Discuss
Whirlpool washer wont drain or spin
 in
Washer Repair
My very old washer will not spin or drain. It does agitate but stops right after the agitation. It has
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer wont drain or spin
  #1 (permalink)
Old 02-15-2017, 08:59 PM
Junior Member
nancyelaine is on a distinguished road
Default Whirlpool washer wont drain or spin
Model Number: A5400XSNO   Brand: Whirlpool   Age: More than 10 years
My very old washer will not spin or drain. It does agitate but stops right after the agitation. It has worked great up until today. I have not problems for 20 20 years. Any videos on how to fix?
thanks
Nancy
Related Models
Admiral A54F-5TKXW-R WALLOVEN- S/C GAS
Admiral A54F-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FK-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FN-5TKVW-R WALLOVEN- S/C GAS
Admiral A54FN-5TKVWM-R WALLOVEN- S/C MWAVE GAS
Admiral A5651XRS RANGE- D/I CONT CLEAN ELE
Admiral A5892XRS RANGE- S/C D/I ELE
Admiral A5898VRV RANGE- S/C D/I ELE
Admiral A5898XRB RANGE- S/C D/I ELE
Admiral A59-5EXW-R WALLOVEN- S/C ELE
Maytag A590 WASHER-TOP LOADING
Maytag A5910 WASHER-TOP LOADING
Admiral A59E-5EXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59FN-5TVW-R WALLOVEN- S/C ELE
Admiral A59FN-5TVWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59G-5TXW-R RANGE- F/S STD ELE
Admiral A59GN-5TVW-R RANGE- F/S STD ELE
Frigidaire A5LECC2 Frg(v3) / Room Air Conditioner
Frigidaire A5LECDC2 Frg(v4) / Room Air Conditioner
Frigidaire A5LECDD2 Frg(v13) / Room Air Conditioner
Frigidaire A5LECDSD2 Frg(v14) / Room Air Conditioner
Frigidaire A5LECUC2 Frg(v12) / Room Air Conditioner
Maytag A606 WASHER-TOP LOADING
Maytag A606S WASHER-TOP LOADING
Maytag A608 WASHER-TOP LOADING
Maytag A608S WASHER-TOP LOADING
Maytag A610 WASHER-TOP LOADING
Maytag A612 WASHER-TOP LOADING
Maytag A612S WASHER-TOP LOADING
Maytag A613 WASHER-TOP LOADING
Admiral A6257XRS RANGE- S/I CONT CLEAN GAS
Jenn-Air A626B MISC / ACCESSORY
Jenn-Air A627W MISC / ACCESSORY
Admiral A6498VRV RANGE- S/C S/I GAS
Admiral A6498XRS RANGE- S/C S/I GAS
Admiral A64HN-4TKVW-R RANGE- S/C S/I GAS
Admiral A6892XRS RANGE- S/C S/I ELE
Admiral A6898VRV RANGE- S/C S/I ELE
Admiral A6898XRB RANGE- S/C S/I ELE
Admiral A68HK-6TXW-R RANGE- S/C S/I ELE
Maytag A6910 WASHER-TOP LOADING
Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag A700 WASHER-TOP LOADING
Maytag A700S WASHER-TOP LOADING
Maytag A702 WASHER-TOP LOADING
Maytag A702S WASHER-TOP LOADING
Maytag A710 WASHER-TOP LOADING
Maytag A710S WASHER-TOP LOADING
Maytag A712 WASHER-TOP LOADING
Maytag A7300 WASHER-TOP LOADING
Maytag A7400 WASHER-TOP LOADING
Maytag A7500 WASHER-TOP LOADING
Maytag A7500S WASHER-TOP LOADING
Maytag A7500W WASHER-TOP LOADING
Maytag A7800 WASHER-TOP LOADING
Admiral A79E-5CXW WALLOVEN- S/C ELE
Admiral A79F-5EXW-R WALLOVEN- S/C ELE
Admiral A79FN-5EVW-R WALLOVEN- S/C ELE
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 WASHER-TOP LOADING
Maytag A806S WASHER-TOP LOADING
Maytag A810 WASHER-TOP LOADING
Maytag A8100 WASHER-TOP LOADING
Maytag A8120 WASHER-TOP LOADING
Maytag A8140 WASHER-TOP LOADING
Maytag A8200 WASHER-TOP LOADING
Maytag A8210 WASHER-TOP LOADING
