sontours
#1 Posted : Tuesday, January 3, 2017 7:26:05 AM(UTC)
sontours
I recently acquired this set in great shape but the washer did not work. After some diagnosis I determined the control board was bad. Since nobody has this new I found a used one on ********. I installed it and the machine worked perfect for about 4-5 cycles. Then it quit. If it was just a bad board OK, but my concern is that I will get another board, install it and have it burn up again. There is a resistor next to the fuse that overheats if I hold the power button down for a few seconds.
I am wondering if anyone has had to dig further into this machine. Any way to repair the board?
Any help is appreciated.
Thanks,
Phil
