Discuss
whirlpool washer not completing spin cycle
 in
Washer Repair
In September of 2016 I purchased a whirlpool wtw5000dw1 washing machine at Lowes on sale for 399.99, yeah I know
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool washer not completing spin cycle
  #1 (permalink)
Old 01-01-2017, 09:39 AM
Junior Member
jcmiller is on a distinguished road
Default whirlpool washer not completing spin cycle
Model Number: wtw5000dw1   Brand: Whirlpool   Age: Less than 1 year
In September of 2016 I purchased a whirlpool wtw5000dw1 washing machine at Lowes on sale for 399.99, yeah I know now, my mistake (if I knew then what I know now, I would have rebuilt my 15 year old washing machine completely). Anyway, my problem was this washing machine would not complete the spin cycle, it would attempt it, drain the machine and spin very slowly throwing up the code for a slow drain problem. The machine would complete a drain and spin cycle if I shut it down and set it to this cycle just fine. After nothing but a hassle and a few choice words for Whirlpool customer service about the time table involved, I picked up the front of the machine pulled out the service manual and went to work along with my laptop at my side for references to online forums for additional help. Most everything I found online was replacing expensive parts in a failed attempt to solve the problem essentially throwing money at the problem and hoping it fixed it. I found one piece of advice, I for the life of me can not remember where, about soap suds messing up the water level sensor, and how to correct the problem. So far so good on my machine, so here is a quick very low cost hopefully a solution to your problem also.
1. take your control panel off to access the electronic control module,(or what ever you want to call it)
2. connected to this control module is a clear plastic tube. (this connects to the water level sensor), remove it from the control module.
3. get a turkey baster or something equivalent that you use to dump vinegar through this tube.
4. use what ever it was that you found, and run pure white vinegar through this tube to clean it out.
What this does is cleans out the water level sensor which possibly has soap suds or dirt in it clogging it up.
This is what I have tried, and it has worked. The washing machine is up to this point and time been working fine again.
One more thing I have found in my searches for a fix to this problem, be careful of the detergent you use, someone mentioned this in another forum and recommended Molly`s soap powder. Have not tried this, but hey if it helps the longevity of this machine I am up for giving it a try.
I hope this helps someone out who may be experiencing the same problems with the spin cycle problem on these terrible machines. Good luck...
Related Models
Whirlpool WTW5100SQ0 AUTOMATIC WASHER
Whirlpool WTW5100VQ0 AUTOMATIC WASHER
Whirlpool WTW5100VQ1 AUTOMATIC WASHER
Whirlpool WTW5100VQ2 AUTOMATIC WASHER
Whirlpool WTW5200SQ0 AUTOMATIC WASHER
Whirlpool WTW5200VQ0 AUTOMATIC WASHER
Whirlpool WTW5200VQ1 AUTOMATIC WASHER
Whirlpool WTW5200VQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ0 AUTOMATIC WASHER
Whirlpool WTW5300SQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ3 AUTOMATIC WASHER
Whirlpool WTW5300VW0 AUTOMATIC WASHER
Whirlpool WTW5300VW1 AUTOMATIC WASHER
Whirlpool WTW5300VW2 AUTOMATIC WASHER
Whirlpool WTW5300VW3 AUTOMATIC WASHER
Whirlpool WTW5310SQ0 AUTOMATIC WASHER
Whirlpool WTW5310VQ0 AUTOMATIC WASHER
Whirlpool WTW5320SQ0 AUTOMATIC WASHER
Whirlpool WTW5321SQ0 AUTOMATIC WASHER
Whirlpool WTW5400TQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ2 AUTOMATIC WASHER
Whirlpool WTW5500ST0 AUTOMATIC WASHER
Whirlpool WTW5500ST2 AUTOMATIC WASHER
Whirlpool WTW5500XL0 AUTOMATIC WASHER
Whirlpool WTW5500XL1 AUTOMATIC WASHER
Whirlpool WTW5500XL2 WASHER
Whirlpool WTW5500XW0 AUTOMATIC WASHER
