Samsung Top Load Washer starts to fill then stops, code nF
Washer Repair
Hello, Hoping someone here has some advice for me. Recently my Samsung top load washer stopped filling during most of
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Samsung Top Load Washer starts to fill then stops, code nF
  #1 (permalink)
Old 02-15-2017, 08:52 AM
Junior Member
chris603 is on a distinguished road
Default Samsung Top Load Washer starts to fill then stops, code nF
Model Number: WA5451ANW/XAA   Brand: Samsung   Age: 1 - 5 years
Hoping someone here has some advice for me. Recently my Samsung top load washer stopped filling during most of the wash cycles.
Here is what happens:
  1. Power on
  2. Fill washer with clothes/detergent
  3. Close lid
  4. Select wash (Normal is most frequently used)
  5. Washer drains tub of leftover water
  6. Washer starts to fill/spin tub at same time
  7. About 45 seconds later washer stops filling (tub still spins)
  8. ~6 minutes later the nF code is thrown because water level hasn't changed
Here are the things I have done so far:
  • Pull/clean/replace the intake screens (no issues)
  • Run through the quick tests - all seems good i think?
  • Replaced the water level sensor with one from APP.com (just the sensor, not the hose itself due to time restraints)
Nothing I have done has changed anything. The washer still starts to fill and then stops. I don't think its the lid switch and here is why, if I set it to rinse/spin it will fill the entire tub (almost overfill) and it will run the entire cycle. I don't think it would run if the lid switch was bad, could be wrong?
Any help is greatly appreciated. Thanks!
Related Models
Frigidaire WA5800ADD1 Frg(v4) / 27 " Washer
Frigidaire WA5800ADD2 Frg(v4) / 27 " Washer
Frigidaire WA5800ADD3 Frg(v1) / 27 " Washer
Frigidaire WA5800AWW1 Frg(v3) / 27 " Washer
Frigidaire WA5800AWW2 Frg(v3) / 27 " Washer
Frigidaire WA5800AWW3 Frg(v2) / 27 " Washer
Frigidaire WA5800RW1 Frg(v2) / 27 " Washer
Frigidaire WA5820RW1 Frg(v1) / 27 " Washer
Frigidaire WA5820RW2 Frg(v1) / 27 " Washer
Frigidaire WA6500ADD1 Frg(v2) / 27 " Washer
Frigidaire WA6500ADD2 Frg(v2) / 27 " Washer
Frigidaire WA6500ADD3 Frg(v3) / 27 " Washer
Frigidaire WA6500AWW1 Frg(v1) / 27 " Washer
Frigidaire WA6500AWW2 Frg(v1) / 27 " Washer
Frigidaire WA6500AWW3 Frg(v4) / 27 " Washer
Frigidaire WA6520AL1 Frg(v2) / 27 " Washer
Frigidaire WA6520AL2 Frg(v2) / 27 " Washer
Frigidaire WA6520AW1 Frg(v1) / 27 " Washer
Frigidaire WA6520AW2 Frg(v1) / 27 " Washer
Frigidaire WA6620RW1 Frg(v1) / 27 " Washer
Frigidaire WA6620RW2 Frg(v1) / 27 " Washer
Frigidaire WA6900RW1 Frg(v3) / 27 " Washer
Frigidaire WA7200ADD1 Frg(v2) / 27 " Washer
Frigidaire WA7200ADD2 Frg(v2) / 27 " Washer
Frigidaire WA7200ADD3 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW1 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW2 Frg(v1) / 27 " Washer
Frigidaire WA7200AWW3 Frg(v2) / 27 " Washer
Frigidaire WA7400PW0 Frg(v1) / 27 " Washer
Frigidaire WA7400PW1 Frg(v1) / 27 " Washer
Frigidaire WA7400PW2 Frg(v2) / 27 " Washer
Frigidaire WA8600PW0 Frg(v1) / 27 " Washer
Frigidaire WA8600PW1 Frg(v1) / 27 " Washer
Frigidaire WA8600PW2 Frg(v2) / 27 " Washer
Frigidaire WA8800PW0 Frg(v1) / 27 " Washer
Frigidaire WA8800PW1 Frg(v1) / 27 " Washer
Frigidaire WA8800PW2 Frg(v2) / 27 " Washer
Frigidaire WAA053M7A1 White Westinghouse Air Conditioner
White Westinghouse WAA060M7C1 White Westinghouse/air Conditioner
Frigidaire WAB057P7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067F7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAB067F7B2 Wwh(v0) / Room Air Conditioner
Frigidaire WAB067P7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067T7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB067W7B1 Wwh(v0) / Air Conditioner
Frigidaire WAB077F7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAB077F7B3 Wwh(v0) / Room Air Conditioner
Frigidaire WAB077S7B1 Wwh(v1) / Room Air Conditioner
Frigidaire WAB077Y7B1 Wwh(v0) / Room Air Conditioner
Frigidaire WAC051P7Z1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC051P7Z2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC051T7Z1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC051T7Z2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC051T7Z2A Wwh(v0) / Room Air Conditioner
