Discuss
Washer won't drain
 in
Washer Repair
Had a problem with washer not spinning all the water out. Did an extra spin and drain cycle on a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't drain
  #1 (permalink)
Old 02-23-2017, 06:58 PM
Junior Member
jpowell1978 is on a distinguished road
Default Washer won't drain
Model Number: WTW5640XW1   Brand: Whirlpool   Age: 5 - 10 years
Had a problem with washer not spinning all the water out. Did an extra spin and drain cycle on a few different loads. Eventually the washer was left with water left in the tub. I've checked for obstructions and found a couple Bobby pins. Removed those and tried again. Went through all the cycles and when timer was down to one minute, it went back to 14 minutes and never heard any water drain. I then did functions test and received errors f9 e1, f7 e7, f0 e2, f0 e5. I conducted the continuity tests for the drain pump and all tests came back normal. When I did the manual tests and tested the drain, I could here something turn on, but nothing happened or drained. I don't see anything clogged. I replaced the actuator thinking that was why clothes were still ending up wet. It says next thing is to replace main control board. I'm not wanting to spend over $300 for that part, so I was wondering if it could be something else. Is it sure it's not the drain pump?
Related Models
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Whirlpool WTW6600SG2 AUTOMATIC WASHER
Whirlpool WTW6600SG3 AUTOMATIC WASHER
Whirlpool WTW6600SW0 AUTOMATIC WASHER
Whirlpool WTW6600SW1 AUTOMATIC WASHER
Whirlpool WTW6600SW2 AUTOMATIC WASHER
Whirlpool WTW6600SW3 AUTOMATIC WASHER
Whirlpool WTW6700TU1 AUTOMATIC WASHER
Whirlpool WTW6700TU2 AUTOMATIC WASHER
Whirlpool WTW6700TW0 AUTOMATIC WASHER
Whirlpool WTW6700TW1 AUTOMATIC WASHER
Whirlpool WTW6700TW2 AUTOMATIC WASHER
Whirlpool WTW6800WB1 AUTOMATIC WASHER
Whirlpool WTW6800WE1 RESIDENTIAL WASHER
Whirlpool WTW6800WL1 AUTOMATIC WASHER
Whirlpool WTW6800WU1 RESIDENTIAL WASHER
Whirlpool WTW6800WW1 AUTOMATIC WASHER
Whirlpool WTW7300XW0 AUTOMATIC WASHER
Whirlpool WTW7300XW1 AUTOMATIC WASHER
Whirlpool WTW7300XW2 AUTOMATIC WASHER
Whirlpool WTW7320YW0 WASHER
Whirlpool WTW7340XW0 AUTOMATIC WASHER
Whirlpool WTW7340XW1 AUTOMATIC WASHER
Whirlpool WTW7340XW2 AUTOMATIC WASHER
Whirlpool WTW7600XW0 AUTOMATIC WASHER
Whirlpool WTW7600XW1 AUTOMATIC WASHER
Whirlpool WTW7600XW2 AUTOMATIC WASHER
Whirlpool WTW7800XB0 AUTOMATIC WASHER
Whirlpool WTW7800XB1 AUTOMATIC WASHER
Whirlpool WTW7800XB2 AUTOMATIC WASHER
Whirlpool WTW7800XB3 AUTOMATIC WASHER
Whirlpool WTW7800XB4 AUTOMATIC WASHER
Whirlpool WTW7800XL0 AUTOMATIC WASHER
Whirlpool WTW7800XL1 AUTOMATIC WASHER
Whirlpool WTW7800XL2 AUTOMATIC WASHER
Whirlpool WTW7800XL3 AUTOMATIC WASHER
Whirlpool WTW7800XL4 AUTOMATIC WASHER
Whirlpool WTW7800XW0 AUTOMATIC WASHER
Whirlpool WTW7800XW1 AUTOMATIC WASHER
Whirlpool WTW7800XW2 AUTOMATIC WASHER
Whirlpool WTW7800XW3 AUTOMATIC WASHER
Whirlpool WTW7800XW4 AUTOMATIC WASHER
Whirlpool WTW7990XG0 AUTOMATIC WASHER
Whirlpool WTW7990XG1 AUTOMATIC WASHER
Whirlpool WTW8200YW0 AUTOMATIC WASHER
Whirlpool WTW8240YW0 AUTOMATIC WASHER
Whirlpool WTW8600YW0 AUTOMATIC WASHER
Whirlpool WTW8800YC0 WASHER
Whirlpool WTW8800YW0 WASHER
Bosch WTZ1170
Bosch WTZ1210
Roper WU0800B UNDERCOUNTER DISHWASHER
Roper WU0800XX0 Dishwasher
Roper WU0800XX1 UNDERCOUNTER DISHWASHER
Maytag WU100 DISHWASHER- UNDERCOUNTER
  #2 (permalink)
Old 02-28-2017, 04:40 PM
Senior Member
PNWDrew is on a distinguished road
Default
All those codes could be explained by drain issue so don't buy a control yet.
Drain it by whatever means you can ( a shop vac is my usual method) and pull the pump off the bottom again. Use the 3 5/16 screws it'll give you the best access.
1) look up into tub hole for evidence of something like a blob of lint or a small sock blocking drain and into drain hose for the same. When bobby pins and other similar items get stuck in pump inlet they catch other crap that may or may not be right at the hole.
2) Manually turn pump impeller, if it feels gritty or doesn't have a series of magnetic resistance points as you rotate it change the pump. Check wiring right at the pump plug while you are there.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
BAFFLED!! LG Washer won't drain. Drain clear, pump works. SimplyBaffled Washer Repair 2 04-20-2016 04:38 PM
Dish washer won't drain after replace the drain pump Bryanhouston Dishwasher Repair 0 03-09-2015 08:56 PM
GE Profile Dish Washer drains, but water continues to drain back into the washer Kirstin123 Dishwasher Repair 0 05-18-2014 07:41 AM
Washer will only drain if put on "Drain+Spin" cycle. Arieleno Washer Repair 7 11-02-2011 07:03 PM
My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? ks_becker Washer Repair 0 08-10-2010 10:25 AM
