2) / 27 " Washer
Frigidaire WA7400PW0 Frg(v1) / 27 " Washer
Frigidaire WA7400PW1 Frg(v1) / 27 " Washer
Frigidaire WA7400PW2 Frg(v2) / 27 " Washer
Frigidaire WA8600PW0 Frg(v1) / 27 " Washer
Frigidaire WA8600PW1 Frg(v1) / 27 " Washer
Frigidaire WA8600PW2 Frg(v2) / 27 " Washer
Frigidaire WA8800PW0 Frg(v1) / 27 " Washer
Frigidaire WA8800PW1 Frg(v1) / 27 " Washer
Frigidaire WA8800PW2 Frg(v2) / 27 " Washer
Frigidaire WAA053M7A1 White Westinghouse Air Conditioner
White Westinghouse WAA060M7C1 White Westinghouse/air Conditioner
Frigidaire WAB057P7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067F7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAB067F7B2 Wwh(v0) / Room Air Conditioner
Frigidaire WAB067P7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067T7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067W7B1 Wwh(v0) / Air Conditioner
Frigidaire WAB077F7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAB077F7B3 Wwh(v0) / Room Air Conditioner
Frigidaire WAB077S7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB077Y7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAC051P7Z1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC051P7Z2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC051T7Z1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC051T7Z2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC051T7Z2A Wwh(v0) / Room Air Conditioner
Frigidaire WAC051T7Z2B Wwh(v0) / Room Air Conditioner
Frigidaire WAC051T7Z5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052G7A1 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052G7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052G7A3 Wwh(v0) / Room Air Conditioner
White Westinghouse WAC052K7A1 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A2 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A4 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A6 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A7 White Westinghouse/air Conditioner
Frigidaire WAC052P7A1 Wwh(v2) / Room Air Conditioner
Frigidaire WAC052T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC052T7A2A Wwh(v0) / Room Air Conditioner
Frigidaire WAC052T7A2B Wwh(v0) / Room Air Conditioner
Frigidaire WAC052T7A3 Wwh(v2) / Room Air Conditioner
Frigidaire WAC052T7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052T7A6 Wwh(v0) / Air Conditioner
White Westinghouse WAC053K7A1 White Westinghouse/air Conditioner
White Westinghouse WAC053L7A1 White Westinghouse/air Conditioner
Frigidaire WAC053S7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053S7A4 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A2A Wwh(v0) / Room Air Conditioner
Frigidaire WAC053T7A3 Wwh(v2) / Room Air Conditioner
Frigidaire WAC053T7A4 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A5 Wwh(v2) / Room Air Conditioner
Frigidaire WAC053T7A6 Wwh(v2) / Room Air Conditioner
Frigidaire WAC056F7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC056P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC056P7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC056T7A1 Wwh(v3) / Room Air Conditioner
Frigidaire WAC056W7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC056W7A5A Wwh(v0) / Room Air Conditioner
White Westinghouse WAC060K7A1 White Westinghouse/air Conditioner
Frigidaire WAC060K7A2
White Westinghouse WAC061L7A1 White Westinghouse/air Conditioner
Frigidaire WAC062P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063S7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063S7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063T7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC063T7A5A Wwh(v0) / Room Air Conditioner
Frigidaire WAC066F7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC066F7A3 Wwh(v0) / Room Air Conditioner
Frigidaire WAC067P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC067P7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC067T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC067W7A1 Wwh(v0) / Room Air Conditioner
Frigidaire WAC067W7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC067W7A5A Wwh(v0) / Room Air Conditioner
Frigidaire WAC072P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073S7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073T7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073W7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073W7A5A Wwh(v0) / Room Air Conditioner
Frigidaire WAC077T7A2 Wwh(v2) / Room Air Conditioner
  #2 (permalink)
Old 03-22-2017, 06:08 PM
Junior Member
Default
Well I hadn't gotten a reply so I just ended up ordering the pressure fill sensor since it is cheap. It came in today, I swapped it out, and the washer seems to work just fine now. Wanted to update the thread in case anyone had similar problems in the future.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Parts to order? BethD Oven Repair (including Ranges and Cooktops) 1 03-12-2017 02:16 PM
Looking for a Bosch troubleshooting/parts manual/list cil Dishwasher Repair 1 04-22-2012 02:39 PM
what parts to order to replace 3rd level spinner jeff millstein Dishwasher Repair 0 10-12-2011 08:10 AM
Parts I need to order to stop a screeching noise... dasho Dryer Repair 0 07-18-2010 02:39 PM
Verify Correct Diagnosis so I can order correct parts JDW123 Dryer Repair 0 07-16-2010 01:59 PM
