Discuss
Whirlpool Duet Sport Washer problems
 in
Washer Repair
I am getting error codes F 33, F 26 and F 24. I have replaced the door lock assembly and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet Sport Washer problems
  #1 (permalink)
Old 01-11-2017, 12:54 PM
Junior Member
bdmbluegrass is on a distinguished road
Default Whirlpool Duet Sport Washer problems
Model Number: WFW8300SW01   Brand: Whirlpool   Age: 5 - 10 years
I am getting error codes F 33, F 26 and F 24. I have replaced the door lock assembly and a bad drain pump assembly, checked connections and wires. I have unplugged overnight and still getting the same codes after replacing the items. It will power on, allow me to choose cycle, hit start button and door locks and then it does nothing. It will always go to add a garment every time and will not unlock door. I have to unplug and plug back in to even get it to respond to anything, even a diagnostics test run. I have checked all component tests and all are good per service manual ohm readings. Any ideas of what to do next?
Related Models
Whirlpool WFW8300SW01 RESIDENTIAL WASHER
Whirlpool WFW8300SW02 AUTOMATIC WASHER
Whirlpool WFW8300SW03 AUTOMATIC WASHER
Whirlpool WFW8300SW04 AUTOMATIC WASHER
Whirlpool WFW8300SW05 AUTOMATIC WASHER
Whirlpool WFW8300SW1 AUTOMATIC WASHER
Whirlpool WFW8400TB00 AUTOMATIC WASHER
Whirlpool WFW8400TB01 AUTOMATIC WASHER
Whirlpool WFW8400TB02 AUTOMATIC WASHER
Whirlpool WFW8400TE00 AUTOMATIC WASHER
Whirlpool WFW8400TE01 AUTOMATIC WASHER
Whirlpool WFW8400TW00 AUTOMATIC WASHER
Whirlpool WFW8400TW01 AUTOMATIC WASHER
Whirlpool WFW8400TW02 AUTOMATIC WASHER
Whirlpool WFW8400TW03 AUTOMATIC WASHER
Whirlpool WFW8410SW0 AUTOMATIC WASHER
Whirlpool WFW8410SW01 AUTOMATIC WASHER
Whirlpool WFW8410SW02 AUTOMATIC WASHER
Whirlpool WFW8410SW03 AUTOMATIC WASHER
Whirlpool WFW8500SR0 AUTOMATIC WASHER
Whirlpool WFW8500SR01 AUTOMATIC WASHER
Whirlpool WFW8500SR02 AUTOMATIC WASHER
Whirlpool WFW8500SR03 AUTOMATIC WASHER
Whirlpool WFW8500SR04 AUTOMATIC WASHER
Whirlpool WFW9050XW00 AUTOMATIC WASHER
Whirlpool WFW9050XW01 AUTOMATIC WASHER
Whirlpool WFW9050XW02 AUTOMATIC WASHER
Whirlpool WFW9050XW03 AUTOMATIC WASHER
Whirlpool WFW9150WW00 AUTOMATIC WASHER
Whirlpool WFW9150WW01 AUTOMATIC WASHER
Whirlpool WFW9150WW02 AUTOMATIC WASHER
Whirlpool WFW9151YW00 WASHER
Whirlpool WFW9200SQ00 AUTOMATIC WASHER
Whirlpool WFW9200SQ01 AUTOMATIC WASHER
Whirlpool WFW9200SQ02 AUTOMATIC WASHER
Whirlpool WFW9200SQ03 AUTOMATIC WASHER
Whirlpool WFW9200SQ04 AUTOMATIC WASHER
Whirlpool WFW9200SQ10 AUTOMATIC WASHER
Whirlpool WFW9200SQA10 AUTOMATIC WASHER
Whirlpool WFW9200SQA11 AUTOMATIC WASHER
Whirlpool WFW9200SQA12 AUTOMATIC WASHER
Whirlpool WFW9250WL00 AUTOMATIC WASHER
Whirlpool WFW9250WL01 AUTOMATIC WASHER
Whirlpool WFW9250WL02 AUTOMATIC WASHER
Whirlpool WFW9250WR00 AUTOMATIC WASHER
Whirlpool WFW9250WR01 AUTOMATIC WASHER
Whirlpool WFW9250WR02 AUTOMATIC WASHER
Whirlpool WFW9250WW00 AUTOMATIC WASHER
Whirlpool WFW9250WW01 AUTOMATIC WASHER
Whirlpool WFW9250WW02 WASHER
Whirlpool WFW9300VU02 AUTOMATIC WASHER
Whirlpool WFW9300VU03 AUTOMATIC WASHER
Whirlpool WFW9300VU04 AUTOMATIC WASHER
Whirlpool WFW9351YL00 AUTOMATIC WASHER
