Discuss
Cabrio UL Code
 in
Washer Repair
I purchased a suspension kit from this site and installed them this evening. The washer still gets a UL code
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Cabrio UL Code
  #1 (permalink)
Old 03-01-2017, 02:58 PM
Junior Member
dosmond is on a distinguished road
Default Cabrio UL Code
Brand: Whirlpool   Age: 5 - 10 years
I purchased a suspension kit from this site and installed them this evening. The washer still gets a UL code when spin is around 9 minutes left. This happens even if nothing is in the washer. At slow spin it appears balanced but once it goes into a faster spin the washer acts like an unbalanced tire on a car. Since not the suspension kit, what do I need to look at next?
  #2 (permalink)
Old 03-02-2017, 05:26 PM
Senior Member
brobriffin is on a distinguished road
Default
dosmond
please give us you model #
for further assistance
  #3 (permalink)
Old 03-02-2017, 05:38 PM
Junior Member
Default Model
The washer model in question is WTW6700TW2 SN CW5170460
  #4 (permalink)
Old 03-02-2017, 09:12 PM
Senior Member
Default
There are a few reasons why the UL occurs and the tub spins off balanced during high spin.
1. The bearings might be going bad.
2. The drive shaft might be bent.
both are part of one kit
Whirlpool W10435302 Bearing and Tub Seal Kit - AppliancePartsPros.com
3. The basket (inner tub) balance ring might be empty It should have water in it for balance. (Hopefully this is not your problem, very expensive)
Whirlpool W10296143 Basket - AppliancePartsPros.com
4. The basket hub assembly might be broken.
Watch the videos with the listed part number links to see how to access and see if any of these might be your problem.
  #5 (permalink)
Old 03-02-2017, 09:19 PM
Senior Member
Default
A sign of bearing failure is what appears to be grease splatter under the machine. Inside the Rotor and against the under side of the walls.
  #6 (permalink)
Old 03-02-2017, 09:22 PM
Senior Member
Default
Also double check that the new suspension rods are the proper strength.
Watch these two videos for details to confirm if the rods are good.
https://youtu.be/ILYGQ9t0v0Y
https://youtu.be/8AvI9ma6rO4
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F51 code - Cabrio washer Nidantwo Washer Repair 0 12-17-2015 02:23 PM
Cabrio oL code won't go away jacksonwalker@mac.com Washer Repair 0 08-22-2014 05:38 PM
Cabrio ul/f51 code Forelorren Washer Repair 1 02-18-2013 08:24 AM
F50 Code on Cabrio manwithplan46151 Washer Repair 2 09-28-2011 06:05 AM
f1 code on cabrio washer susanv Washer Repair 4 08-09-2011 09:29 AM
