Discuss
Belt Riding Too Close to Tub
 in
Washer Repair
Tonight I replaced the drain pump in my Maytag MAH3000AWW washing machine, I did a load of laundry and at
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Belt Riding Too Close to Tub
  #1 (permalink)
Old 02-02-2017, 09:31 PM
Junior Member
bananamber is on a distinguished road
Default Belt Riding Too Close to Tub
Model Number: MAH3000AWW   Brand: Maytag   Age: More than 10 years
Tonight I replaced the drain pump in my Maytag MAH3000AWW washing machine, I did a load of laundry and at some point the belt slipped off. I put the belt back on and ran the machine to see what was going on and the belt slid way too far inwards toward the tub.
My concern is that I noticed a fairly deep groove cut into the tub (Or whatever part that is right behind the pulley) by the belt. Unfortunately I don't know if this is a new problem or if it has been like this since I originally replaced the motor about 8 or 9 years ago.
Either way, how do I fix this issue? Any help is appreciated. Thanks!
I should probably mention that the reason I replaced the pump was because it wasn't able to pump with enough pressure. Took it apart and found out 3 out of 4 fins on the impeller were broken off (and missing) and the backflow valve was missing. So I don't think that has anything to do with the belt issue.
Related Models
Maytag MAH3000AWW WASHER- HORIZONTAL AXIS
Admiral MAH3000BGW WASHER- HORIZONTAL AXIS
Maytag MAH4000AWQ WASHER- HORIZONTAL AXIS
Maytag MAH4000AWW WASHER- HORIZONTAL AXIS
Maytag MAH4000BWQ WASHER- HORIZONTAL AXIS
Maytag MAH4000BWW WASHER- HORIZONTAL AXIS
Maytag MAH5500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH5500AWW WASHER- HORIZONTAL AXIS
Maytag MAH5500BWQ WASHER- HORIZONTAL AXIS
Maytag MAH5500BWW WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWQ WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWW WASHER- HORIZONTAL AXIS
Maytag MAH6500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH6500AWW WASHER- HORIZONTAL AXIS
Maytag MAH6700AWM WASHER- HORIZONTAL AXIS
Maytag MAH6700AWW WASHER- HORIZONTAL AXIS
Maytag MAH7500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH7500AWW WASHER- HORIZONTAL AXIS
Admiral MAH7550AAW WASHER- HORIZONTAL AXIS
Admiral MAH7550AGW WASHER- HORIZONTAL AXIS
Maytag MAH8700AWM WASHER- HORIZONTAL AXIS
Maytag MAH8700AWW WASHER- HORIZONTAL AXIS
Maytag MAH9700AWM WASHER- HORIZONTAL AXIS
Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS
Maytag MAH9700AWW WASHER- HORIZONTAL AXIS
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM MISC / ACCESSORY
Maytag MAL1800AXQ MISC / ACCESSORY
Maytag MAL1800AXW MISC / ACCESSORY
Maytag MAL2000AXQ MISC / ACCESSORY
Maytag MAL2000AXW MISC / ACCESSORY
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL MANUAL, PARTS (WASHER)
Maytag MAT10CSAAW MANUAL, PARTS (WASHER)
Maytag MAT10CSAGL MANUAL, PARTS (WASHER)
Maytag MAT10CSAGW MANUAL, PARTS (WASHER)
Maytag MAT10CSEGL MANUAL, PARTS (WASHER)
Maytag MAT10CSEGW MANUAL, PARTS (WASHER)
Maytag MAT10DAAAL MANUAL, PARTS (WASHER)
Maytag MAT10DAAAW MANUAL, PARTS (WASHER)
Maytag MAT10DAABL MANUAL, PARTS (WASHER)
Maytag MAT10DAABW MANUAL, PARTS (WASHER)
Maytag MAT10PDAAL MANUAL, PARTS (WASHER)
Maytag MAT10PDAAW MANUAL, PARTS (WASHER)
Maytag MAT10PDABL MANUAL, PARTS (WASHER)
Maytag MAT10PDABW MANUAL, PARTS (WASHER)
Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER)
Maytag MAT10PSAAL MANUAL, PARTS (WASHER)
Maytag MAT10PSAAW MANUAL, PARTS (WASHER)
Maytag MAT10PSAGL MANUAL, PARTS (WASHER)
Maytag MAT10PSAGW MANUAL, PARTS (WASHER)
Maytag MAT11CSBKL MANUAL, PARTS (WASHER)
Maytag MAT11MNAAW MANUAL, PARTS (WASHER)
Maytag MAT11MNAGW MANUAL, PARTS (WASHER)
Maytag MAT11MNEGW MANUAL, PARTS (WASHER)
Maytag MAT11PDAAL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDAAW MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABW MAYTAG LAUNDRY (WASHER)
Maytag MAT12CSAAL MANUAL, PARTS (WASHER)
Maytag MAT12CSAAQ MANUAL, PARTS (WASHER)
Maytag MAT12CSAAW MANUAL, PARTS (WASHER)
Maytag MAT12CSAGW MANUAL, PARTS (WASHER)
Maytag MAT12CSAKL MANUAL, PARTS (WASHER)
Maytag MAT12CSAKQ MANUAL, PARTS (WASHER)
Maytag MAT12CSDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSEGW MANUAL, PARTS (WASHER)
Maytag MAT12CSFWQ COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSFWW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLGW MAYTAG COMMERCIAL WASHER (WASHER)
Maytag MAT12CSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDAAL MANUAL, PARTS (WASHER)
Maytag MAT12PDAAW MANUAL, PARTS (WASHER)
Maytag MAT12PDABL MANUAL, PARTS (WASHER)
Maytag MAT12PDABW MANUAL, PARTS (WASHER)
Maytag MAT12PDAGW MANUAL, PARTS (WASHER)
Maytag MAT12PDBAL MANUAL, PARTS (WASHER)
Maytag MAT12PDBAQ MANUAL, PARTS (WASHER)
Maytag MAT12PDBAW MANUAL, PARTS (WASHER)
Maytag MAT12PDBBL MANUAL, PARTS (WASHER)
Maytag MAT12PDBBQ WASHER-TOP LOADING
Maytag MAT12PDBBW MANUAL, PARTS (WASHER)
Maytag MAT12PDCBL MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDBW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDEGW MANUAL, PARTS (WASHER)
Maytag MAT12PDLAQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLAW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLGW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDSAW MANUAL,PARTS (WASHER)
Maytag MAT12PRAAW MANUAL, PARTS (WASHER)
Maytag MAT12PRAEW MANUAL, PARTS (WASHER)
Maytag MAT12PRBAW MANUAL, PARTS (WASHER)
Maytag MAT12PRDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PRSAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAGW MANUAL, PARTS (WASHER)
Maytag MAT12PSBAW MANUAL, PARTS (WASHER)
Maytag MAT12PSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT13MNAAW MANUAL, PARTS (WASHER)
Maytag MAT13MNAGW MANUAL, PARTS (WASHER)
Maytag MAT13MNDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNEGW MANUAL, PARTS (WASHER)
Maytag MAT13PDAAW MANUAL, PARTS (WASHER)
Maytag MAT13PDBAW MANUAL, PARTS (WASHER)
Maytag MAT13PNAEW MAYTAG LAUNDRY (WASHER)
Maytag MAT13PNDEW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13PRBWW MAYTAG LAUNDRY (WASHER)
Maytag MAT14CSAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSAWW0 COMMERCIAL AUTOMATIC WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
WED7500VW belt replacement (no belt tensioner) dafoster78 Dryer Repair 1 12-30-2016 04:14 PM
Amana Washing Machine Drive Belt Slipping after Belt and Idler Spring replacement tjensen47 Washer Repair 1 12-04-2014 01:36 PM
Changing tranny belt and pump belt hard? g20zoom Washer Repair 0 05-31-2012 12:02 AM
motor turns easily when I pull belt, but fault code manual says to remove belt first kenrepair Washer Repair 0 10-21-2010 06:58 AM
Amana top load belt broke, new belt smokes mikeyfz Washer Repair 1 08-28-2010 05:46 PM
