Discuss
GE Top Loader - No Power
 in
Washer Repair
My washer has no power and will not turn on. I verified that the outlet is fine. I also replaced
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Top Loader - No Power
  #1 (permalink)
Old 02-17-2017, 12:12 PM
Junior Member
mknowlesus is on a distinguished road
Default GE Top Loader - No Power
Model Number: wpgt9150hww   Brand: GE   Age: 1 - 5 years
My washer has no power and will not turn on. I verified that the outlet is fine. I also replaced the display circuit board (Display Asm Washer Part Number: AP4344456) but this did not fix my problem. Any tips for troubleshooting no power? I have an electrical tester with continuity etc., but no idea what to really look for. I assume that I would need to test the 120v plug coming into the washer? Any other parts I should check?
Thank you,
Related Models
General Electric WPGT9350C0PL Washer
General Electric WPGT9350C0WW Washer
General Electric WPGT9360C0PL Washer
General Electric WPGT9360C0WW Washer
General Electric WPGT9360E0PL Washer
General Electric WPGT9360E0WW Washer
General Electric WPRB8050D0CC Washer
General Electric WPRB8050D0WW Washer
General Electric WPRB8050D1CC Washer
General Electric WPRB8050D1WW Washer
General Electric WPRB8350H0WT WASHER
General Electric WPRB9110D0CC Washer
General Electric WPRB9110D0WW Washer
General Electric WPRB9110D1CC Washer
General Electric WPRB9110D1WW Washer
General Electric WPRB9220C0CC Washer
General Electric WPRB9220C0WW Washer
General Electric WPRB9220C1CC Washer
General Electric WPRB9220C1WW Washer
General Electric WPRB9220D0CC Washer
General Electric WPRB9220D0WW Washer
General Electric WPRB9220D1CC Washer
General Electric WPRB9220D1WW Washer
General Electric WPRB9220DCCC Washer
General Electric WPRB9220DCWW Washer
General Electric WPRB9250C0CC Washer
General Electric WPRB9250C0WW Washer
General Electric WPRB9250D0CC Washer
General Electric WPRB9250D0WW Washer
General Electric WPRB9250D1CC Washer
General Electric WPRB9250D1WW Washer
General Electric WPRE5240D1WW Washer
General Electric WPRE6100G0WT Washer
General Electric WPRE6100G1WT WASHER
General Electric WPRE6100G2WT WASHER
General Electric WPRE6100G3WT WASHER
General Electric WPRE6150H0WT WASHER
General Electric WPRE6150H1WT WASHER
General Electric WPRE6150H2WT WASHER
General Electric WPRE6150K0WT WASHER
General Electric WPRE6150K1WT WASHER
General Electric WPRE6150K2WT WASHER
General Electric WPRE6150K3WT WASHER
General Electric WPRE6280D1WW Washer
General Electric WPRE6280DCWW Washer
General Electric WPRE8100G0WT Washer
General Electric WPRE8100G1WT WASHER
General Electric WPRE8150H0WT WASHER
General Electric WPRE8150H1WT WASHER
General Electric WPRE8150H2WT WASHER
General Electric WPRE8150K0WT WASHER
General Electric WPRE8150K1WT WASHER
General Electric WPRE8150K2WT WASHER
General Electric WPRE8150K3WT WASHER
General Electric WPRE8320H2WT WASHER
General Electric WPRE8320H3WT WASHER
General Electric WPRE8350H0WT WASHER
General Electric WPRE8350H1WT WASHER
General Electric WPRE8350H2WT WASHER
General Electric WPSB8060B0CC Washer
General Electric WPSB8060B0WW Washer
General Electric WPSB8060B1CC Washer
General Electric WPSB8060B1WW Washer
General Electric WPSB8060B9CC Washer
General Electric WPSB8060B9WW Washer
General Electric WPSB9080B0CC Washer
General Electric WPSB9080B0WW Washer
General Electric WPSB9120B0CC Washer
General Electric WPSB9120B0WW Washer
General Electric WPSE3120Y1WW Washer
General Electric WPSE4200A0AA Washer
General Electric WPSE4200A0WW Washer
General Electric WPSE4270A0AA Washer
General Electric WPSE4270A0WW Washer
General Electric WPSE5290A0AA Washer
General Electric WPSE5290A0WW Washer
General Electric WPSE7001A0AA Washer
General Electric WPSE7001A0WW Washer
General Electric WPSE7002A0AA Washer
General Electric WPSE7002A0WW Washer
General Electric WPSE7003A0AA Washer
General Electric WPSE7003A0WW Washer
General Electric WPSE7003A1WW Washer
General Electric WPSE7003A9WW Washer
General Electric WPSE7003B9WW Washer
General Electric WPSF4170V0AA Washer
General Electric WPSF4170V0WW Washer
General Electric WPSF4170V1AA Washer
General Electric WPSF4170V1WW Washer
General Electric WPSF4170W0AA Washer
General Electric WPSF4170W0WW Washer
