Discuss
Frigidaire washer spins and stops
 in
Washer Repair
I have a Frigidaire washer whose model # is FWX645RFS0. The washer washes (agitates) fine but it has problem during
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire washer spins and stops
  #1 (permalink)
Old 01-01-2017, 01:59 PM
Junior Member
wmd1942 is on a distinguished road
Default Frigidaire washer spins and stops
Model Number: FWX645RFS0   Brand: Frigidaire   Age: More than 10 years
I have a Frigidaire washer whose model # is FWX645RFS0. The washer washes (agitates) fine but it has problem during spin cycle. When it tries to spin, it will pull in the tension pulley as if the tub is too heavy to spin. After the tub starts to rotate, the spring loaded tension pulley is released and makes the loud noise. While the tub spinning is speeding up, the washer will keep doing this (pulling and releasing pulley) for a few times until tub starts to spin fast. However, the motor will shut down after tub spinning for some time (varying from 20 sec to one min). After that, washer will not work anymore. It looks like the overload protection is activated. If I remove the belt, the motor will run fine.
I'd appreciate it if anyone can help me to identify the problem. Thanks.
Related Models
Frigidaire FWX645RFS0 Frg(v0) / Washer
Frigidaire FWX645RFS1 Frg(v0) / Washer
Frigidaire FWX6968HW0 Frg(v0) / Washer
Frigidaire FWX6970E FRIGIDAIRE WASHER
Frigidaire FWX6970EW0 Frg(v0) / Washer
Frigidaire FWX6970EW1 Frg(v0) / Washer
Frigidaire FWX6970EW2 Frg(v0) / Washer
Frigidaire FWX6970EW3 Frg(v0) / Washer
Frigidaire FWX6970EW4 Frg/washer
Frigidaire FWX6970EW5 Frg(v0) / Washer
Frigidaire FWX6971E FRIGIDAIRE WASHER
Frigidaire FWX6971EW0 Frg(v0) / Washer
Frigidaire FWX6971EW1 Frg(v0) / Washer
Frigidaire FWX6971EW2 Frg(v0) / Washer
Frigidaire FWX6975E FRIGIDAIRE WASHER
Frigidaire FWX6975EW0 Frg(v0) / Washer
Frigidaire FWX6975EW1 Frg(v0) / Washer
Frigidaire FWX6975EW2 Frg(v0) / Washer
Frigidaire FWX833AS0 Washer - Frigidaire
Frigidaire FWX833AS1 Washer - Frigidaire
Frigidaire FWX833AS2 Frigidaire/washer
Frigidaire FWX833AS3 Frigidaire/washer
Frigidaire FWX833MAS0 Frigidaire/washer
Frigidaire FWX833SAQ0 Washer - Frig/gallery
Frigidaire FWX833SAS0 Washer - Frig/gallery
Frigidaire FWXB23RGS0 Frg(v0) / Washer
Frigidaire FWXB45RGS0 Washer - Frig/best Buy
Frigidaire FWXB45RGS1 Washer - Frig/best Buy
Frigidaire FWY833KAS0 Frigidaire/washer
Frigidaire FWY833KCS0 Frigidaire/washer
Frigidaire FXP18B4AW0 REFRIGERATOR
Frigidaire FXP18B4AW1 FRIGIDAIRE/REFRIGERATOR
Hardwick G-433 SURFACE UNIT- ELE
Hardwick G-436 SURFACE UNIT- ELE
Hardwick G-445 SURFACE UNIT- ELE
Jenn-Air G0206B-8 ELECTRIC GRILL OUTDOOR
Jenn-Air G100 SURFACE UNIT- DDRAFT ELE
Jenn-Air G101 SURFACE UNIT- DDRAFT ELE
Jenn-Air G102 SURFACE UNIT- DDRAFT ELE
Jenn-Air G103 SURFACE UNIT- DDRAFT ELE
Admiral G1110PRA RANGE- F/S STD GAS
Admiral G1110PRW RANGE- F/S STD GAS
Frigidaire G12W
Frigidaire G15W
Frigidaire G18W
Whirlpool G20EFSB2313 REFRIGERATOR
Whirlpool G20EFSB23S4 REFRIGERATOR
Whirlpool G20EFSB23S5 REFRIGERATOR
Whirlpool G20EFSB23S6 REFRIGERATOR
Whirlpool G20EFSB23S7 REFRIGERATOR
