Discuss
2015 Whirlpool Duet won't spin at high speed, stalls w 1 min remaining, F7E9
 in
Washer Repair
Hi forum! Tons of great advice here that got me pretty damn far , but I'm still hung up. Here
Appliance Repair Forum > Appliance Repair Help > Washer Repair » 2015 Whirlpool Duet won't spin at high speed, stalls w 1 min remaining, F7E9
  #1 (permalink)
Old 01-21-2017, 07:29 PM
Junior Member
igarbo is on a distinguished road
Default 2015 Whirlpool Duet won't spin at high speed, stalls w 1 min remaining, F7E9
Model Number: WFW72HEDW0   Brand: Whirlpool   Age: 1 - 5 years
Hi forum! Tons of great advice here that got me pretty damn far , but I'm still hung up. Here are photos of my progress and the service tech book I followed
Let me try to be brief: The washer is losing its mind.
Bottom line: This newish washer won't run a normal cycle and either won't fill with water, won't spin properly or won't drain, for example:
- Sometimes I press start: then the washer locks, unlocks, locks again and shuts off
- Sometimes I press start: the washer counts down from 43, pulls in a bit of water, spins twice, stops, 3 min later spins 3 more times, then continues erratically until stalling at 1 min remaining for an hour, maybe more maybe less
Things I've checked:
- Took off the top and front
- Unscrewed the drain catch and emptied it. Dirty water, but otherwise empty (makes sense give how new this thing is)
- Unscrewed the hot and cold intake hoses, then ran water through each into a bucket. Both work great
- Pulled the drain hose out of the standpipe while washer drained. Nice full flow of water went out
- Used an voltmeter to test continuity on the Motor Circuit. Each read around 14 ohms (within the 6-20 ohm standard as shown in image of service book)
Then I got clever and found the Service Technician book, and activated Service Diagnostic Mode and ran a Quick Diagnostic Test. The results:
- C1-4: worked beautifully
- C5: Drum rotated but only for 3 spins, not 20 seconds (as expected)
- C6: Drum rotated but again very little, not for 1 min (as expected)
- C7: Drain pumped worked beautifully
- C8: Drum rotated a few spins then paused a minute, then rotated a few spins again, then paused. It did this probably 6 or 8 times.
- Completion took a while as the washer seems to hang on C8 and then the door lock led flashed for a while, seemed like 20 seconds (didn't time it)
After the Quick Diagnostic Test, I'm left with one error code: F7E9. This code isn't on the internet or in the technician's guide. I did find F07 for a different model which says it's the motor control unit.
The internet leads me to believe I either have:
- a serious issue w the motor (though this seems odd as the drum does spin some) or
- possibly it's the door, as my washer seems to be behaving really similarly to this
Can any of the studs on this forum give a recommendation?
Thanks for any help!!
Related Models
Whirlpool WFW8200TW00 AUTOMATIC WASHER
Whirlpool WFW8200TW01 AUTOMATIC WASHER
Whirlpool WFW8300SW0 AUTOMATIC WASHER
Whirlpool WFW8300SW00 RESIDENTIAL WASHER
Whirlpool WFW8300SW01 RESIDENTIAL WASHER
Whirlpool WFW8300SW02 AUTOMATIC WASHER
Whirlpool WFW8300SW03 AUTOMATIC WASHER
Whirlpool WFW8300SW04 AUTOMATIC WASHER
Whirlpool WFW8300SW05 AUTOMATIC WASHER
Whirlpool WFW8300SW1 AUTOMATIC WASHER
Whirlpool WFW8400TB00 AUTOMATIC WASHER
Whirlpool WFW8400TB01 AUTOMATIC WASHER
Whirlpool WFW8400TB02 AUTOMATIC WASHER
Whirlpool WFW8400TE00 AUTOMATIC WASHER
Whirlpool WFW8400TE01 AUTOMATIC WASHER
Whirlpool WFW8400TW00 AUTOMATIC WASHER
Whirlpool WFW8400TW01 AUTOMATIC WASHER
Whirlpool WFW8400TW02 AUTOMATIC WASHER
Whirlpool WFW8400TW03 AUTOMATIC WASHER
Whirlpool WFW8410SW0 AUTOMATIC WASHER
Whirlpool WFW8410SW01 AUTOMATIC WASHER
Whirlpool WFW8410SW02 AUTOMATIC WASHER
Whirlpool WFW8410SW03 AUTOMATIC WASHER
Whirlpool WFW8500SR0 AUTOMATIC WASHER
Whirlpool WFW8500SR01 AUTOMATIC WASHER
