Discuss
Burning smell and not pumping out completely - Whirlpool direct drive washer
 in
Washer Repair
I have an older Whirlpool direct drive washer, model LSR6132HQ1. For the past several weeks, it has had an issue
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Burning smell and not pumping out completely - Whirlpool direct drive washer
  #1 (permalink)
Old 03-16-2017, 07:56 AM
Junior Member
dwizum is on a distinguished road
Default Burning smell and not pumping out completely - Whirlpool direct drive washer
Model Number: LSR6132HQ1   Brand: Whirlpool   Age: More than 10 years
For the past several weeks, it has had an issue where it won't always pump all the water out at the end of a cycle. The clothes will be wet and there will be a few inches of water in the bottom of the unit. If I turn the knob to the very end of the cycle and cause it to repeat the spin cycle, it will eventually pump dry like it's supposed to.
Besides not pumping out all the water, there is sometimes a very faint burning smell. It's almost like a burning rubber smell, it doesn't smell like a burnt motor or electrical in nature.
Any ideas? I've replaced the little coupling piece several times, this doesn't seem like that's the issue. It does spin, and it does pump, it's just not pumping as well as it should.
If this had a drive belt on the pump, that would seem like the obvious issue. But it's direct drive. Any thoughts?
Related Models
Whirlpool LSR6132HQ1 AUTOMATIC WASHER
Whirlpool LSR6132HZ0 AUTOMATIC WASHER
Whirlpool LSR6232JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR6232JQ1 WASHER - DIRECT DRIVE
Whirlpool LSR6232JQ2 AUTOMATIC WASHER
Whirlpool LSR6233BG0 AUTOMATIC WASHER
Whirlpool LSR6233BN0 AUTOMATIC WASHER
Whirlpool LSR6233BN1 WASHER
Whirlpool LSR6233BW0 AUTOMATIC WASHER
Whirlpool LSR6233BW1 WASHER
Whirlpool LSR6233DN0 AUTOMATIC WASHER
Whirlpool LSR6233DW0 AUTOMATIC WASHER
Whirlpool LSR6244AW0 Washers*
Whirlpool LSR6332KQ0 WASHER
Whirlpool LSR6332KQ1 AUTOMATIC WASHER
Whirlpool LSR6334LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR6334LQ1 AUTOMATIC WASHER
Whirlpool LSR6335LQ0 WASHER - DIRECT DRIVE
Whirlpool LSR7010PQ0 AUTOMATIC WASHER
Whirlpool LSR7010PQ1 AUTOMATIC WASHER
Whirlpool LSR7010PQ2 AUTOMATIC WASHER
Whirlpool LSR7133KQ0 WASHER
Whirlpool LSR7133KQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ0 AUTOMATIC WASHER
Whirlpool LSR7133PQ1 AUTOMATIC WASHER
Whirlpool LSR7133PQ2 AUTOMATIC WASHER
Whirlpool LSR7200EQ0 AUTOMATIC WASHER
Whirlpool LSR7200EZ0 AUTOMATIC WASHER
Whirlpool LSR7233BG0
Whirlpool LSR7233BG1
Whirlpool LSR7233BG2
Whirlpool LSR7233BGO WASHER
Whirlpool LSR7233BN0
Whirlpool LSR7233BN1
Whirlpool LSR7233BN2
Whirlpool LSR7233BNO WASHER
Whirlpool LSR7233BQ0
Whirlpool LSR7233BQ1
Whirlpool LSR7233BQ2
Whirlpool LSR7233BQO WASHER
Whirlpool LSR7233BW0
Whirlpool LSR7233BW1
Whirlpool LSR7233BW2
Whirlpool LSR7233BWO WASHER
Whirlpool LSR7233BZ0
Whirlpool LSR7233BZ2
Whirlpool LSR7233DQ0 WASHER
Whirlpool LSR7233DQ1 AUTOMATIC WASHER
Whirlpool LSR7233DW0 WASHER
Whirlpool LSR7233DZ0 WASHER
Whirlpool LSR7233DZ1 AUTOMATIC WASHER
Whirlpool LSR7233EQ0 WASHER
Whirlpool LSR7233EQ1 AUTOMATIC WASHER
Whirlpool LSR7233EW0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ1 AUTOMATIC WASHER
Whirlpool LSR7233HQ0 AUTOMATIC WASHER
Whirlpool LSR7233HZ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ1 AUTOMATIC WASHER
Whirlpool LSR7300PQ2 AUTOMATIC WASHER
Whirlpool LSR7333PQ0 AUTOMATIC WASHER
