Discuss
Agitation is Slow
 in
Washer Repair
So the agitator on my Whirlpool WTW5100VQ0 is moving slowly. The bottom agitator moves back and forth as it should
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Agitation is Slow
  #1 (permalink)
Old 02-22-2017, 01:16 PM
Junior Member
PirateChic is on a distinguished road
Exclamation Agitation is Slow
Model Number: WTW5100VQ   Brand: Whirlpool   Age: 5 - 10 years
So the agitator on my Whirlpool WTW5100VQ0 is moving slowly. The bottom agitator moves back and forth as it should and the upper agitator moves as it should. I just installed a new cam kit on the upper agitator. So now, after the water has filled the tub and begins the washing cycle, the clothes stay stationary, while the agitator is doing it's thing, slowly. It seems like the agitator is not getting enough power to push the cloth around. I've tested this three times, once with a small amount of clothes and again with a heavier load of clothes, then finally with no clothes and there is not a lot of splashing action as there once was. I get the same result each time.
I checked the drive motor coupler and it was in good condition.
The machine will spin and rinse as it should. The slow moving agitator is my only problem.
I will say the washer was working perfectly prior to this. One day after washing around 5 regular loads of clothes and upon starting my 6th load, I noticed a loud grinding sound - like plastic rubbing against plastic maybe? This occurred while the machine was in the wash cycle. I thought maybe something had gotten caught under the agitator, so I turned the machine off and tried to move through the clothes to feel for something amiss. I did find the clothes were violently twisted around the agitator - so very badly that it took about 20 minutes to untangle it all. I then turned the machine to the rinse/spin cycle, so I could get the clothes out and inspect the machine further. After watching some repair videos, I decided to install a new cam kit in the top agitator as the dogs were definitely stripped. However, this did not fix the issue. I am not sure what to do now. Any help would be much appreciated. Thanks!
Related Models
Whirlpool WTW5100VQ0 AUTOMATIC WASHER
Whirlpool WTW5100VQ1 AUTOMATIC WASHER
Whirlpool WTW5100VQ2 AUTOMATIC WASHER
Whirlpool WTW5200SQ0 AUTOMATIC WASHER
Whirlpool WTW5200VQ0 AUTOMATIC WASHER
Whirlpool WTW5200VQ1 AUTOMATIC WASHER
Whirlpool WTW5200VQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ0 AUTOMATIC WASHER
Whirlpool WTW5300SQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ3 AUTOMATIC WASHER
Whirlpool WTW5300VW0 AUTOMATIC WASHER
Whirlpool WTW5300VW1 AUTOMATIC WASHER
Whirlpool WTW5300VW2 AUTOMATIC WASHER
Whirlpool WTW5300VW3 AUTOMATIC WASHER
Whirlpool WTW5310SQ0 AUTOMATIC WASHER
Whirlpool WTW5310VQ0 AUTOMATIC WASHER
Whirlpool WTW5320SQ0 AUTOMATIC WASHER
Whirlpool WTW5321SQ0 AUTOMATIC WASHER
Whirlpool WTW5400TQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ2 AUTOMATIC WASHER
Whirlpool WTW5500ST0 AUTOMATIC WASHER
Whirlpool WTW5500ST2 AUTOMATIC WASHER
Whirlpool WTW5500XL0 AUTOMATIC WASHER
Whirlpool WTW5500XL1 AUTOMATIC WASHER
Whirlpool WTW5500XL2 WASHER
Whirlpool WTW5500XW0 AUTOMATIC WASHER
Whirlpool WTW5500XW1 AUTOMATIC WASHER
Whirlpool WTW5500XW2 WASHER
Whirlpool WTW5505SQ0 AUTOMATIC WASHER
Whirlpool WTW5505SQ1 AUTOMATIC WASHER
Whirlpool WTW5505VQ0 AUTOMATIC WASHER
Whirlpool WTW5505VQ1 AUTOMATIC WASHER
Whirlpool WTW5510VQ0 AUTOMATIC WASHER
Whirlpool WTW5520SQ0 AUTOMATIC WASHER
Whirlpool WTW5521SQ0 AUTOMATIC WASHER
Whirlpool WTW5530SQ0 AUTOMATIC WASHER
Whirlpool WTW5540SQ0 AUTOMATIC WASHER
Whirlpool WTW5540ST0 AUTOMATIC WASHER
Whirlpool WTW5550SQ0 AUTOMATIC WASHER
Whirlpool WTW5550ST0 AUTOMATIC WASHER
Whirlpool WTW5550XW0 AUTOMATIC WASHER
Whirlpool WTW5550XW1 AUTOMATIC WASHER
Whirlpool WTW5550XW2 WASHER
Whirlpool WTW5560SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ2 AUTOMATIC WASHER
Whirlpool WTW5590ST0 AUTOMATIC WASHER
Whirlpool WTW5590ST2 AUTOMATIC WASHER
Whirlpool WTW5590VQ0 AUTOMATIC WASHER
Whirlpool WTW5590VQ1 AUTOMATIC WASHER
Whirlpool WTW5600SQ0 AUTOMATIC WASHER
Whirlpool WTW5600VQ0 AUTOMATIC WASHER
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
  #2 (permalink)
Old 02-23-2017, 02:00 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
From your description, I'd say the problem is inside your transmission.