Whirlpool WFW8500SR02 AUTOMATIC WASHER
Whirlpool WFW8500SR03 AUTOMATIC WASHER
Whirlpool WFW8500SR04 AUTOMATIC WASHER
Whirlpool WFW9050XW00 AUTOMATIC WASHER
Whirlpool WFW9050XW01 AUTOMATIC WASHER
Whirlpool WFW9050XW02 AUTOMATIC WASHER
Whirlpool WFW9050XW03 AUTOMATIC WASHER
Whirlpool WFW9150WW00 AUTOMATIC WASHER
Whirlpool WFW9150WW01 AUTOMATIC WASHER
Whirlpool WFW9150WW02 AUTOMATIC WASHER
Whirlpool WFW9151YW00 WASHER
Whirlpool WFW9200SQ00 AUTOMATIC WASHER
Whirlpool WFW9200SQ01 AUTOMATIC WASHER
Whirlpool WFW9200SQ02 AUTOMATIC WASHER
Whirlpool WFW9200SQ03 AUTOMATIC WASHER
Whirlpool WFW9200SQ04 AUTOMATIC WASHER
Whirlpool WFW9200SQ10 AUTOMATIC WASHER
Whirlpool WFW9200SQA10 AUTOMATIC WASHER
Whirlpool WFW9200SQA11 AUTOMATIC WASHER
Whirlpool WFW9200SQA12 AUTOMATIC WASHER
Whirlpool WFW9250WL00 AUTOMATIC WASHER
Whirlpool WFW9250WL01 AUTOMATIC WASHER
Whirlpool WFW9250WL02 AUTOMATIC WASHER
Whirlpool WFW9250WR00 AUTOMATIC WASHER
Whirlpool WFW9250WR01 AUTOMATIC WASHER
Whirlpool WFW9250WR02 AUTOMATIC WASHER
Whirlpool WFW9250WW00 AUTOMATIC WASHER
Whirlpool WFW9250WW01 AUTOMATIC WASHER
Whirlpool WFW9250WW02 WASHER
Whirlpool WFW9300VU02 AUTOMATIC WASHER
Whirlpool WFW9300VU03 AUTOMATIC WASHER
Whirlpool WFW9300VU04 AUTOMATIC WASHER
Whirlpool WFW9351YL00 AUTOMATIC WASHER
Whirlpool WFW9351YW00 AUTOMATIC WASHER
Whirlpool WFW9400SB00 AUTOMATIC WASHER
Whirlpool WFW9400SB01 AUTOMATIC WASHER
Whirlpool WFW9400SB02 AUTOMATIC WASHER
Whirlpool WFW9400SBA10 AUTOMATIC WASHER
Whirlpool WFW9400ST00 AUTOMATIC WASHER
Whirlpool WFW9400ST01 AUTOMATIC WASHER
Whirlpool WFW9400ST02 AUTOMATIC WASHER
Whirlpool WFW9400STA10 AUTOMATIC WASHER
Whirlpool WFW9400SU00 AUTOMATIC WASHER
Whirlpool WFW9400SU01 AUTOMATIC WASHER
Whirlpool WFW9400SU02 AUTOMATIC WASHER
Whirlpool WFW9400SW00 AUTOMATIC WASHER
Whirlpool WFW9400SW01 AUTOMATIC WASHER
Whirlpool WFW9400SW02 AUTOMATIC WASHER
Whirlpool WFW9400SW03 AUTOMATIC WASHER
Whirlpool WFW9400SW04 AUTOMATIC WASHER
Whirlpool WFW9400SWA10 AUTOMATIC WASHER
Whirlpool WFW9400SZ00 AUTOMATIC WASHER
Whirlpool WFW9400SZ01 AUTOMATIC WASHER
Whirlpool WFW9400SZ02 AUTOMATIC WASHER
Whirlpool WFW9400SZ03 AUTOMATIC WASHER
Whirlpool WFW9400SZ04 AUTOMATIC WASHER
Whirlpool WFW9400SZA10 AUTOMATIC WASHER
Whirlpool WFW9400VE01 AUTOMATIC WASHER
Whirlpool WFW9400VE02 AUTOMATIC WASHER
Whirlpool WFW9400VE03 AUTOMATIC WASHER
Whirlpool WFW9410XW00 WASHER
Whirlpool WFW9450WL00 AUTOMATIC WASHER
Whirlpool WFW9450WR00 AUTOMATIC WASHER
Whirlpool WFW9450WW00 AUTOMATIC WASHER
Whirlpool WFW9451XW00 AUTOMATIC WASHER
Whirlpool WFW9470WL00 AUTOMATIC WASHER
Whirlpool WFW9470WL01 AUTOMATIC WASHER
Whirlpool WFW9470WR00 AUTOMATIC WASHER
Whirlpool WFW9470WR01 AUTOMATIC WASHER
Whirlpool WFW9470WW00 AUTOMATIC WASHER
Whirlpool WFW9470WW01 AUTOMATIC WASHER
Whirlpool WFW94HEXL0 WASHER
Whirlpool WFW94HEXL1 AUTOMATIC WASHER
Whirlpool WFW94HEXL2 AUTOMATIC WASHER
Whirlpool WFW94HEXR0 WASHER
Whirlpool WFW94HEXR1 AUTOMATIC WASHER
Whirlpool WFW94HEXR2 AUTOMATIC WASHER
Whirlpool WFW94HEXW0 WASHER
Whirlpool WFW94HEXW1 AUTOMATIC WASHER
Whirlpool WFW94HEXW2 AUTOMATIC WASHER
Whirlpool WFW9500TC00 AUTOMATIC WASHER
Whirlpool WFW9500TC01 AUTOMATIC WASHER
Whirlpool WFW9500TC02 AUTOMATIC WASHER
Whirlpool WFW9500TC03 AUTOMATIC WASHER
Whirlpool WFW9500TW00 AUTOMATIC WASHER
Whirlpool WFW9500TW01 AUTOMATIC WASHER
Whirlpool WFW9500TW02 AUTOMATIC WASHER
Whirlpool WFW9500TW03 AUTOMATIC WASHER
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet no high speed spin Itsme2 Washer Repair 0 11-16-2016 06:38 PM
Whirlpool duet TumbleFresh 4.0 wfw9150ww00 won't high speed spin mmcgraw Washer Repair 1 08-17-2014 07:16 AM
Whirlpool Duet won't go into high speed spin Frontloadfan Washer Repair 0 07-08-2014 09:29 AM
Whirlpool washer - won't high speed spin GerryW Washer Repair 3 10-30-2009 07:17 PM
Whirlpool Top load does not high speed spin howdyadothat Washer Repair 11 06-24-2008 12:14 PM
