Discuss
Water inlet valve
 in
Washer Repair
when i first turn washer on, the water inlet valve lets cold water in, then after about 30sec. turns off
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water inlet valve
  #1 (permalink)
Old 03-08-2017, 05:02 AM
Junior Member
dcbradt is on a distinguished road
Default Water inlet valve
Brand: Maytag   Age: 5 - 10 years
when i first turn washer on, the water inlet valve lets cold water in, then after about 30sec. turns off and hums. I switch the plug ins(little elec. wires) and it runs again, then during rinse cylce, it does the same thing and I have to switch wires back, I've checked hoses, screens and all seem fine, I do not use the hotwater, and the hotwater is turned off from the wall. and yes, I have it set on Cold/cold
thanks
Darren
  #2 (permalink)
Old 03-08-2017, 06:47 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Try this, take the hot water hose and switch it for the cold water hose. Then switch the wires so that the hot water valve will now do the job that the cold water side used to do.
Then try it out, if it fills OK, that means the cold water side of your water valve is going bad.
If you provide the model number I could provide you with better help.
  #3 (permalink)
Old 03-08-2017, 03:51 PM
Junior Member
jimctec is on a distinguished road
Default
Some of the inlet valves have a thermistor inside. Automatic temp control. If the incoming water is too cold it may be trying to add a little hot to warm it up. Try normal operation with both valves turned on at the wall.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Inlet Valve bm@scubanation.com Dishwasher Repair 1 12-11-2015 02:18 AM
Water inlet valve Shari B Washer Repair 1 08-05-2015 06:38 PM
Water inlet valve gonneda1 Dishwasher Repair 1 02-28-2014 06:28 PM
difference between inlet valve and water inlet system? pollgreen Dishwasher Repair 0 01-08-2014 11:08 AM
Water inlet valve MPKNAPLES Dishwasher Repair 0 09-08-2009 12:26 PM
