Discuss
Replaced the bearings and seal now will not agitate
 in
Washer Repair
My whirlpool washer was leaking in the bottom center where the agitator is. With research I found that it was
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Replaced the bearings and seal now will not agitate
  #1 (permalink)
Old 02-06-2017, 03:55 PM
Junior Member
Lamb3 is on a distinguished road
Default Replaced the bearings and seal now will not agitate
Model Number: Wtw6200vw0   Brand: Whirlpool   Age: 1 - 5 years
My whirlpool washer was leaking in the bottom center where the agitator is. With research I found that it was the main tub seal and bearings. So we replaced the kit easily. But once we put on the old motor stator it wouldn't move freely. We tried it anyways. And the leak is fixed but will not agitate. Is it possible that the stator (which worked before the repair) (and was wet :/ when we pulled it off to be repaired) dried out while waiting for the part and now has swollen and no longer works?
Related Models
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Whirlpool WTW6600SG2 AUTOMATIC WASHER
Whirlpool WTW6600SG3 AUTOMATIC WASHER
Whirlpool WTW6600SW0 AUTOMATIC WASHER
Whirlpool WTW6600SW1 AUTOMATIC WASHER
Whirlpool WTW6600SW2 AUTOMATIC WASHER
Whirlpool WTW6600SW3 AUTOMATIC WASHER
Whirlpool WTW6700TU1 AUTOMATIC WASHER
Whirlpool WTW6700TU2 AUTOMATIC WASHER
Whirlpool WTW6700TW0 AUTOMATIC WASHER
Whirlpool WTW6700TW1 AUTOMATIC WASHER
Whirlpool WTW6700TW2 AUTOMATIC WASHER
Whirlpool WTW6800WB1 AUTOMATIC WASHER
Whirlpool WTW6800WE1 RESIDENTIAL WASHER
Whirlpool WTW6800WL1 AUTOMATIC WASHER
Whirlpool WTW6800WU1 RESIDENTIAL WASHER
Whirlpool WTW6800WW1 AUTOMATIC WASHER
Whirlpool WTW7300XW0 AUTOMATIC WASHER
Whirlpool WTW7300XW1 AUTOMATIC WASHER
Whirlpool WTW7300XW2 AUTOMATIC WASHER
Whirlpool WTW7320YW0 WASHER
Whirlpool WTW7340XW0 AUTOMATIC WASHER
Whirlpool WTW7340XW1 AUTOMATIC WASHER
Whirlpool WTW7340XW2 AUTOMATIC WASHER
Whirlpool WTW7600XW0 AUTOMATIC WASHER
Whirlpool WTW7600XW1 AUTOMATIC WASHER
Whirlpool WTW7600XW2 AUTOMATIC WASHER
Whirlpool WTW7800XB0 AUTOMATIC WASHER
Whirlpool WTW7800XB1 AUTOMATIC WASHER
Whirlpool WTW7800XB2 AUTOMATIC WASHER
Whirlpool WTW7800XB3 AUTOMATIC WASHER
Whirlpool WTW7800XB4 AUTOMATIC WASHER
Whirlpool WTW7800XL0 AUTOMATIC WASHER
Whirlpool WTW7800XL1 AUTOMATIC WASHER
Whirlpool WTW7800XL2 AUTOMATIC WASHER
Whirlpool WTW7800XL3 AUTOMATIC WASHER
Whirlpool WTW7800XL4 AUTOMATIC WASHER
Whirlpool WTW7800XW0 AUTOMATIC WASHER
Whirlpool WTW7800XW1 AUTOMATIC WASHER
Whirlpool WTW7800XW2 AUTOMATIC WASHER
Whirlpool WTW7800XW3 AUTOMATIC WASHER
Whirlpool WTW7800XW4 AUTOMATIC WASHER
Whirlpool WTW7990XG0 AUTOMATIC WASHER
Whirlpool WTW7990XG1 AUTOMATIC WASHER
Whirlpool WTW8200YW0 AUTOMATIC WASHER
Whirlpool WTW8240YW0 AUTOMATIC WASHER
Whirlpool WTW8600YW0 AUTOMATIC WASHER
Whirlpool WTW8800YC0 WASHER
Whirlpool WTW8800YW0 WASHER
Bosch WTZ1170
Bosch WTZ1210
Roper WU0800B UNDERCOUNTER DISHWASHER
Roper WU0800XX0 Dishwasher
Roper WU0800XX1 UNDERCOUNTER DISHWASHER
Maytag WU100 DISHWASHER- UNDERCOUNTER
Maytag WU1000 DISHWASHER- UNDERCOUNTER
Roper WU1000X0 Dishwasher
Roper WU1000X1 Dishwasher
Roper WU1000X4 Dishwasher
Roper WU1000X5 Dishwasher
Roper WU1000X6 Dishwasher
Roper WU1000X7 Dishwasher
Roper WU1000X8 Dishwasher
Roper WU1000Y0 UNDERCOUNTER DISHWASHER