General Electric WPSF4170W1AA Washer
General Electric WPSF4170W1WW Washer
General Electric WPSF4170W2AA Washer
General Electric WPSF5170W0AA Washer
General Electric WPSF5170W0WW Washer
General Electric WPSF5170W1AA Washer
General Electric WPSF5170W1WW Washer
Whirlpool WPSHAW0 PURE DELIVERY WATER PUMP
General Electric WPSL3120W0WW Washer
General Electric WPSL3120W2WW Washer
General Electric WPSP4170W0WW Washer
General Electric WPSP4170W1WW Washer
General Electric WPSQ3120T2AA Washer
General Electric WPSQ3120T2WW Washer
General Electric WPSQ3120T5AA Washer
General Electric WPSQ3120T5WW Washer
General Electric WPSQ3120T6AA Washer
General Electric WPSQ3120T6WW Washer
General Electric WPSQ3120T8AA Washer
General Electric WPSQ3120T8WW Washer
General Electric WPSQ3120T9AA Washer
General Electric WPSQ3120T9WW Washer
General Electric WPSQ3120TAAA Washer
General Electric WPSQ3120TAWW Washer
General Electric WPSQ4160T2AA Washer
General Electric WPSQ4160T2WW Washer
General Electric WPSQ4160T5AA Washer
General Electric WPSQ4160T5WW Washer
General Electric WPSQ4160T6AA Washer
  #2 (permalink)
Old 02-17-2017, 07:47 PM
Senior Member
PNWDrew is on a distinguished road
Default
You need 120VAC coming into main pcb, it supplies the 12 and 5 VDC to the UI display.
Do as much of this as you can by checking continuity on an unplugged machine. It is easy to get shocked or short a component out while working live.If you have any rubber or non-conductive gloves that would help protect you from a shock, use them. Believe me, you can get a bad shock from 120v.
That 120v first goes through the filter. That's my guess for your issue. Part # 241 on the diagram below. It's the small whitish plastic box under the console. It's probably upside down. The power cord will go to it. access it and verify that the fuse on it is closed (passing current) by checking continuity across the fuse built on the filter. It may have a layer of epoxy on it so try to make sure you are contacting the actual metal. If no continuity that is your issue, or at least the 1st issue as something may have caused it to blow. If you feel brave you can check this live by checking for potential across that fuse. Put a probe on both ends while the machine is plugged in, if the meter reads 0 the fuse is good, if it reads 120 it is not. It is not replaceable unfortunately.
If no continuity and you are feeling brave you can jump across the fuse with a short length of wire. Alligator clips are nice for this task. Once you are sure the wire is securely jumping the fuse plug it back in and see if it's alive. IF this gets action try to run and spin cycle or other test.
If no life at that point, unplug it again while you access the main pcb. Part # 60. It's the larger white plastic box and may also be upside down and have a cover. Make sure it is propped up securely then plug the machine in and see if the wires leading from the filter to it are delivering 120v. I think there should be a red led on the main pcb when it is powered up. If the main pcb is getting 120v from the filter and you have no lights on the User Interface (UI) you usually have a bad main pcb.
If you are truly motivated you can try to see if the DC transformer has failed by looking for 5 or 1 2VDC going to the UI or other components, but it doesn't matter as that isn't easily repairable unless you have some electronics knowledge.
Parts for GE WPGT9150H0MG: Controls, Backsplash & Top Panel Parts - AppliancePartsPros.com
  #3 (permalink)
Old 02-18-2017, 11:14 AM
Junior Member
Default Power issues
PNWDrew, thank you for the response and effort here! I will walk through your steps and see if i can narrow down the issue. I am not feeling that brave to check anything while its live, but will test what I can. Thanks again....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Front Loader, no power Sean1981 Washer Repair 3 05-22-2014 01:36 PM
no power to front loader millerjd1311 Washer Repair 1 05-23-2012 02:41 PM
Help request. Samsung Front loader. Zero Power chinaonnitrous1 Washer Repair 0 12-31-2010 07:34 PM
frigidaire front loader power but not action ladyred1101 Washer Repair 7 10-26-2010 02:23 PM
No Power to Kenmore Oasis Elite Top Loader Sticks1947 Washer Repair 25 12-14-2008 06:15 AM
