Discuss
W10435302 Bearing replacement Kit - Tips and Advice (second try)
 in
Washer Repair
Ok, Sorry if duplicate, don't think it went through the first time. New user here, have used appliance parts pros
Appliance Repair Forum > Appliance Repair Help > Washer Repair » W10435302 Bearing replacement Kit - Tips and Advice (second try)
  #1 (permalink)
Old 03-11-2017, 02:12 PM
Junior Member
Madd0c is on a distinguished road
Default W10435302 Bearing replacement Kit - Tips and Advice (second try)
Model Number: Kenmore Cabrio   Brand: Kenmore   Age: 5 - 10 years
New user here, have used appliance parts pros for years, never thought I needed to post anything. Had never needed to call the hotline in about 5 different repairs, but I needed to replace the bearings in my Kenmore Cabrio washer.
If you want to skip the melodramatic story and go to the Tips below feel free.
Watched the excellent video, and ordered the part(W10435302) including the separate bearing installation tool (W10447783 worth it). Got the parts fast, and waited for a Saturday morning to do the repair. Everything went along fine with the video until the part with removing the old drum shaft.
On the video, 2 taps with the hammer and the old drum shaft falls into the outer tub. EZ. Nope. I beat the living crap out of that thing.
After beating on the old drive shaft for 10 minutes, I called the hotline. A pleasant representative got all my info, and when I asked the question she pointed me to the online video. I explained that, yes, I had watched the video, and that was not my problem. After several minutes on hold, she came back and said they had no other information, and no live technicians( not sure if that is a Saturday thing, or a general thing). Sooooooo with my simmering rage inside me, I was able to pound out the drive shaft. No seriously here is:
Tip 1 -
If your old drum shaft will not drive into the outer tub from below use a 4 pound mallet ( or something similar and HEAVY). Place a block of wood on the drum shaft and it actually did only take 3 hits to pop it out. Was worried I would break the outer tub, but at this point I was going to have to replace it if I didn't get the shaft out. The outer tub was fine.
Tip 2-
The sealant probably is great stuff, but it seems like toner cartridges. That stuff gets EVERYWHERE. Hard to wipe off. If it dries on your hands good luck. Well, Acetone takes it off no problem (yes, I know, possibly carcinogenic, but if my hands havent fallen off after the gallons I have gotten on me over the years then I think a little on a paper towel will probably be survivable - USE AT YOUR OWN RISK - darn lawyers)
So take home message is acetone will get that stuff off the tub, your hands etc.
Tip 3-
When you get everything installed, before you put the rotor assembly on, the drive shaft should turn freely. I had a few areas that seemed to be binding. It seems that the spacer tube that the video shows just being placed in casually, actually can be off center. Try to center it when you put the lower bearing assembly in (tough working from the bottom I know). I wasn't going to disassemble everything, so I took everything off to the drum shaft, and tapped it out. I then used the "bearing removal tool" steel rod to tap the spacer tube more centered. This fixed the binding.
Everything else went very smoothly.
I appreciate the information and service that Appliance Parts Pros puts into the videos, and they definitely have saved me a ton of money.
Keep up the good work!
I hope this information helps someone who is stuck like I was.
Madd0c
Related Models
Whirlpool KERA205PBL0 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBL1 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBL2 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBL3 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBL4 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBL5 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBT0 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBT1 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBT2 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBT3 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBT4 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PBT5 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PSS0 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PSS1 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PSS2 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PSS3 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PSS4 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PSS5 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PWH0 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PWH1 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PWH2 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PWH3 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PWH4 