Whirlpool WFW9351YW00 AUTOMATIC WASHER
Whirlpool WFW9400SB00 AUTOMATIC WASHER
Whirlpool WFW9400SB01 AUTOMATIC WASHER
Whirlpool WFW9400SB02 AUTOMATIC WASHER
Whirlpool WFW9400SBA10 AUTOMATIC WASHER
Whirlpool WFW9400ST00 AUTOMATIC WASHER
Whirlpool WFW9400ST01 AUTOMATIC WASHER
Whirlpool WFW9400ST02 AUTOMATIC WASHER
Whirlpool WFW9400STA10 AUTOMATIC WASHER
Whirlpool WFW9400SU00 AUTOMATIC WASHER
Whirlpool WFW9400SU01 AUTOMATIC WASHER
Whirlpool WFW9400SU02 AUTOMATIC WASHER
Whirlpool WFW9400SW00 AUTOMATIC WASHER
Whirlpool WFW9400SW01 AUTOMATIC WASHER
Whirlpool WFW9400SW02 AUTOMATIC WASHER
Whirlpool WFW9400SW03 AUTOMATIC WASHER
Whirlpool WFW9400SW04 AUTOMATIC WASHER
Whirlpool WFW9400SWA10 AUTOMATIC WASHER
Whirlpool WFW9400SZ00 AUTOMATIC WASHER
Whirlpool WFW9400SZ01 AUTOMATIC WASHER
Whirlpool WFW9400SZ02 AUTOMATIC WASHER
Whirlpool WFW9400SZ03 AUTOMATIC WASHER
Whirlpool WFW9400SZ04 AUTOMATIC WASHER
Whirlpool WFW9400SZA10 AUTOMATIC WASHER
Whirlpool WFW9400VE01 AUTOMATIC WASHER
Whirlpool WFW9400VE02 AUTOMATIC WASHER
Whirlpool WFW9400VE03 AUTOMATIC WASHER
Whirlpool WFW9410XW00 WASHER
Whirlpool WFW9450WL00 AUTOMATIC WASHER
Whirlpool WFW9450WR00 AUTOMATIC WASHER
Whirlpool WFW9450WW00 AUTOMATIC WASHER
Whirlpool WFW9451XW00 AUTOMATIC WASHER
Whirlpool WFW9470WL00 AUTOMATIC WASHER
Whirlpool WFW9470WL01 AUTOMATIC WASHER
Whirlpool WFW9470WR00 AUTOMATIC WASHER
Whirlpool WFW9470WR01 AUTOMATIC WASHER
Whirlpool WFW9470WW00 AUTOMATIC WASHER
Whirlpool WFW9470WW01 AUTOMATIC WASHER
Whirlpool WFW94HEXL0 WASHER
Whirlpool WFW94HEXL1 AUTOMATIC WASHER
Whirlpool WFW94HEXL2 AUTOMATIC WASHER
Whirlpool WFW94HEXR0 WASHER
Whirlpool WFW94HEXR1 AUTOMATIC WASHER
Whirlpool WFW94HEXR2 AUTOMATIC WASHER
Whirlpool WFW94HEXW0 WASHER
Whirlpool WFW94HEXW1 AUTOMATIC WASHER
Whirlpool WFW94HEXW2 AUTOMATIC WASHER
Whirlpool WFW9500TC00 AUTOMATIC WASHER
Whirlpool WFW9500TC01 AUTOMATIC WASHER
Whirlpool WFW9500TC02 AUTOMATIC WASHER
Whirlpool WFW9500TC03 AUTOMATIC WASHER
Whirlpool WFW9500TW00 AUTOMATIC WASHER
Whirlpool WFW9500TW01 AUTOMATIC WASHER
Whirlpool WFW9500TW02 AUTOMATIC WASHER
Whirlpool WFW9500TW03 AUTOMATIC WASHER
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
Whirlpool WFW9550WW10 AUTOMATIC WASHER
Whirlpool WFW95HEXL0 WASHER
Whirlpool WFW95HEXL1 AUTOMATIC WASHER
Whirlpool WFW95HEXL2 AUTOMATIC WASHER
  #2 (permalink)
Old 01-20-2017, 06:25 PM
Junior Member
Default
Fixed. I found a solder point on the Motor control board had shorted from moisture and popped the solder away from pin. Could only see it with a jewelers loop. Soldered the one point and put back in and and it runs like a top.
After days of troubleshooting and advice from so called experts, I found, I conquered. Saved myself $600.00 plus.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Sport Washer F-21 bradlawson Washer Repair 1 04-17-2014 04:25 PM
Whirlpool duet sport washer jomarshall Washer Repair 1 09-30-2011 06:37 PM
Whirlpool Duet Sport Washer tonyarayburn Refrigerator & Freezer Repair 3 08-22-2011 06:39 AM
Whirlpool Duet Sport ht washer gottago4itnow Washer Repair 3 01-14-2010 03:47 PM
whirlpool duet sport washer sheryl luker Washer Repair 1 09-03-2009 08:10 PM
