Discuss
GE Washer won't spin or agitate
 in
Washer Repair
GE Washer will fill and drain, but won't spin or agitate after a power outage. The power outage was not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer won't spin or agitate
  #1 (permalink)
Old 03-15-2017, 06:13 PM
Junior Member
mitchm527 is on a distinguished road
Default GE Washer won't spin or agitate
Model Number: WHDSR316G6WW   Brand: GE   Age: 5 - 10 years
GE Washer will fill and drain, but won't spin or agitate after a power outage. The power outage was not weather related, not sure what caused the outage. But once the power came back on, the washer has not worked since. No other electronics were damaged. I've tried resetting multiple times, with multiple methods - no luck.
I've checked the following:
-Lid switch is good.
-Inline fuse going to the motor is good.
-Belt is good. If I turn the motor by hand, the belt turns the tub without issue.
-Confirmed with my multimeter that the motor is getting power.
Here are my findings so far:
1)The light on my inverter board keeps blinking 1 second on/off - which indicates 'Normal Standby'. It does NOT switch to 0.5 second on/off (Normal Running) when it should be in spin cycle. That leads me to think it's not being told to go into spin cycle. So does that point me towards the timer?
2) My Mode Shifter Coil Plug (the Red and Yellow wires) only reads 65 Ohms, I've read on several threads now it should be 98 Ohms (at least for the GE models in those threads). Is this any indication of a bad Mode Shifter Coil? Would this cause my problem, if so?
3) The washer seems to try to drain for an exceptionally long time. Probably 5 minutes after all the water is gone, it's still trying to drain. And of course no spinning.
Please help!
Related Models
General Electric WHDSR316G6WW WASHER
General Electric WHDSR417D0WW Washer
General Electric WHDSR417D5WW Washer
General Electric WHDVH626F0GG Washer
General Electric WHDVH626F0WW Washer
General Electric WHDVH626H1GG WASHER
General Electric WHDVH626H1WW WASHER
General Electric WHDVH660H0BB Washer
General Electric WHDVH660H0GG Washer
General Electric WHDVH660H0MB WASHER
General Electric WHDVH660H0MS WASHER
General Electric WHDVH660H0WW Washer
General Electric WHDVH660H1BB WASHER
General Electric WHDVH660H1GG WASHER
General Electric WHDVH660H1MB WASHER
General Electric WHDVH660H1MS WASHER
General Electric WHDVH660H1WW WASHER
General Electric WHDVH680J0BB WASHER
General Electric WHDVH680J0GG WASHER
General Electric WHDVH680J0MB WASHER
General Electric WHDVH680J0MR WASHER
General Electric WHDVH680J0MS WASHER
General Electric WHDVH680J0WW WASHER
General Electric WHDVH680J1MR WASHER
General Electric WHDVH680J1MS WASHER
General Electric WHDVH680J1WW WASHER
Whirlpool WHE33311 30" Electric Range
Whirlpool WHE383311 30" ELECTRIC RANGE COOKTOP
Whirlpool WHP1000SB1 PEDESTAL
Whirlpool WHP1000SK0 PEDESTAL
Whirlpool WHP1000SK1 PEDESTAL
Whirlpool WHP1000SL0 PEDESTAL
Whirlpool WHP1000SL1 PEDESTAL
Whirlpool WHP1000SQ0 PEDESTAL
Whirlpool WHP1000SQ1 PEDESTAL
Whirlpool WHP1000ST0 PEDESTAL
Whirlpool WHP1000ST1 PEDESTAL
Whirlpool WHP1000SU1 PEDESTAL
Whirlpool WHP1500SA0 PEDESTAL
Maytag WHP1500SA1 PEDESTAL
Whirlpool WHP1500SB0 PEDESTAL
Maytag WHP1500SB1 PEDESTAL
Whirlpool WHP1500SC0 PEDESTAL
Maytag WHP1500SC1 PEDESTAL
Whirlpool WHP1500SL0 PEDESTAL
Maytag WHP1500SL1 PEDESTAL
Whirlpool WHP1500SQ0 PEDESTAL
Maytag WHP1500SQ1 PEDESTAL
Whirlpool WHP1500ST0 PEDESTAL
Maytag WHP1500ST1 PEDESTAL
Whirlpool WHP1500SU0 PEDESTAL
Maytag WHP1500SU1 PEDESTAL
Whirlpool WHP32812 30" Electric Range Self Clean Oven
Whirlpool WHP54802 30" Electric Range Self Clean Oven
Whirlpool WHP54803 30" Electric Range Self Clean Oven
Whirlpool WHP83812 30" ELECTRIC RANGE CERAN COOKTOP SELF CLEAN
General Electric WHRE5260E0CC Washer
General Electric WHRE5260E0WW Washer
General Electric WHRE5260E1CC Washer
General Electric WHRE5260E1WW Washer
General Electric WHRE5260E6CC Washer
General Electric WHRE5260E6WW Washer
General Electric WHRE5550H0WW WASHER
General Electric WHRE5550H1WW WASHER
General Electric WHRE5550H2WW WASHER
General Electric WHRE5550K0WW WASHER
General Electric WHRE5550K1WW WASHER
General Electric WHRE5550K2WW WASHER
General Electric WHRE5550K3WW WASHER
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Frigidaire WIMH3 Frg(v17) / Washer
Frigidaire WIML1 Frg(v22) / Washer
Frigidaire WIML2 Frg(v23) / Washer
Frigidaire WIML3 Frg(v18) / Washer
Frigidaire WIMW1 Frg(v24) / Washer
Frigidaire WIMW2 Frg(v25) / Washer
Frigidaire WIMW3 Frg(v19) / Washer
Frigidaire WISCL2 Frg(v3) / Washer
Frigidaire WISCL3 Frg(v3) / Washer
Frigidaire WISCL5 Frg(v3) / Top Loading Washer
Frigidaire WISCL6 Frg(v4) / Top Load Washer
Frigidaire WISCLL0 Frg(v4) / 27 " Washer
Frigidaire WISCLL1 Frg(v6) / 27 " Washer
Frigidaire WISCLL2 Frg(v2) / 27 " Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will spin but not agitate Abby12 Washer Repair 6 11-13-2013 02:09 PM
Washer will not agitate, but will spin stejon12 Washer Repair 2 09-13-2013 05:12 PM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 11:13 AM
Washer will agitate but not spin/spin slowly sainthooligan Washer Repair 11 07-24-2010 11:34 AM
washer will not spin or agitate nate Washer Repair 0 11-25-2007 12:44 PM
