Discuss
Whirlpool Duet washer FH code
 in
Washer Repair
My hot water was turned off and my son started a load. the machine was flashing HF I turned it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet washer FH code
  #1 (permalink)
Old 01-17-2017, 08:14 PM
Junior Member
farmgirl is on a distinguished road
Default Whirlpool Duet washer FH code
Brand: Whirlpool   Age: More than 10 years
My hot water was turned off and my son started a load. the machine was flashing HF I turned it off and the drain pump kicked on, it will not shut off. I have tried eery button several times and for long periods of time, unplugged it and waited hours several times. I plug it in and the pump kicks in but the door is locked and the control panel lets you do everything but turn it off. The hot water is on and hooked up but still nothing. Any suggestions?
  #2 (permalink)
Old 01-18-2017, 03:46 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
I found this on another page. You didn't post your model number.
"FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water,
the manufacturer has assigned this error or fault code to indicate that there is a problem with the amount of water entering the machine. This error code will be displayed if the machine is trying to fill with water but the flow meter doesn’t sense any flow for 30 seconds. In this case, check the water supply to be sure you have good pressure for both hot and cold water. Then, consider replacing the flow meter. This code can also display if the machine is filling with water, the flow meter measures 10.5 gallons of water into the machine, but the water level pressure switch does not turn off the water inlet valves. If this happens the water inlet valve or the water level pressure switch may be defective. Finally, if all other things check out, the problem might be with the central control unit circuit board (CCU) or the wiring to any of these components."
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Washer F8 Code donald188 Washer Repair 30 07-24-2017 03:31 PM
whirlpool duet wASHER f11 CODE apostoln Dishwasher Repair 1 01-13-2015 08:35 AM
Whirlpool Duet Washer F22 Code Fix RThomas447 Washer Repair 1 01-19-2012 03:58 PM
whirlpool duet washer code F33 trisha1955 Washer Repair 1 12-01-2011 09:12 AM
whirlpool duet washer f20 code mindylfowler Washer Repair 1 09-29-2011 06:14 PM
