Discuss
noise in washer
 in
Washer Repair
My washer makes a loud noise when it goes into spin cycle; but it doesn't spin unless I lift the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » noise in washer
  #1 (permalink)
Old 01-30-2017, 03:34 PM
Junior Member
mvm150 is on a distinguished road
Default noise in washer
Model Number: LSN2000PW3   Brand: Whirlpool   Age: 5 - 10 years
My washer makes a loud noise when it goes into spin cycle; but it doesn't spin unless I lift the lid until it quits making the the noise and then when I shut the lid it starts spinning and sounds normal. I replaced the transmission because it was leaking oil on the floor and I thought it might be what was causing the problem. The noise was still there after replacing the trans so I replaced the basket drive assembly, the washer drive block and and the brake and drum assembly along with both coupler assemblies and it still does the same thing. It sounds like the transmission is whining trying to get into gear but it's new?
Related Models
Whirlpool LSN2000PW3 AUTOMATIC WASHER
Whirlpool LSN2000PW4 AUTOMATIC WASHER
 LSN240HE Air Conditioner
 LSN242CE Air Conditioner
 LSN242HE Air Conditioner
Whirlpool LSN3000PG0 AUTOMATIC WASHER
Whirlpool LSN3000PG1 AUTOMATIC WASHER
Whirlpool LSN3000PG2 AUTOMATIC WASHER
Whirlpool LSN3000PG3 AUTOMATIC WASHER
Whirlpool LSN3000PG4 AUTOMATIC WASHER
Whirlpool LSN3000PW0 AUTOMATIC WASHER
Whirlpool LSN3000PW1 AUTOMATIC WASHER
Whirlpool LSN3000PW2 AUTOMATIC WASHER
Whirlpool LSN3000PW3 AUTOMATIC WASHER
Whirlpool LSN3000PW4 AUTOMATIC WASHER
 LSN301HE Air Conditioner
Whirlpool LSN7233BN0
Whirlpool LSN7233BN1
Whirlpool LSN7233BQ0
Whirlpool LSN7233BQ1
Whirlpool LSN7233BW0
Whirlpool LSN7233BW1
Whirlpool LSN7233DQ0
Whirlpool LSN7233DW0
Whirlpool LSN8244AN0
Whirlpool LSN8244AQ0
Whirlpool LSN8244AW0
Whirlpool LSN8244BN0
Whirlpool LSN8244BQ0
Whirlpool LSN8244BW0
 LSNC183VMA Air Conditioner
 LSNJ0910CL Air Conditioner
Whirlpool LSP6244AG0
Whirlpool LSP6244AN0
Whirlpool LSP6244AW0
Whirlpool LSP6244BG0
Whirlpool LSP6244BN0
Whirlpool LSP6244BW0
Whirlpool LSP8244BG0
Whirlpool LSP8244BG1
Whirlpool LSP8244BN0
Whirlpool LSP8244BN1
Whirlpool LSP8244BW0
Whirlpool LSP8244BW1
Whirlpool LSP8245AN0
Whirlpool LSP8245AW0
Whirlpool LSP8245BN0
Whirlpool LSP8245BW0
Whirlpool LSP9245BN0
Whirlpool LSP9245BN1
Whirlpool LSP9245BW0
Whirlpool LSP9245BW1
Whirlpool LSP9355AG0
Whirlpool LSP9355AN0
Whirlpool LSP9355AW0
Whirlpool LSP9355BN0 AUTOMATIC WASHER
Whirlpool LSP9355BN1
Whirlpool LSP9355BW0 AUTOMATIC WASHER
Whirlpool LSP9355BW1
Whirlpool LSQ7030KQ0 WASHER
Whirlpool LSQ7030LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ7030LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ7030MQ0 AUTOMATIC WASHER
Whirlpool LSQ7533JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ7533JQ1 WASHER
Whirlpool LSQ7533JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ7533JT1 WASHER
Whirlpool LSQ8000HQ0 WASHER
Whirlpool LSQ8000JQ0 WASHER
Whirlpool LSQ8000JQ1 WASHER
Whirlpool LSQ8000LQ0 WASHER
Whirlpool LSQ8000LQ1 AUTOMATIC WASHER
Whirlpool LSQ8000LQ2 AUTOMATIC WASHER
Whirlpool LSQ8000LQ3 AUTOMATIC WASHER
Whirlpool LSQ8200HQ0 AUTOMATIC WASHER
Whirlpool LSQ8200HZ0 AUTOMATIC WASHER
Whirlpool LSQ8220HQ0 AUTOMATIC WASHER
Whirlpool LSQ8243HQ0 AUTOMATIC WASHER
Whirlpool LSQ8243HZ0 AUTOMATIC WASHER
Whirlpool LSQ8500JQ0 AUTOMATIC WASHER
Whirlpool LSQ8500JQ1 WASHER
Whirlpool LSQ8500JQ2 WASHER
Whirlpool LSQ8500JT0 AUTOMATIC WASHER
Whirlpool LSQ8500JT1 WASHER
Whirlpool LSQ8500JT2 WASHER
Whirlpool LSQ8500LQ0 AUTOMATIC WASHER
Whirlpool LSQ8510LQ0 AUTOMATIC WASHER
Whirlpool LSQ8511KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ8511KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ8512KQ0 WASHER
Whirlpool LSQ8512KT0 WASHER
Whirlpool LSQ8520JQ0 AUTOMATIC WASHER
Whirlpool LSQ8520JQ1 WASHER
Whirlpool LSQ8543JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JQ1 WASHER
Whirlpool LSQ8543JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JT1 WASHER
Whirlpool LSQ8543JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JZ1 WASHER
Whirlpool LSQ9010KQ0 WASHER
Whirlpool LSQ9010KT0 WASHER
Whirlpool LSQ9010LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LG1 AUTOMATIC WASHER
Whirlpool LSQ9010LG2 AUTOMATIC WASHER
Whirlpool LSQ9010LG3 AUTOMATIC WASHER
Whirlpool LSQ9010LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LQ1 AUTOMATIC WASHER
Whirlpool LSQ9010LQ2 AUTOMATIC WASHER
Whirlpool LSQ9010LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LW1 AUTOMATIC WASHER