Admiral A8210PA SURFACE UNIT- GAS
Admiral A8210PA-L SURFACE UNIT- GAS
Admiral A8210PT-L SURFACE UNIT- GAS
Admiral A8210PW SURFACE UNIT- GAS
Admiral A8210PW-L SURFACE UNIT- GAS
Admiral A8211PA SURFACE UNIT- GAS
Admiral A8211PS SURFACE UNIT- GAS
Admiral A8211PW SURFACE UNIT- GAS
Maytag A8240 WASHER-TOP LOADING
Admiral A8241RA SURFACE UNIT- GAS
Admiral A8241RA-L SURFACE UNIT- GAS
Admiral A8241RS SURFACE UNIT- GAS
Admiral A8241RT-L SURFACE UNIT- GAS
Admiral A8241RV SURFACE UNIT- GAS
Admiral A8241RW SURFACE UNIT- GAS
Admiral A8241RW-L SURFACE UNIT- GAS
Admiral A8261RB SURFACE UNIT- GAS
Admiral A8261RV SURFACE UNIT- GAS
Admiral A82LK-3K-R SURFACE UNIT- GAS
Admiral A82LN-3K-R SURFACE UNIT- GAS
Admiral A82LW-2K-R SURFACE UNIT- GAS
Admiral A8321PA SURFACE UNIT- GAS
Admiral A8321PS SURFACE UNIT- GAS
Admiral A8321PW SURFACE UNIT- GAS
Admiral A8321TA-L SURFACE UNIT- GAS
Admiral A8321TW-L SURFACE UNIT- GAS
Maytag A8340 WASHER-TOP LOADING
Maytag A8420 WASHER-TOP LOADING
Maytag A8440 WASHER-TOP LOADING
Maytag A8500 WASHER-TOP LOADING
Maytag A8520 WASHER-TOP LOADING
Maytag A8600 WASHER-TOP LOADING
Admiral A8610PA SURFACE UNIT- ELE
Admiral A8610PS SURFACE UNIT- ELE
Admiral A8610PV SURFACE UNIT- ELE
Maytag A8640 WASHER-TOP LOADING
Maytag A8650 WASHER-TOP LOADING
Admiral A8670PB SURFACE UNIT- ELE
Admiral A8670PV SURFACE UNIT- ELE
Admiral A86LW-1-R SURFACE UNIT- ELE
Maytag A8700 WASHER-TOP LOADING
Admiral A8720PA SURFACE UNIT- ELE
Admiral A8720PW SURFACE UNIT- ELE
Maytag A8740 WASHER-TOP LOADING
  #2 (permalink)
Old 02-16-2017, 01:16 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Could this be your model number?
LA5400XSW0
I'm wondering if it could be your lid switch? Does your lid switch "click" when you close the lid?
  #3 (permalink)
Old 02-16-2017, 06:47 AM
Junior Member
Default
yes, it used to click now that you mentioned it but it does not now.
  #4 (permalink)
Old 02-16-2017, 02:14 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
If that is the correct model number, this should be your switch.
Whirlpool W10820036 Switch-Lid - AppliancePartsPros.com
  #5 (permalink)
Old 02-16-2017, 06:44 PM
Junior Member
Default
Well, I will try it. Cheaper then buying a new one!
  #6 (permalink)
Old 02-16-2017, 06:49 PM
Junior Member
Default
I re-checked and the model is LA5400XSNO.
  #7 (permalink)
Old 02-16-2017, 11:20 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
I'm pretty sure the second to last number is color code.
"W" is for white
Yours is "N". I can't remember what "N" stood for. What color is your washer? Is it Kind of a tan color?
The part should be the same, no matter the case color.
  #8 (permalink)
Old 02-21-2017, 05:40 PM
Junior Member
Default
It is sort of tan, yellowish. I know it is old. Trying to figure out if it is worth fixing.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer will drain but wont spin suzyscott Washer Repair 3 10-04-2012 05:20 PM
whirlpool washer will agitate, but wont spin or drain robert garbacz Washer Repair 5 04-11-2011 07:26 AM
Whirlpool Washer wont spin or drain kass0063@aol.com Washer Repair 0 05-31-2010 02:47 PM
whirlpool washer wont spin but will drain charlissa Washer Repair 1 10-21-2009 04:03 AM