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA205PWH5 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool KERA807PBB00 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PBB01 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PBB02 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PBL00 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PBL01 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PBL02 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PSS00 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PSS01 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PSS02 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PWW00 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PWW01 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERA807PWW02 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool KERC500EAL1 ELECTRIC RANGE
Whirlpool KERC500EAL2 ELECTRIC RANGE
Whirlpool KERC500EAL3 ELECTRIC RANGE
Whirlpool KERC500EAL4 ELECTRIC RANGE
Whirlpool KERC500EAL5 ELECTRIC RANGE
Whirlpool KERC500EWH1 ELECTRIC RANGE
Whirlpool KERC500EWH2 ELECTRIC RANGE
Whirlpool KERC500EWH3 ELECTRIC RANGE
Whirlpool KERC500EWH4 ELECTRIC RANGE
Whirlpool KERC500EWH5 ELECTRIC RANGE
Whirlpool KERC500HBT0 ELECTRIC RANGE
Whirlpool KERC500HBT1 ELECTRIC RANGE
Whirlpool KERC500HBT2 ELECTRIC RANGE
Whirlpool KERC500HBT3 ELECTRIC RANGE
Whirlpool KERC500HWH0 ELECTRIC RANGE
Whirlpool KERC500HWH1 ELECTRIC RANGE
Whirlpool KERC500HWH2 ELECTRIC RANGE
Whirlpool KERC500HWH3 ELECTRIC RANGE
Whirlpool KERC500YAL0 ELECTRIC RANGE
Whirlpool KERC500YAL1 ELECTRIC RANGE
Whirlpool KERC500YAL2 ELECTRIC RANGE
Whirlpool KERC500YAL3 ELECTRIC RANGE
Whirlpool KERC500YAL4 ELECTRIC RANGE
Whirlpool KERC500YAL5 ELECTRIC RANGE
Whirlpool KERC500YBL0 ELECTRIC RANGE
Whirlpool KERC500YBL1 ELECTRIC RANGE
Whirlpool KERC500YBL2 ELECTRIC RANGE
Whirlpool KERC500YBL3 ELECTRIC RANGE
Whirlpool KERC500YBL4 ELECTRIC RANGE
Whirlpool KERC500YBL5 ELECTRIC RANGE
Whirlpool KERC500YWH0 ELECTRIC RANGE
Whirlpool KERC500YWH1 ELECTRIC RANGE
Whirlpool KERC500YWH2 ELECTRIC RANGE
Whirlpool KERC500YWH3 ELECTRIC RANGE
Whirlpool KERC500YWH4 ELECTRIC RANGE
Whirlpool KERC500YWH5 ELECTRIC RANGE
Whirlpool KERC506HBS3 30" ELECTRIC RANGE CERAN COOKTOP Convection Oven
Whirlpool KERC506HBT0 ELECTRIC RANGE
Whirlpool KERC506HBT1 ELECTRIC RANGE
Whirlpool KERC506HBT2 ELECTRIC RANGE
Whirlpool KERC506HBT3 30" ELECTRIC RANGE CERAN COOKTOP Convection Oven
Whirlpool KERC506HWH0 ELECTRIC RANGE
Whirlpool KERC506HWH1 ELECTRIC RANGE
Whirlpool KERC506HWH2 ELECTRIC RANGE
Whirlpool KERC506HWH3 30" ELECTRIC RANGE CERAN COOKTOP Convection Oven
Whirlpool KERC507EAL1 ELECTRIC RANGE
Whirlpool KERC507EAL2 ELECTRIC RANGE
Whirlpool KERC507EAL3 ELECTRIC RANGE
Whirlpool KERC507EAL4 ELECTRIC RANGE
Whirlpool KERC507EAL5 ELECTRIC RANGE
Whirlpool KERC507EBL1 ELECTRIC RANGE
Whirlpool KERC507EBL2 ELECTRIC RANGE
Whirlpool KERC507EBL3 ELECTRIC RANGE
Whirlpool KERC507EBL4 ELECTRIC RANGE
Whirlpool KERC507EBL5 ELECTRIC RANGE
Whirlpool KERC507EWH1 ELECTRIC RANGE
Whirlpool KERC507EWH2 ELECTRIC RANGE
Whirlpool KERC507EWH3 ELECTRIC RANGE
Whirlpool KERC507EWH4 ELECTRIC RANGE
Whirlpool KERC507EWH5 ELECTRIC RANGE
Whirlpool KERC507HAL0 ELECTRIC RANGE
Whirlpool KERC507HAL1 ELECTRIC RANGE
Whirlpool KERC507HAL2 ELECTRIC RANGE
Whirlpool KERC507HAL3 ELECTRIC RANGE
Whirlpool KERC507HBL0 ELECTRIC RANGE
Whirlpool KERC507HBL1 ELECTRIC RANGE
Whirlpool KERC507HBL2 ELECTRIC RANGE
Whirlpool KERC507HBL3 ELECTRIC RANGE
Whirlpool KERC507HBL4 ELECTRIC RANGE
Whirlpool KERC507HBS0 ELECTRIC RANGE
Whirlpool KERC507HBS1 ELECTRIC RANGE
Whirlpool KERC507HBS2 ELECTRIC RANGE
Whirlpool KERC507HBS3 ELECTRIC RANGE
Whirlpool KERC507HBS4 ELECTRIC RANGE
Whirlpool KERC507HBT0 ELECTRIC RANGE
Whirlpool KERC507HBT1 ELECTRIC RANGE
Whirlpool KERC507HBT2 ELECTRIC RANGE
Whirlpool KERC507HBT3 ELECTRIC RANGE
Whirlpool KERC507HBT4 ELECTRIC RANGE
Whirlpool KERC507HWH0 ELECTRIC RANGE
Whirlpool KERC507HWH1 ELECTRIC RANGE
Whirlpool KERC507HWH2 ELECTRIC RANGE
Whirlpool KERC507HWH3 ELECTRIC RANGE
Whirlpool KERC507HWH4 ELECTRIC RANGE
  #2 (permalink)
Old 03-12-2017, 08:23 PM
Senior Member
PNWDrew is on a distinguished road
Default
The drive shaft and bearings can be a real pain to get out. The basket can be a real pain to get out. Yes that inner tube can and does get offline. It's a POS of a design made to avoid all the replacement tubs we were seeing.
I usually tighten until bearings seat and then loosen it all up and make sure the tube didn't get cocked sideways. It usually is. Then I tighten it all back down and drop the drive shaft in, etc...
Do it 20-30 more times and you'll have it down to 45-60 min. And still be annoyed to see it show up on your day. It never really stops sucking.
As for the brown glue, it's actually dryer drum seal glue and it is some of the toughest stuff made, but it dries quickly and some inside the tub isn't an issue.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