Whirlpool LSQ9010LW2 AUTOMATIC WASHER
Whirlpool LSQ9010LW3 AUTOMATIC WASHER
Whirlpool LSQ9010PG0 AUTOMATIC WASHER
Whirlpool LSQ9010PG1 AUTOMATIC WASHER
Whirlpool LSQ9010PG2 AUTOMATIC WASHER
Whirlpool LSQ9010PG3 AUTOMATIC WASHER
Whirlpool LSQ9010PG5 AUTOMATIC WASHER
Whirlpool LSQ9010PG6 AUTOMATIC WASHER
Whirlpool LSQ9010PW0 AUTOMATIC WASHER
Whirlpool LSQ9010PW1 AUTOMATIC WASHER
  #2 (permalink)
Old 01-30-2017, 04:11 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Just a quick question, what is the temperature in the room where the washer is?
  #3 (permalink)
Old 01-30-2017, 05:54 PM
Junior Member
Default washer
around 70 degrees
  #4 (permalink)
Old 02-04-2017, 11:52 AM
Senior Member
PNWDrew is on a distinguished road
Default
Sounds like it's in neutral drain, a normal stage of the cycle. All Whirlpool direct drive transmissions have a neutral drain stage, however many older transmissions do not do it well or have stopped doing it.
1)The timer ends agitation and reverses the motor.
2)It pumps out but trans remains in nuetral. There is a distinct noise to this stage. To many it sounds like it's straining.
3)After a few minutes (it may vary by cycle) the timer briefly removes power from the motor, this switches trans into spin.
4)The timer reapplies power and it spins.
By opening the lid you are simulating #3, so when you close the lid the trans will spin. Allow it to proceed without opening the lid while making this sound, if it is pumping out normally and switches into spin on its own you're fine.
About neutral drain. It tended to fail as the trans aged and you may not have been hearing it before with the old trans. When neutral drain fails the trans flips into spin at the end of agitation or very shortly afterward and the machines spin and drain together. This put more stress on everything so there is the neutral drain stage to allow the water to pump out prior to spin.
  #5 (permalink)
Old 02-04-2017, 04:00 PM
Junior Member
Default whirlpool washer
I just replaced the transmission in the washer 2 weeks ago. the noise I hear sounds like the the transmission.
  #6 (permalink)
Old 02-04-2017, 04:07 PM
Junior Member
A few years ago the washer started making the same noise and I replaced the transmission and it fixed the problem. This time I replaced the the trans and it sounds just like the old one I took out.
  #7 (permalink)
Old 02-04-2017, 04:37 PM
Senior Member
Default
You'd have to record the noise somehow then for farther analysis. These are very simple machines and I've fixed several thousand over the years, I'd probably recognize it. Perhaps take a video with your cell phone?
Can you make it make the noise by starting it at any one point in the cycle?
  #8 (permalink)
Old 02-05-2017, 01:21 PM
Junior Member
Default whirpool washer
https://youtu.be/vjNc6iRUegM
this is the noise that it makes
  #9 (permalink)
Junior Member
  #10 (permalink)
Old 02-06-2017, 11:15 AM
Senior Member
Default
That's the neutral drain period, it should not spin immediately after agitation. There is a 1-3 minute period called neutral drain. If you still have the tech sheet that was under the console and look at the timer cam sequence you can see this period, after which the timer opens the motor circuit briefly then closes it, and that will send it into spin.
If you let it go another few minutes without opening the lid does it briefly stop, then go into spin? If not your timer may be bad if it isn't opening the circuit or the trans if it gets stuck in ND.
https://www.youtube.com/watch?v=GCLWPoEYesI
jump to 28:15 or 41:45 and let it play.
Note: This demo video has the lid switch bypassed so the machine believes the lid is closed. Most techs have a old lid switch plug wired to allow this, or you can hold the lid switch itself down with a pencil or something that fits through the hole and achieve same results.
Here's a look at the inside of the trans showing the neutral drain assembly.
https://www.youtube.com/watch?v=ieZ5y47TAMk.Skip to 2:10.
And finally here's a link to an explanation of the process by another site
https://appliantology.org/blogs/entr...-drive-washer/
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Noise G.Mathews Washer Repair 0 04-02-2015 08:47 AM
washer noise wildman_2@verizon.net Washer Repair 1 04-21-2013 09:51 AM
washer noise bill2005 Washer Repair 1 08-12-2010 06:18 PM
washer noise helen0000 Washer Repair 1 11-13-2009 04:48 PM
Washer Noise bowshooter Washer Repair 3 09-30-2009 06:07 AM
