Discuss
Whirlpool Washer Agitator Noise / No Spin
 in
Washer Repair
This morning our Whirlpool washer began making a very loud rattling noise shortly before going into the spin cycle, where
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer Agitator Noise / No Spin
  #1 (permalink)
Old 03-01-2017, 12:06 PM
Junior Member
BobTh is on a distinguished road
Default Whirlpool Washer Agitator Noise / No Spin
Model Number: LA6800XTN0   Brand: Whirlpool   Age: More than 10 years
This morning our Whirlpool washer began making a very loud rattling noise shortly before going into the spin cycle, where it simply buzzed before I shut it off.
Video: https://youtu.be/xKg9qTV-Kmk
Any assistance in identifying the specific problem and parts would be appreciated. Thanks.
Related Models
Whirlpool LA6800XTN0 AUTOMATIC WASHER
Whirlpool LA6800XTN1
Whirlpool LA6800XTW0 AUTOMATIC WASHER
Whirlpool LA6800XTW1
Whirlpool LA6888XTF0
Whirlpool LA6888XTG0
Whirlpool LA6888XTG1
Whirlpool LA6888XTM0
Whirlpool LA6888XTN0
Whirlpool LA6888XTN1
Whirlpool LA6888XTW0
Whirlpool LA6888XTW1
Whirlpool LA6900XKW2
Maytag LA6910 WASHER-TOP LOADING
Whirlpool LA7000XKW1
Whirlpool LA7000XKW2
Whirlpool LA7000XMW0
Whirlpool LA7000XPW0
Whirlpool LA7000XPW1
Whirlpool LA7000XSW0
Whirlpool LA7000XSW1
Whirlpool LA7000XTF0
Whirlpool LA7000XTF1
Whirlpool LA7000XTG0
Whirlpool LA7000XTG1
Whirlpool LA7000XTM0
Whirlpool LA7000XTM1
Whirlpool LA7000XTN0
Whirlpool LA7000XTN1
Whirlpool LA7000XTW0
Whirlpool LA7000XTW1
Whirlpool LA7001XSW0
Whirlpool LA7001XTF1
Whirlpool LA7001XTG1
Whirlpool LA7001XTM1
Whirlpool LA7001XTN1
Whirlpool LA7001XTW0
Whirlpool LA7001XTW1
Whirlpool LA7005XKW1
Whirlpool LA7005XMW0
Whirlpool LA7005XPW0
Whirlpool LA7005XPW1
Frigidaire LA700AXD1 Wwh(v4) / 27 " Washer
Frigidaire LA700AXD2 Wwh(v4) / 27 " Washer
Frigidaire LA700AXD3 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW1 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW2 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW3 Wwh(v4) / 27 " Washer
Frigidaire LA700MXD1 Wwh(v6) / 27 " Washer
Frigidaire LA700MXW1 Wwh(v5) / 27 " Washer
Whirlpool LA7088XTF0
Whirlpool LA7088XTF1
Whirlpool LA7088XTG0
Whirlpool LA7088XTG1
Whirlpool LA7088XTM0
Whirlpool LA7088XTM1
Whirlpool LA7088XTN0
Whirlpool LA7088XTN1
Whirlpool LA7088XTW0
Whirlpool LA7088XTW1
Maytag LA712 WASHER-TOP LOADING
Maytag LA7300 WASHER-TOP LOADING
Maytag LA7400 WASHER-TOP LOADING
Whirlpool LA7400XMW0
Whirlpool LA7400XMW1
Whirlpool LA7400XMW2
Whirlpool LA7400XMW3
Whirlpool LA7450XMW0
Whirlpool LA7450XMW1
Whirlpool LA7460XMW0
Maytag LA7500 WASHER-TOP LOADING
Maytag LA7500S WASHER-TOP LOADING
Maytag LA7500W WASHER-TOP LOADING
Whirlpool LA7500XKW0
Frigidaire LA750EXD3 Wwh(v6) / Washer
Frigidaire LA750EXF3 Wwh(v7) / Washer
Frigidaire LA750EXH3 Wwh(v8) / Washer
Frigidaire LA750EXV3 Wwh(v9) / Washer
Frigidaire LA750EXW3 Wwh(v10) / Washer
Frigidaire LA750MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA750MXW1 Wwh(v1) / 27 " Washer
Whirlpool LA7680XKW1
Whirlpool LA7680XKW2
Whirlpool LA7680XMW0 Washers*
Whirlpool LA7680XPW0
Whirlpool LA7680XPW1
Whirlpool LA7680XPW2
Whirlpool LA7680XSW0
Whirlpool LA7680XSW1
Whirlpool LA7680XTF0
Whirlpool LA7680XTF1
Whirlpool LA7680XTG0
Whirlpool LA7680XTG1
Whirlpool LA7680XTM0
Whirlpool LA7680XTM1
Whirlpool LA7680XTN0
Whirlpool LA7680XTN1
Whirlpool LA7680XTW0
Whirlpool LA7680XTW1
Whirlpool LA7681XSW0
Whirlpool LA7681XSW1
Whirlpool LA7685XKW1
