Discuss
Maytag Bravos Drive Shaft Stuck
 in
Washer Repair
Yesterday I took my washer apart to clear the drain pump. I am now putting everything back together and the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Bravos Drive Shaft Stuck
  #1 (permalink)
Old 01-23-2017, 11:19 AM
Junior Member
Buddman72 is on a distinguished road
Default Maytag Bravos Drive Shaft Stuck
Brand: Maytag   Age: 5 - 10 years
Yesterday I took my washer apart to clear the drain pump. I am now putting everything back together and the inner tub is stuck on the drive shaft. It was difficult getting it off but after I used the car jack and 2x4 method I was able to get it loose enough to remove it. Now, I cannot make it go down any further and I am unable to screw the agitator back on. Has anybody else experienced this? Is it okay to use lubrication to get it back on?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drive shaft will not turn at all changeling Washer Repair 5 09-14-2013 06:31 PM
Drive shaft not turning donlabate Washer Repair 3 12-07-2011 07:32 PM
drive shaft removal BigBill867 Washer Repair 0 11-22-2011 08:51 AM
nut on drive shaft that holds on plastic drive gear ttzcomet Trash Compactor Repair 0 12-08-2010 05:28 PM
Leaky Tub Btm@ Drive Shaft PeterLi Washer Repair 1 10-03-2010 04:17 AM
