Discuss
Maytag Bravos (VMW) - Intermittent spin & lid lock issues?
 in
Washer Repair
Hello! I'm troubleshooting a finicky Maytag Bravos HE top-loading washer, and seem to be at a standstill as I'm receiving
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Bravos (VMW) - Intermittent spin & lid lock issues?
  #1 (permalink)
Old 12-31-2016, 02:16 PM
Junior Member
Low Efficiency is on a distinguished road
Question Maytag Bravos (VMW) - Intermittent spin & lid lock issues?
Model Number: MVWX550XW1   Brand: Maytag   Age: More than 10 years
Hello!
I'm troubleshooting a finicky Maytag Bravos HE top-loading washer, and seem to be at a standstill as I'm receiving intermittent symptoms, and progressing through the service manual steps is proving inconclusive... The error codes are F7 E1 (basket speed sensor fault), and F7 E7 (motor unable to reach target RPM).
Here are the symptoms:
Over the past few months, we've had a few cases where the machine gets stuck with a flashing lid lock, even when "off", and won't do anything until it times out several minutes later. It has also had a few cases of disappointing washing performance, although I'm not sure if that is a failure symptom or a characteristic of the HE design...
Today it had a new, more pressing issue - we were washing a small load of some seasonal clothes that had been packed for a while, so a few of the items were t-shirts and the like that were folded. The washer ran its cycles and competed, and when my wife opened the lid, the lower items were soggy wet, a few items on top still had dry parts (had never touched water), and the wet t-shirts were still folded. So although it took the normal amount of time, it might not have agitated or spun...
Following through the steps in the service manual, it would seem like everything checks out after doing the functional checks. I can lock/unlock the lid repeatedly without issue, the fill valves check out, etc, etc. The manual tachometer test is successful as well. The machine agitates, and it can spin as well without any unusual sounds or noises. The tub spins freely by hand, and selecting spin & drain spins and drains as expected.
What happens though - I ran the automated test set, and the first time through, it seemed like it stopped the spin test very quickly - only running the motor for a half-second or less, then skipped right past the 30-45-second spin down and went straight to the "lid will unlock" step where it stalled for several minutes with the flashing lid lock light, for long after the tub had come to a stop.
However, what is strange is that I cleared the codes and re-ran the automated test set, and this time when it got to the spin stage, it spun up to full speed and for the expected time, but then immediately skipped to the "Done" stage, played the chime, and unlatched the lid... all while the tub was still spinning at nearly full speed. After this second test, there were NO fault codes stored.
It *seems* like an intermittent speed reading... but like I said, that function checks out when doing the manual tests.
Before I fire the parts cannon at this, does anyone recognize this behavior as a common intermittent failure mode?
Thanks in advance.
Related Models
Maytag MVWX600XW0 AUTOMATIC WASHER
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
Whirlpool MW3200XW0 Microwave
Whirlpool MW3500XM0 Microwaves*
Whirlpool MW3500XM1 Microwaves*
Whirlpool MW3500XP1 Microwaves*
Whirlpool MW3500XP2 Microwaves*
Whirlpool MW3500XP3 Microwaves*
Whirlpool MW3500XS0 Microwaves*
Whirlpool MW3500XW0 Microwaves*
Whirlpool MW3520XP1 Microwaves*
Whirlpool MW3520XP2 Microwaves*
Whirlpool MW3520XP3 Microwaves*
Whirlpool MW352EXP1 Microwaves*
Whirlpool MW3600XS0 Microwaves*
Whirlpool MW3600XW0 Microwaves*
Whirlpool MW3600XW1 Microwaves*
Whirlpool MW3601XS0 Microwaves*
Whirlpool MW3601XW0 Microwaves*
Whirlpool MW3601XW1 Microwaves*
Amana MW41 MWAVE- CNTRTP / STAND ALONE
Amana MW42 MWAVE- CNTRTP / STAND ALONE
Amana MW43 MWAVE- CNTRTP / STAND ALONE
Amana MW500.000 COMMERCIAL MICROWAVES
 MW5380W MWAVE- CNTRTP / STAND ALONE
Roper MW557 Microwave
Roper MW5571 Microwaves
 MW5592W MWAVE- CNTRTP / STAND ALONE
 MW5592W/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW56 MWAVE- CNTRTP / STAND ALONE
Amana MW57 MWAVE- CNTRTP / STAND ALONE
Amana MW58 MWAVE- CNTRTP / STAND ALONE
Amana MW600.000 COMMERCIAL MICROWAVES
 MW640BA MWAVE- CNTRTP / STAND ALONE
 MW640WA MWAVE- CNTRTP / STAND ALONE
Amana MW700.000 COMMERCIAL MICROWAVES
Amana MW72 MWAVE- CNTRTP / STAND ALONE
 MW730BB MWAVE- CNTRTP / STAND ALONE
 MW735WB MWAVE- CNTRTP / STAND ALONE
 MW735WB/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW7400XW0 Microwaves*
Whirlpool MW7500XW0 Microwaves*
 MW7695GS MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8100XL0 MICROWAVE
Whirlpool MW8100XL1 MICROWAVE
Whirlpool MW8100XL2 MICROWAVE
Whirlpool MW8100XP0 MICROWAVE
Whirlpool MW8100XR0 MICROWAVE
Whirlpool MW8200XL0 Microwaves*
Whirlpool MW8200XL1 Microwaves*
Whirlpool MW8200XL2 Microwaves*
Whirlpool MW8200XP0 Microwaves*
Whirlpool MW8200XR0 Microwaves*
Whirlpool MW8300XL0 Microwaves*
Whirlpool MW8300XL2 Microwaves*
Whirlpool MW8300XP0 Microwaves*
 MW830BA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW830EXP0 Microwaves*
 MW830WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8400XL0 Microwaves*
Whirlpool MW8400XL2 Microwaves*
Whirlpool MW8400XR0 Microwaves*
Whirlpool MW8400XS0 Microwaves*
Whirlpool MW8400XS1 Microwaves*
Whirlpool MW8400XS2 Microwaves*
Whirlpool MW8400XW0 Microwaves*
 MW840BC MWAVE- CNTRTP / STAND ALONE
  #2 (permalink)
Old 06-11-2017, 11:16 AM
Junior Member
samboski is on a distinguished road
Default
did you ever figure this out?
I've had 2 broken wires on my Bravos washer - the intermittent nature of your issue makes it sound like mine. I bet there is a wire partially broken.
Maytag Bravos actuator replaced but worked for less than a week
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
mdb8600aww Maytag quiet series 300 flashing L lock issues? markm75 Dishwasher Repair 0 03-16-2016 05:16 PM
Maytag Bravos X Won't Spin - Shifter Bad?? crosivach Washer Repair 0 07-09-2014 07:33 PM
Maytag Bravos Lid lock flashing bsktlinda Washer Repair 0 03-29-2014 01:18 PM
Maytag Bravos Lid Won't Lock tvaughn33 Washer Repair 9 12-11-2012 03:48 PM
Maytag Bravos code F50 - won't spin Bill-W Washer Repair 7 07-18-2012 05:12 PM