Whirlpool LA7685XPW0
Whirlpool LA7685XPW1
Whirlpool LA7685XPW2
Whirlpool LA7700XPW0
Whirlpool LA7700XPW1
Whirlpool LA7700XPW3
Whirlpool LA7700XPW4
Whirlpool LA7700XPW5
Whirlpool LA7700XSW0
Whirlpool LA7700XWN0
Whirlpool LA7700XWW0
Whirlpool LA7780XSW0
Whirlpool LA7780XSW1 Washers*
Whirlpool LA7780XSW2
Maytag LA7800 WASHER-TOP LOADING
Whirlpool LA7800XKW2
Whirlpool LA7800XMW0
Whirlpool LA7800XPW0
  #2 (permalink)
Old 03-02-2017, 05:38 PM
Senior Member
brobriffin is on a distinguished road
Default
Starting from the last symptom (the buzzing) it sounds like you have a bad start capacitor.
Whirlpool WP8572717 Capacitor - AppliancePartsPros.com
However the rattling noise during agitate mode sounds like something going bad in the motor or more likely transmission. If it is hanging up it may cause that sound in spin mode although the motor should spin just draining before spinning. Where does the rattling sound seem to come from?
1. The bottom.
2. The tub / basket area?
Will the machine go into agitate mode now or does it buzz then as well?
  #3 (permalink)
Old 03-04-2017, 05:48 PM
Junior Member
Default
Thank you for your reply.
I believe the sound is coming from the bottom. I took a look at the motor coupler and it was fine, but didn't go any deeper than that.
Before I took it apart, the machine would still go into agitate mode.
Edit: When I pulled the coupling, I noted what appeared to be a small amount of oil leaking from around the motor shaft.
  #4 (permalink)
Old 03-05-2017, 05:16 AM
Senior Member
Default
Does it still just buzz in spin mode but operate in agitate mode? If so the capacitor is fine.
The transmission may be binding up not allowing the motor to turn in spin mode. The oil leak might be a sign of trans issue and that may be your noise. Is the oil coming from the drive input shaft on the transmission? If all that is true sounds like time for a new transmission. Not hard to replace especially if you have the motor off. I would also replace the clutch as well.
Whirlpool 3360629 Neutral Drain Transmission - AppliancePartsPros.com
Whirlpool 285785 Clutch Assembly - AppliancePartsPros.com
  #5 (permalink)
Old 03-05-2017, 01:01 PM
Junior Member
Default
Just out of curiosity, I bypassed the lid switch and engaged the motor in spin mode. The motor itself seems to be making quite a racket (see video). No buzz, but the unit is not under load. Your thoughts?
https://youtu.be/eQeD_l3mUvk
  #6 (permalink)
Old 03-05-2017, 02:47 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
That motor's bearings sound really bad. You need a new motor.
When they are that bad, the motor will pull more amperage and sometimes not start. I wondered what it would sound like without the pump and know I know.
  #7 (permalink)
Old 03-06-2017, 04:55 PM
Senior Member
Default
ThatGuy beat me to the punch.
Whirlpool WP661600 Direct Drive Washer Motor - AppliancePartsPros.com
Great work BTW, BobTh you are a good sleuth.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Imperial Loud Noise on Spin & Agitator Turns rock2 Washer Repair 2 12-24-2011 05:12 PM
whirlpool washer no agitator or spin jackleech Washer Repair 1 08-31-2010 12:33 PM
Whirlpool washer grind noise in spin omnitool Washer Repair 1 04-12-2010 11:09 AM
Whirlpool Washer Spin Cycle Noise radiodudek Washer Repair 1 01-09-2010 09:09 PM
Estate Whirlpool washer noise during spin tom gottler Washer Repair 1 12-20-2008 10:46 AM