When it quits agitating right, is it making a kind of riipp riipp noises that sound like gears grinding or slipping against each other?
It will agitate when cold or without clothes, but starts making the noise when it warms up or clothes are added.
Its most likely this part.
Whirlpool 3360629 Neutral Drain Transmission - AppliancePartsPros.com
  #3 (permalink)
Old 02-23-2017, 11:04 AM
Junior Member
Default
Agitation begins when it's supposed to - after the tub has filled with water. The agitation is just not as "aggressive" as it once was. I've tested all possible scenarios - with clothes/without clothes, cold water/warm water/hot water/, small load/medium load/super load, on every different type of wash cycle and I get the same result. The agitator isn't pushing the clothes around - they remain stationary no matter how many articles of clothing are in the machine.
The noise begins as soon as the agitation begins (wash cycle). The noise is hard to explain....it's very loud and ratchet-like. Kind of like the sound a ratchet (the tool) makes, except deeper and louder. It "follows" the agitator - like when the agitator moves, the noise occurs also. The noise disappears as soon as the agitator stops. I thought maybe the agitator was stripped, but I do not see any sign of that. I've taken it apart and put it back together at least 5 times to check.
When you said, "When it quits agitating right, is it making a kind of riipp riipp noises that sound like gears grinding or slipping against each other?", are you asking is it making that noise when it is transitioning over to the rinse cycle from the wash cycle? If so, I do not think so. I can hear it "changing gears" from one cycle to the next, but it's not a different noise other than the one it's always made when it switched gears.
Another thing maybe worth mentioning here is that before all of this happened, some times during the spin cycle, the machine would shake violently. I would open the lid to find the clothes "unbalanced" and would have to take them out and distribute the weight evenly around the tub. After doing this, the violent shaking would cease.
Someone mentioned it may be the high side winding in the motor that has stopped working. I have an ohmmeter and was going to check to see if this is the case. I'd much rather this be a transmission issue than a motor issue lol
Did anything I mentioned above make you believe it to be the motor or do you still believe it is the transmission?
  #4 (permalink)
Old 02-23-2017, 12:20 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
In my opinion its the transmission.
I think I misunderstood some of your description and you mine.
What you describe in your second post is what I was trying to say in mine. Loud grinding noise, no agitation = bad transmission.
The part with the clothes getting tangled or off balance is another symptom of the problem.
I think your motor is probably OK.
  #5 (permalink)
Old 04-26-2017, 05:18 PM
Junior Member
Default
You were right! It was the transmission. We put another in a few weeks ago and the problem is solved! Thanks so much for your help!
Now the washer is shaking so violently during the spin cycle that I fear it will take off down the hallway lol. I've inspected all of the springs and they are fine. I'm 99% sure it's the suspension pads. Trying to find a spanner wrench locally is proving to be impossible, so going to order one online. Crossing my fingers I'm right!
Thanks again! =)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Very slow agitation strick Washer Repair 0 06-27-2015 06:29 PM
maytag slow agitation tzsv4k Washer Repair 2 01-20-2011 06:54 AM
Maytag slow agitation tzsv4k Washer Repair 0 01-11-2011 11:39 AM
Slow Agitation CharlieL27 Washer Repair 0 10-19-2010 01:41 PM
Slow agitation labma1 Washer Repair 0 11-17-2008 07:18 PM