Whirlpool WTW5500XW1 AUTOMATIC WASHER
Whirlpool WTW5500XW2 WASHER
Whirlpool WTW5505SQ0 AUTOMATIC WASHER
Whirlpool WTW5505SQ1 AUTOMATIC WASHER
Whirlpool WTW5505VQ0 AUTOMATIC WASHER
Whirlpool WTW5505VQ1 AUTOMATIC WASHER
Whirlpool WTW5510VQ0 AUTOMATIC WASHER
Whirlpool WTW5520SQ0 AUTOMATIC WASHER
Whirlpool WTW5521SQ0 AUTOMATIC WASHER
Whirlpool WTW5530SQ0 AUTOMATIC WASHER
Whirlpool WTW5540SQ0 AUTOMATIC WASHER
Whirlpool WTW5540ST0 AUTOMATIC WASHER
Whirlpool WTW5550SQ0 AUTOMATIC WASHER
Whirlpool WTW5550ST0 AUTOMATIC WASHER
Whirlpool WTW5550XW0 AUTOMATIC WASHER
Whirlpool WTW5550XW1 AUTOMATIC WASHER
Whirlpool WTW5550XW2 WASHER
Whirlpool WTW5560SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ2 AUTOMATIC WASHER
Whirlpool WTW5590ST0 AUTOMATIC WASHER
Whirlpool WTW5590ST2 AUTOMATIC WASHER
Whirlpool WTW5590VQ0 AUTOMATIC WASHER
Whirlpool WTW5590VQ1 AUTOMATIC WASHER
Whirlpool WTW5600SQ0 AUTOMATIC WASHER
Whirlpool WTW5600VQ0 AUTOMATIC WASHER
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
  #2 (permalink)
Old 01-02-2017, 09:30 AM
Junior Member
Default update on this problem
This washing machine worked fine for 8 loads under normal and quick wash settings. On load number 9 we washed some blankets and set the machine on bulky items/sheets, problem returned. There is no way you can convince me this is a problem mechanical or electrical. I am going to clean out the water level hose once again, on a hunch it is the detergent I am using creating the problem and blocking this hose with suds. I will reply back to this thread with a response as to how it worked, just be patient and stay tuned in.
BTW this hose only goes to the tub, the sensor is part of the electronic control.
  #3 (permalink)
Old 01-02-2017, 10:35 AM
Junior Member
Default just checking in after the water level hose cleaning
In my previous post, i posted the problem returned. I removed the control panel and cleaned the water level hose once again, ran another load of laundry, and presto, the machine worked flawlessly. Now I can not say this is the root of anybody else`s problems, but it is definitely where I would start in an effort to correct this spin cycle problem, as the cost is zero if you have the white vinegar on hand. Cleaning this hose only takes about 15 to 20 minutes tops the first time around, this last time I cleaned it, it took 5 minutes start to finish.
I am certain that my problem lies with this water level hose, and a change of laundry detergents.
Hopefully this helps others in solving their problem of incomplete spin cycles.
  #4 (permalink)
Old 01-08-2017, 04:09 PM
Junior Member
Default finally got my answer as to what is going on with this thing
In my three previous post I clean the tube for the water level sensor. While cleaning this I also unplugged the machine resetting the control board and removing all codes, which is why the thing worked fine afterwards. The problem persists, and now will not complete the spin cycle in any setting without giving a fault. It will drain and spin my clothes dry, and abruptly thereafter will engage the drain pump til it gives a fault code. If I unplug it, it resets the control board and will work fine for a load of laundry. After putting this machine in manual diagnostic mode, I have figured out the control board needs replaced, the water level sensor built into the board is failing or has failed. Seems to be quite the common problem with these whirlpool Cabrio washing machines.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Cabrio Washer not completing spin cycle alehde Washer Repair 14 01-01-2017 11:32 AM
Washer not completing spin cycle Rlharperpi Washer Repair 0 05-28-2013 09:21 PM
problem completing spin cycle allen9258 Washer Repair 5 11-06-2012 05:24 PM
washer not completing cycle chrisgroves123 Washer Repair 1 06-03-2011 05:45 PM
whirlpool not completing cycle JOSH MANN Washer Repair 3 03-18-2008 02:00 PM