Whirlpool G20EFSB23S8 REFRIGERATOR
Whirlpool G20EFSB23S9 REFRIGERATOR
Frigidaire G21CL0 Frg(v1) / Gas Range
Frigidaire G21CW0 Frg(v2) / Gas Range
Frigidaire G21CW2 Frg(v1) / Gas Range
Frigidaire G21CW3 Frg(v2) / Gas Range
Frigidaire G21PCL0 Frg(v1) / Gas Range
Frigidaire G21PCL1 Frg(v3) / Gas Range
Frigidaire G21PCL3 Frg(v2) / Gas Range
Frigidaire G21PCL4 Frg(v2) / Gas Range
Frigidaire G21PCL5 Frg(v4) / Gas Range
Frigidaire G21PCW0 Frg(v2) / Gas Range
Frigidaire G21PCW1 Frg(v4) / Gas Range
Frigidaire G21PCW3 Frg(v1) / Gas Range
Frigidaire G21PCW4 Frg(v1) / Gas Range
Frigidaire G21PCW5 Frg(v3) / Gas Range
Frigidaire G22W
Frigidaire G24CL0 Frg(v1) / Free Standing Gas Range
Frigidaire G24CL3 Frg(v2) / Gas Range
Frigidaire G24CL4 Frg(v4) / Gas Range
Frigidaire G24CW0 Frg(v2) / Free Standing Gas Range
Frigidaire G24CW3 Frg(v1) / Gas Range
Frigidaire G24CW4 Frg(v3) / Gas Range
Frigidaire G24PCL0 Frg(v3) / Gas Range
Frigidaire G24PCL1 Frg(v5) / Gas Range
Frigidaire G24PCL3 Frg(v2) / Gas Range
Frigidaire G24PCL4 Frg(v4) / Gas Range
Frigidaire G24PCW0 Frg(v4) / Gas Range
Frigidaire G24PCW1 Frg(v6) / Gas Range
Frigidaire G24PCW3 Frg(v1) / Gas Range
Frigidaire G24PCW4 Frg(v3) / Gas Range
Frigidaire G25BNL0 Frg(v2) / Gas Range
Frigidaire G25BNW0 Frg(v1) / Gas Range
Whirlpool G25EFSB2313 REFRIGERATOR
Whirlpool G25EFSB23S4 REFRIGERATOR
Whirlpool G25EFSB23S5 REFRIGERATOR
Whirlpool G25EFSB23S6 REFRIGERATOR
Whirlpool G25EFSB23S7 REFRIGERATOR
Whirlpool G25EFSB23S8 REFRIGERATOR
Whirlpool G25EFSB23S9 REFRIGERATOR
Whirlpool G2IXEFMWB00 REFRIGERATOR
Whirlpool G2IXEFMWB01 REFRIGERATOR
Whirlpool G2IXEFMWB02 REFRIGERATOR
Whirlpool G2IXEFMWB03 REFRIGERATOR
Whirlpool G2IXEFMWQ00 REFRIGERATOR
Whirlpool G2IXEFMWQ01 REFRIGERATOR
Whirlpool G2IXEFMWQ02 REFRIGERATOR
Whirlpool G2IXEFMWQ03 REFRIGERATOR
Whirlpool G2IXEFMWS00 REFRIGERATOR
Whirlpool G2IXEFMWS01 REFRIGERATOR
Whirlpool G2IXEFMWS02 REFRIGERATOR
Whirlpool G2IXEFMWS03 REFRIGERATOR
Frigidaire G30BCL2 Frg(v2) / Gas Range
Frigidaire G30BCW1 Frg(v1) / Gas Range
Frigidaire G30CL0 Frg(v5) / Gas Range
Frigidaire G30CL2 Frg(v2) / Gas Range
Frigidaire G30CL3 Frg(v4) / Gas Range
Frigidaire G30CW0 Frg(v6) / Gas Range
Frigidaire G30CW2 Frg(v1) / Gas Range
Frigidaire G30CW3 Frg(v3) / Gas Range
Frigidaire G30LPNL1 Frg(v2) / Gas Range
Frigidaire G30LPNL2 Frg(v2) / Gas Range
Frigidaire G30LPNL3 Frg(v2) / Gas Range
Frigidaire G30LPNW1 Frg(v1) / Gas Range
Frigidaire G30LPNW2 Frg(v1) / Gas Range
Frigidaire G30LPNW3 Frg(v1) / Gas Range
Frigidaire G30NL1 Frg(v1) / Gas Range
Frigidaire G30NL2 Frg(v2) / Gas Range
Frigidaire G30NL3 Frg(v3) / Gas Range
Frigidaire G30NL4 Frg(v4) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire spins slowly on rinse then stops after 5 mins vc2 Washer Repair 0 05-14-2013 10:53 AM
Washer Spins slowly stops and restarts eegone Washer Repair 1 03-16-2010 04:36 AM
ge washer WWA8600SBLWW repaired belt now it spins and stops... jeffsji Washer Repair 1 07-30-2009 08:16 PM
GE Profile Washer only spins for 2 seconds, then stops, then smokes kurse Washer Repair 4 04-01-2009 05:53 PM
GE Washer spins then stops Offroader25 Washer Repair 3 10-09-2008 05:23 PM