Frigidaire WAC051T7Z2B Wwh(v0) / Room Air Conditioner
Frigidaire WAC051T7Z5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052G7A1 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052G7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052G7A3 Wwh(v0) / Room Air Conditioner
White Westinghouse WAC052K7A1 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A2 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A4 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A6 White Westinghouse/air Conditioner
White Westinghouse WAC052K7A7 White Westinghouse/air Conditioner
Frigidaire WAC052P7A1 Wwh(v2) / Room Air Conditioner
Frigidaire WAC052T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC052T7A2A Wwh(v0) / Room Air Conditioner
Frigidaire WAC052T7A2B Wwh(v0) / Room Air Conditioner
Frigidaire WAC052T7A3 Wwh(v2) / Room Air Conditioner
Frigidaire WAC052T7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC052T7A6 Wwh(v0) / Air Conditioner
White Westinghouse WAC053K7A1 White Westinghouse/air Conditioner
White Westinghouse WAC053L7A1 White Westinghouse/air Conditioner
Frigidaire WAC053S7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053S7A4 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A2A Wwh(v0) / Room Air Conditioner
Frigidaire WAC053T7A3 Wwh(v2) / Room Air Conditioner
Frigidaire WAC053T7A4 Wwh(v1) / Room Air Conditioner
Frigidaire WAC053T7A5 Wwh(v2) / Room Air Conditioner
Frigidaire WAC053T7A6 Wwh(v2) / Room Air Conditioner
Frigidaire WAC056F7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC056P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC056P7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC056T7A1 Wwh(v3) / Room Air Conditioner
Frigidaire WAC056W7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC056W7A5A Wwh(v0) / Room Air Conditioner
White Westinghouse WAC060K7A1 White Westinghouse/air Conditioner
Frigidaire WAC060K7A2
White Westinghouse WAC061L7A1 White Westinghouse/air Conditioner
Frigidaire WAC062P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063S7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063S7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC063T7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC063T7A5A Wwh(v0) / Room Air Conditioner
Frigidaire WAC066F7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC066F7A3 Wwh(v0) / Room Air Conditioner
Frigidaire WAC067P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC067P7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC067T7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC067W7A1 Wwh(v0) / Room Air Conditioner
Frigidaire WAC067W7A5 Wwh(v0) / Room Air Conditioner
Frigidaire WAC067W7A5A Wwh(v0) / Room Air Conditioner
Frigidaire WAC072P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073S7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073T7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073W7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC073W7A5A Wwh(v0) / Room Air Conditioner
Frigidaire WAC077T7A2 Wwh(v2) / Room Air Conditioner
Frigidaire WAC082G7A2 Wwh(v0) / Room Air Conditioner
Frigidaire WAC082G7A8 Wwh(v0) / Room Air Conditioner
White Westinghouse WAC083K7A1 White Westinghouse/air Conditioner
White Westinghouse WAC083K7A2 White Westinghouse/air Conditioner
White Westinghouse WAC083K7A4 White Westinghouse/air Conditioner
White Westinghouse WAC083K7A5 White Westinghouse/air Conditioner
Frigidaire WAC083S7A1 Wwh(v1) / Room Air Conditioner
Frigidaire WAC083S7A2 Wwh(v1) / Room Air Conditioner
Frigidaire WAC083T7A2 Wwh(v1) / Room Air Conditioner
  #2 (permalink)
Old 02-16-2017, 05:17 AM
Junior Member
Bumping this, anyone have any ideas?
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer starts to fill then stops lights blinking Katmat Washer Repair 1 06-27-2012 07:45 PM
washer starts to fill then stops richie33 Dishwasher Repair 2 11-03-2011 08:32 PM
washer starts to fill then stops richie33 Washer Repair 1 08-31-2011 06:40 PM
Roper washer starts to fill and stops phish_phinder Washer Repair 6 01-17-2011 11:22 AM
front load washer starts and stops immediately sunshine Washer Repair 1 01-12-2010 09:48 AM
