Discuss
LG Front Load Washer Barely Spins
 in
Washer Repair
I have an LG WM2455HW washing machine that will attempt to cycle just fine and doesn't throw any error codes,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG Front Load Washer Barely Spins
  #1 (permalink)
Old 03-02-2017, 08:30 AM
Junior Member
mckennwa is on a distinguished road
Default LG Front Load Washer Barely Spins
Model Number: WM2455HW   Brand: -other-   Age: 5 - 10 years
I have an LG WM2455HW washing machine that will attempt to cycle just fine and doesn't throw any error codes, however, it simply won't spin when given any resistance. You can hear some noise as it tries to spin, but it can't do it. When I remove all the clothes, it can turn the drum then, but more than a couple of wet shirts and it can't turn anymore.
My guesses are that either the stator is failing or the clutch is slipping. However, since it will at least spin a little, I am wondering if it is the stator or not, as I would assume those either fail completely or not. Could it be that the rotor assembly is loose?
I opened the machine and was able to freely spin the tub, so I do not suspect that the bearings are to blame.
Thanks in advance for any help. We have two young boys, so the sooner I can fix this the better!
Related Models
 WM2487HRM Washer
 WM2487HRMA Washer
 WM2487HWM Washer
 WM2487HWMA Washer
 WM2496HSM Washer
 WM2496HWM Washer
 WM2677HSM Washer
 WM2688HNM Washer
 WM2688HNMA Washer
 WM2688HWM Washer
 WM2688HWMA Washer
Jenn-Air WM27160B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27160W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780W WALLOVEN- S/C MWAVE ELE
 WM2801HLA Washer
 WM2801HRA Washer
 WM2801HWA Washer
 WM3001HPA Washer
 WM3001HRA Washer
 WM3001HWA Washer
Jenn-Air WM30460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM30460W WALLOVEN- S/C MWAVE ELE
 WM3431HS Washer
 WM3431HW Washer
 WM3632HW Washer
 WM3677HW Washer
 WM3988HWA Washer
Amana WM612 MWAVE- CNTRTP / STAND ALONE
Amana WM614 MWAVE- CNTRTP / STAND ALONE
Amana WM615 MWAVE- CNTRTP / STAND ALONE
Amana WM712 MWAVE- CNTRTP / STAND ALONE
Amana WM714 MWAVE- CNTRTP / STAND ALONE
Amana WM715 MWAVE- CNTRTP / STAND ALONE
General Electric WMCD2050G0WC Washer
General Electric WMCD2050H0WC WASHER
General Electric WMCD2050H1WC WASHER
General Electric WMCD2050H2WC WASHER
General Electric WMCD2050H3WC WASHER
General Electric WMCD2050H4WC WASHER
General Electric WMCD2050H5WC WASHER
General Electric WMCD2050H6WC COIN-OP WASHER
General Electric WMCD2050J0WC COIN-OP WASHER
General Electric WMCD2050J1WC WASHER
Jenn-Air WME3020B WALLOVEN- S/C MWAVE ELE
Jenn-Air WME3020W WALLOVEN- S/C MWAVE ELE
Jenn-Air WMG3020B WALLOVEN- S/C MWAVE GAS
Jenn-Air WMG3020W WALLOVEN- S/C MWAVE GAS
Whirlpool WMH1162XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS0 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS1 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVQ0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVQ2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVS0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVS2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVT0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVT1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVT2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2205XVB0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVB1 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVQ0 Microwave Oven/Hood 2.0 Cu. Ft.
  #2 (permalink)
Old 03-02-2017, 09:42 AM
Junior Member
Default
After further research, it sounds like the teeth on the inside of the rotor assembly may be to blame. I will remove the back panel and check that tonight.
  #3 (permalink)
Old 03-02-2017, 10:26 PM
Senior Member
PNWDrew is on a distinguished road
Default
Super common problem and very easy fix. The new rotor part will have a stronger spline. Just ensure that the corresponding splines on the basket shaft are not significantly damaged.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Spins But Barely Agitates widowbryant Washer Repair 0 03-13-2015 08:59 AM
Front load washer only spins one direction e5dave5 Washer Repair 1 04-25-2013 06:05 PM
front load washer shakes when spins TJH Washer Repair 4 05-07-2012 02:00 PM
Washer barely spins or agitates. MommaJesi Washer Repair 1 12-31-2009 05:39 PM
whirlpool washer agitator barely spins TEDALD Washer Repair 0 04-05-2008 07:27 AM