Whirlpool LSR7333PQ1 AUTOMATIC WASHER
Whirlpool LSR7333PQ3 AUTOMATIC WASHER
Whirlpool LSR7333PQ4 AUTOMATIC WASHER
Whirlpool LSR8010PQ0 AUTOMATIC WASHER
Whirlpool LSR8010PQ1 AUTOMATIC WASHER
Whirlpool LSR8010PQ2 AUTOMATIC WASHER
Whirlpool LSR8010PT0 AUTOMATIC WASHER
Whirlpool LSR8010PT1 AUTOMATIC WASHER
Whirlpool LSR8010PT2 AUTOMATIC WASHER
Whirlpool LSR8133HQ0 AUTOMATIC WASHER
Whirlpool LSR8133HZ0 AUTOMATIC WASHER
Whirlpool LSR8200EQ0 AUTOMATIC WASHER
Whirlpool LSR8200EZ0 AUTOMATIC WASHER
Whirlpool LSR8233EQ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EQ1 AUTOMATIC WASHER
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JQ1 WASHER
Whirlpool LSR8233JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JT1 WASHER
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 AUTOMATIC WASHER
Whirlpool LSR9434PQ1 AUTOMATIC WASHER
Whirlpool LSR9434PQ3 AUTOMATIC WASHER
Whirlpool LSR9434PQ4 AUTOMATIC WASHER
Whirlpool LSR9434PT0 AUTOMATIC WASHER
Whirlpool LSR9434PT1 AUTOMATIC WASHER
Whirlpool LSR9434PT3 AUTOMATIC WASHER
Whirlpool LSR9434PT4 AUTOMATIC WASHER
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
  #2 (permalink)
Old 03-16-2017, 10:52 AM
Junior Member
jimctec is on a distinguished road
Default
Perhaps something is caught up in your pump and restricting the pumping action. This will cause heat and could melt your pump; have seen it happen.
  #3 (permalink)
Old 03-16-2017, 11:49 AM
Junior Member
Default
Could a worn clutch cause this? Does the clutch have anything to do with pumping, or just spinning?
  #4 (permalink)
Old 03-19-2017, 11:21 PM
Junior Member
manfred63 is on a distinguished road
Default
Quote:
The clutch has nothing to do with the draining, a worn clutch would just cause it to spin too slowly or not at all. Standing water at end of the cycle usually indicates a problem with the pump or the drain spout from the bottom of tub where the hose is attached being obstructed with an article of clothing. Remove the hoses from the pump, and remove it from the motor to look inside the pump for a sock or something. If it is clear, remove hose from bottom of tub to see if something is stuck there restricting the water flow.
You can look at the washer repair videos on my website and see an example of a sock stuck in a water pump on my video "Diagnose Washer that won't spin or drain, just hums"
Ken's Appliance Repair
  #5 (permalink)
Old 03-27-2017, 09:52 AM
Junior Member
Default
I was suspecting the clutch because it smells like... well, like a burnt clutch. Also, I'm wondering if the water in the bottom was due to incomplete/poor spin cycle, not poor pumping. The issue was sporadic, it was only happening maybe half the time.
At any rate, by the time I'd seen your post, I had already bought a new clutch and put it on. It doesn't seem to have happened since, but I've only had 3 loads through. If it continues to have a problem I will report back here, but for now I am going to assume this has fixed it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool direct drive washer won't spin sarcza Washer Repair 1 03-07-2012 12:40 PM
Spin problem with Whirlpool direct drive washer msvolkert Washer Repair 4 07-31-2010 06:54 AM
replacing drive coupleing on Whirlpool direct drive washer bbuck222 Washer Repair 2 08-06-2009 08:34 AM
Whirlpool Direct-Drive Washer Won't Run Dave Bishop Washer Repair 2 03-11-2009 09:40 AM
whirlpool direct drive washer will not agitate thyssen01 Washer Repair 1 03-05-2009 05:54 PM