Roper WU1000Y1 UNDERCOUNTER DISHWASHER
Maytag WU1004 DISHWASHER- UNDERCOUNTER
Maytag WU1005 DISHWASHER- UNDERCOUNTER
Maytag WU101 DISHWASHER- UNDERCOUNTER
Maytag WU103 DISHWASHER- UNDERCOUNTER
Maytag WU104 DISHWASHER- UNDERCOUNTER
Maytag WU180 DISHWASHER- UNDERCOUNTER
Roper WU1800XX0 Dishwasher
Frigidaire WU180T1BLACK Wwh(v5) / 18 " Dishwasher
Frigidaire WU180TF1 Wwh(v3) / 18 " Dishwasher
Frigidaire WU180TH1 Wwh(v2) / 18 " Dishwasher
Frigidaire WU180TR1 Wwh(v1) / 18 " Dishwasher
Frigidaire WU180TV1 Wwh(v4) / 18 " Dishwasher
Frigidaire WU180TW1 Wwh(v6) / 18 " Dishwasher
Maytag WU181 DISHWASHER- UNDERCOUNTER
Maytag WU200 DISHWASHER- UNDERCOUNTER
Maytag WU201 DISHWASHER- UNDERCOUNTER
Maytag WU202 DISHWASHER- UNDERCOUNTER
Maytag WU203 DISHWASHER- UNDERCOUNTER
Maytag WU204 DISHWASHER- UNDERCOUNTER
Maytag WU282 DISHWASHER- UNDERCOUNTER
Maytag WU284 DISHWASHER- UNDERCOUNTER
Maytag WU285 DISHWASHER- UNDERCOUNTER
Maytag WU300 DISHWASHER- UNDERCOUNTER
Roper WU3000V0 Dishwasher
Roper WU3000V1 Dishwasher
Roper WU3000V2 Dishwasher
Roper WU3000V3 Dishwasher
Roper WU3000X0 Dishwasher
Roper WU3000X1 Dishwasher
Roper WU3000X2 Dishwasher
Roper WU3000X3 Dishwasher
Roper WU3000X4 Dishwasher
  #2 (permalink)
Old 02-12-2017, 10:38 PM
Senior Member
PNWDrew is on a distinguished road
Default
So it tries to fill and then aborts with a F51 or other code?
Does it turn at all, basket, agitator dome or anything? If it doesn't turn at all you've misaligned something. The kit replaces the seal, top bearing, spacer, washer, bottom bearing,shaft and nut? It also requires a bearing press to align and seat the two bearings. If all is normal the shaft will spin freely in the bearings.
The same stator and rotor drive the shaft whether it's in agitation or spin. Nothing changes under the machine between spin and agitate. It's just how the PCB powers the stator. Your tub floats up on that shaft to agitate and settles back down to spin. If it cannot float it will not agitate.
Reach into it when the machine is empty and grab the basket on opposite sides, then lift. If it doesn't slide upward freely on the drive shaft about 3/4" it can't disengage from the basket drive part of the shaft and will not agitate.
If the basket moves up and down but doesn't turn, lean it back and see if the rotor turns freely from beneath. If it doesn't, remove the rotor itself, inspect the rotor and stator for damage or a screw of something stuck to the rotor magnets, and see if the shaft turns by hand.
This is the kit...
Whirlpool W10435302 Bearing and Tub Seal Kit - AppliancePartsPros.com
and this is the tool to align it all
Whirlpool W10447783 Bearing Installation Tool - AppliancePartsPros.com
I've never tried it without the tool, but it would not be fun and I would have little confidence in it. It's about a 60 minute job with the tool and decent luck getting it apart. I've done more than I can count. 2 last week alone.
Good Luck,
Drew
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bearings and Seal tophatt1949 Washer Repair 0 03-28-2011 03:09 PM
help replacing tub seal and bearings bobracko Washer Repair 2 06-26-2010 08:09 PM
tub bearings&seal replacement dquinn Washer Repair 1 02-04-2009 04:09 PM
bearings and seal Adunc Washer Repair 0 05-17-2008 09:49 AM
bearings / seal replace gandra Washer Repair 2 11-03-2007 04:59 PM
