kudrat
#1 Posted : Wednesday, February 1, 2017 8:35:01 AM(UTC)
kudrat
Drain and spin in normal cycle not functioning. I have to turn the knob to drain and spin option. What part i need to replace?
PNWDrew
#2 Posted : Monday, February 6, 2017 10:38:04 AM(UTC)
PNWDrew
The washer has an error code recall function, to see them you'd need to enter diagnostics. That would be helpful and likely easier than me asking you 4-5 questions.
https://www.youtube.com/watch?v=oBihToN6dxs This is same process for you.
Here it is on paper.
https://www.manualslib.com/manua...800xq.html?page=3#manual
Might be easier to follow. Pg 3 for how to enter. Codes start on Pg 6. Each code is "FxEx" with "x" being a #. The grey/white squares shown with each error are the lights flashing under your knob to ID the error if you do not have a display.
Don't base a repair strictly on a code, they are not all as cut and dry as they seem.
