Looking for advice/direction with this repair. Initial symptom included a screech while stopping, then the main drive motor going. Replaced motor with appropriate part, machine spun but still with loud noise and screeching halt. Added a very small amount of grease to the pulley spindles, machine still made noise then began to leak water ( I am assuming the drain motor and/or drain pump have damage). Direction/suggestions? Thank you for your help in advance!
