Discuss
WM2050CW fails the spin test
 in
Washer Repair
Hi, I've read a couple of posts here to suspect what's wrong, but wanted to confirm. My washer is currently
Appliance Repair Forum > Appliance Repair Help > Washer Repair » WM2050CW fails the spin test
  #1 (permalink)
Old 03-12-2017, 12:02 PM
Junior Member
ti_chris is on a distinguished road
Default WM2050CW fails the spin test
Model Number: WM2050CW   Brand: -other-   Age: 5 - 10 years
I've read a couple of posts here to suspect what's wrong, but wanted to confirm. My washer is currently having a hard time rotating. I have run the diagnostic and have observed that it does fine with the first test (tumble clockwise). However it fails the low & high spin. There, the LED reads numbers that quickly change anywhere from 30 to 150. I suspect that it's the rotor assembly & sensor switch, but would love to confirm my suspicion first.
Related Models
 WM2075CW Washer
 WM2077CW Washer
 WM2101HW Washer
 WM2233HD Washer
 WM2233HS Washer
 WM2233HU Washer
 WM2233HW Washer
 WM2277HB Washer
 WM2277HS Washer
 WM2277HW Washer
Jenn-Air WM227B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM227W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236W WALLOVEN- S/C MWAVE ELE
 WM2432HW Washer
 WM2442HW Washer
 WM2455HG Washer
 WM2487HRM Washer
 WM2487HRMA Washer
 WM2487HWM Washer
 WM2487HWMA Washer
 WM2496HSM Washer
 WM2496HWM Washer
 WM2677HSM Washer
 WM2688HNM Washer
 WM2688HNMA Washer
 WM2688HWM Washer
 WM2688HWMA Washer
Jenn-Air WM27160B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27160W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780W WALLOVEN- S/C MWAVE ELE
 WM2801HLA Washer
 WM2801HRA Washer
 WM2801HWA Washer
 WM3001HPA Washer
 WM3001HRA Washer
 WM3001HWA Washer
Jenn-Air WM30460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM30460W WALLOVEN- S/C MWAVE ELE
 WM3431HS Washer
 WM3431HW Washer
 WM3632HW Washer
 WM3677HW Washer
 WM3988HWA Washer
Amana WM612 MWAVE- CNTRTP / STAND ALONE
Amana WM614 MWAVE- CNTRTP / STAND ALONE
Amana WM615 MWAVE- CNTRTP / STAND ALONE
Amana WM712 MWAVE- CNTRTP / STAND ALONE
Amana WM714 MWAVE- CNTRTP / STAND ALONE
Amana WM715 MWAVE- CNTRTP / STAND ALONE
General Electric WMCD2050G0WC Washer
General Electric WMCD2050H0WC WASHER
General Electric WMCD2050H1WC WASHER
General Electric WMCD2050H2WC WASHER
General Electric WMCD2050H3WC WASHER
General Electric WMCD2050H4WC WASHER
General Electric WMCD2050H5WC WASHER
General Electric WMCD2050H6WC COIN-OP WASHER
General Electric WMCD2050J0WC COIN-OP WASHER
General Electric WMCD2050J1WC WASHER
Jenn-Air WME3020B WALLOVEN- S/C MWAVE ELE
Jenn-Air WME3020W WALLOVEN- S/C MWAVE ELE
Jenn-Air WMG3020B WALLOVEN- S/C MWAVE GAS
Jenn-Air WMG3020W WALLOVEN- S/C MWAVE GAS
Whirlpool WMH1162XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS0 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS1 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS0 MICROWAVE OVEN 1.6 CU. FT.
  #2 (permalink)
Old 03-16-2017, 10:06 AM
Junior Member
jimctec is on a distinguished road
Default
Is there any noise in spin? Any wiggle in the basket its self compared to the outer tub. You need to know if the bearings are good. Does the motor action sound abnormal in spin? Sometimes is louder or pulsing sound... The least expensive part to try would be the Hall sensor that picks up motor speed and sends signal to control. You have to remove the rotor and stator to get to it. P#6501KW2002A.
  #3 (permalink)
Old 03-16-2017, 02:05 PM
Junior Member
Default
Quote:
Things seem normal when testing #1. For #2 however, it does pulse and it grinds to a halt if there's a significant load in there. I'll try and grab a video tonight to illustrate what I'm seeing. Would that be more of an indication that the bearing is toasted?
  #4 (permalink)
Old 03-16-2017, 09:15 PM
Junior Member
Default
Here's the video of what it does:
https://youtu.be/HCfEZlV3pT4
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
front loader fails to spin in spin cycle mschlott Washer Repair 1 08-06-2016 05:38 AM
Duet Dryer fails keypad test-cycle selector knob momofthreeinfl Dryer Repair 2 08-02-2014 02:21 PM
Maytag freezer/evap fan fails service test 3 teknogroove Refrigerator & Freezer Repair 0 09-27-2013 06:26 PM
Kenmore Washer Won't Cycle -Fails Tachometer Test Richy1 Washer Repair 1 05-20-2013 08:39 PM
Washer fails high spin test T11 camry93 Washer Repair 3 06-24-2010 04:41 AM
