Discuss
Severe vibration problem
 in
Washer Repair
I have a front loading washer that I am awaiting parts for. In the meantime I've got a top loading
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Severe vibration problem
  #1 (permalink)
Old 01-21-2017, 03:16 AM
Junior Member
SmokeyMoss is on a distinguished road
Default Severe vibration problem
Model Number: WTW5200VQ2   Brand: Whirlpool   Age: 5 - 10 years
I have a front loading washer that I am awaiting parts for. In the meantime I've got a top loading whirlpool WTW5200VQ2 that was purchased in June 2010 that has been in storage for 3years. I brought it in and hooked it up in my laundry room and started a load. It filled and washed perfectly so I went upstairs. A short while later I heard the damndest noise and ran down to the laundry room. This washer was doing a dance like I've never seen and the tub had to have been hitting all 4 sides of the cabinet. I raised the lid to stop it. Upon inspection the load looked like it might be a little to one side so I moved a few articles around and closed the lid again. It started spinning and same thing again. It was banging like crazy. I did this 3 times and never could get it balanced. After the 3rd attempt the spin cycle must have been over because when I lowered the lid it didn't start again and after about 30 seconds it started to fill for the rinse cycle. I was about to walk out of the laundry when I heard water but it was a different sound from the sound of filling I looked down and saw water soaking out in all4 directions out from under the washer. That should give some indication as to how violently the tub was beating around. Something either broke or came loose. By the time I got the cabinet off and exposed everything the water had all run out so I haven't found out what is leaking yet. My first concern is the imbalance problem the springs seem to be in real good shape. The only one that even had any rust on it at all is the long counter balance spring in the back but it seems to have fair tension. I noticed now that the cabinet was off I could tilt the drum assembly far more and thedrum assembly would actually slide on the machine base. I noticed something else. In the parts diagram on this site there is a drawing of the parts for the machine base. I noticed that there are two triangular shaped brackets the lower one is positioned with a corner of the triangle pointed at the 2 back corners of the washer and according to the diagram the upper triangular shaped bracket which is afixed under the tub is positioned the same as if it were to sit right on top of the other triangle one on top of the other. Mine is not sitting that way. My upper bracket is reversed from the lower one where you have Each corner of the upper triangle sticking out on a flat section of the lower triangle. The diagram show some plastic pads that are supposed to help with vibration and these pads are supposed to be in contact with the other bracket but the way mine is sitting with the two triangles opposing each other none of these plastic pads are even touching metal on the other. My washer has never been into before so I don't think that it was installed wrong by any service work done on it prior and surely it didn't come from the factory backwards like that. Plus the machine ran fine for three years before I put it in storage. Please someone tell me what in the hell is going on here? I'm about to go nuts with two washers on the fritz and I sure don't want to go to a coin-operated laundromat!
Related Models
Whirlpool WTW5200VQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ0 AUTOMATIC WASHER
Whirlpool WTW5300SQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ3 AUTOMATIC WASHER
Whirlpool WTW5300VW0 AUTOMATIC WASHER
Whirlpool WTW5300VW1 AUTOMATIC WASHER
Whirlpool WTW5300VW2 AUTOMATIC WASHER
Whirlpool WTW5300VW3 AUTOMATIC WASHER
Whirlpool WTW5310SQ0 AUTOMATIC WASHER
Whirlpool WTW5310VQ0 AUTOMATIC WASHER
Whirlpool WTW5320SQ0 AUTOMATIC WASHER
Whirlpool WTW5321SQ0 AUTOMATIC WASHER
Whirlpool WTW5400TQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ2 AUTOMATIC WASHER
Whirlpool WTW5500ST0 AUTOMATIC WASHER
Whirlpool WTW5500ST2 AUTOMATIC WASHER
Whirlpool WTW5500XL0 AUTOMATIC WASHER
Whirlpool WTW5500XL1 AUTOMATIC WASHER
Whirlpool WTW5500XL2 WASHER
Whirlpool WTW5500XW0 AUTOMATIC WASHER
Whirlpool WTW5500XW1 AUTOMATIC WASHER
Whirlpool WTW5500XW2 WASHER
Whirlpool WTW5505SQ0 AUTOMATIC WASHER
Whirlpool WTW5505SQ1 AUTOMATIC WASHER
Whirlpool WTW5505VQ0 AUTOMATIC WASHER
Whirlpool WTW5505VQ1 AUTOMATIC WASHER
Whirlpool WTW5510VQ0 AUTOMATIC WASHER
Whirlpool WTW5520SQ0 AUTOMATIC WASHER
Whirlpool WTW5521SQ0 AUTOMATIC WASHER
Whirlpool WTW5530SQ0 AUTOMATIC WASHER
Whirlpool WTW5540SQ0 AUTOMATIC WASHER
Whirlpool WTW5540ST0 AUTOMATIC WASHER
Whirlpool WTW5550SQ0 AUTOMATIC WASHER
Whirlpool WTW5550ST0 AUTOMATIC WASHER
Whirlpool WTW5550XW0 AUTOMATIC WASHER
Whirlpool WTW5550XW1 AUTOMATIC WASHER
Whirlpool WTW5550XW2 WASHER
Whirlpool WTW5560SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ2 AUTOMATIC WASHER
Whirlpool WTW5590ST0 AUTOMATIC WASHER
Whirlpool WTW5590ST2 AUTOMATIC WASHER
Whirlpool WTW5590VQ0 AUTOMATIC WASHER
Whirlpool WTW5590VQ1 AUTOMATIC WASHER
Whirlpool WTW5600SQ0 AUTOMATIC WASHER
Whirlpool WTW5600VQ0 AUTOMATIC WASHER
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Severe vibration problem SmokeyMoss Washer Repair 1 01-21-2017 06:40 PM
Vibration and shaking problem Scott Campbell Washer Repair 0 12-06-2015 01:03 PM
Drum severe vibration dmpsqrd Dryer Repair 0 12-06-2013 06:44 PM
Washing Machine Severe Vibration on Spin Cycle uniman Washer Repair 1 05-25-2013 05:32 PM
High Noise and Severe Vibration rjxu2007@gmail.com Washer Repair 1 08-09-2010 11:26 AM
