Discuss
Kenmore 600 series motor/agitation issue.
 in
Washer Repair
Good Morning all, My Kenmore 600 series washer fills to the proper water level, but when it gets to the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 600 series motor/agitation issue.
  #1 (permalink)
Old 12-27-2016, 08:25 AM
Junior Member
Wirednuke83 is on a distinguished road
Default Kenmore 600 series motor/agitation issue.
Model Number: 27612600   Brand: Kenmore   Age: More than 10 years
Good Morning all,
My Kenmore 600 series washer fills to the proper water level, but when it gets to the point where it should start agitating the motor hums and nothing happens. I was able to turn the timer directly to the spin/drain cycle and the tub began to spin slowly (seemed slower than usual) and the water drained out. It also smelled like hot/burning insulation/plastic.
I removed the pump and verified that it's free and clear, and I attempted to check the motor winding resistance but I don't have a reference value to compare it against. I know it should be low, and I also don't know which leads are which.
I have a feeling it's either the motor or the transmission, but I would appreciate any guidance on moving forward to figuring out which one it is.
Thanks,
Phil
Related Models
Roper 2763*0A Ranges, Electric*
Roper 2763W0A Ranges, Electric*
Roper 2765*0A Ranges, Electric*
Roper 2765W0A Ranges, Electric*
Jenn-Air 2770ELD WALLOVEN- STD ELE
Jenn-Air 2775ELD WALLOVEN- STD ELE
Hoover 2800
Frigidaire 2803 GAS RANGE
Frigidaire 2803-80B GAS RANGE
Frigidaire 28044 FRIGIDAIRE GAS RANGE
Frigidaire 280440C GAS RANGE
Frigidaire 280447C GAS RANGE
Frigidaire 2809A GAS RANGE
Frigidaire 2811 GAS RANGE
Frigidaire 2812A GAS RANGE
Frigidaire 2813-80B GAS RANGE
Frigidaire 2813A GAS RANGE
Frigidaire 2819A GAS RANGE
Frigidaire 2820A GAS RANGE
Frigidaire 282240A GAS RANGE
Frigidaire 282240B GAS RANGE
Frigidaire 282240C GAS RANGE
Frigidaire 282247B GAS RANGE
Frigidaire 282247C GAS RANGE
Frigidaire 2822A GAS RANGE
Frigidaire 2823 GAS RANGE
Frigidaire 2823-80B GAS RANGE
Frigidaire 2828A GAS RANGE
Frigidaire 2829A GAS RANGE
Hoover 2830
Frigidaire 2833 GAS RANGE
Frigidaire 2833-80B GAS RANGE
Frigidaire 2834-80A GAS RANGE
Frigidaire 2834-80B FRIGIDAIRE GAS RANGE
Frigidaire 2834-87B FRIGIDAIRE GAS RANGE
Frigidaire 283440A GAS RANGE
Frigidaire 283440B GAS RANGE
Frigidaire 283440C FRIGIDAIRE GAS RANGE
Frigidaire 283440D GAS RANGE
Frigidaire 283447B GAS RANGE
Frigidaire 283447C FRIGIDAIRE GAS RANGE
Frigidaire 283447D GAS RANGE
Frigidaire 283460B GAS RANGE
Frigidaire 283460C GAS RANGE
Frigidaire 283467B GAS RANGE
Frigidaire 283467C GAS RANGE
Hoover 2836
Frigidaire 28364 GAS RANGE
Frigidaire 2841A GAS RANGE
Frigidaire 284260A GAS RANGE
Frigidaire 284267A GAS RANGE
Frigidaire 2843-80A GAS RANGE
Frigidaire 2843-80B GAS RANGE
Frigidaire 2843-80C GAS RANGE
Roper 2843W0A Ranges, Electric*
Frigidaire 284440A GAS RANGE
Frigidaire 284440B GAS RANGE
Frigidaire 284447A GAS RANGE
Frigidaire 284447B GAS RANGE
Frigidaire 2851A GAS RANGE
Frigidaire 2853 GAS RANGE
Frigidaire 28564 FRIGIDAIRE GAS RANGE
Frigidaire 285640A FRIGIDAIRE GAS RANGE
Frigidaire 285640B GAS RANGE
Frigidaire 285640D GAS RANGE
Frigidaire 285640E GAS RANGE
Frigidaire 285647A FRIGIDAIRE GAS RANGE
Frigidaire 285647B GAS RANGE
Frigidaire 285647D GAS RANGE
Frigidaire 285647E GAS RANGE
Frigidaire 285660A GAS RANGE
Frigidaire 285667A GAS RANGE
Frigidaire 28584 GAS RANGE
Frigidaire 285840A GAS RANGE
Frigidaire 285840B GAS RANGE
Frigidaire 285840C GAS RANGE
Frigidaire 285840D GAS RANGE
Frigidaire 285847A GAS RANGE
Frigidaire 285847B GAS RANGE
Frigidaire 285847C GAS RANGE
Frigidaire 285847D GAS RANGE
Frigidaire 28586 FRIGIDAIRE GAS RANGE
Frigidaire 285860A GAS RANGE
Frigidaire 285860B FRIGIDAIRE GAS RANGE
Frigidaire 285860C FRIGIDAIRE GAS RANGE
Frigidaire 285867A GAS RANGE
Frigidaire 28594 FRIGIDAIRE GAS RANGE
Frigidaire 285940A FRIGIDAIRE GAS RANGE
Frigidaire 285940B GAS RANGE
Frigidaire 285941A FRIGIDAIRE GAS RANGE
Frigidaire 285947A FRIGIDAIRE GAS RANGE
Frigidaire 285947B GAS RANGE
Frigidaire 2859A GAS RANGE
Frigidaire 2861A GAS RANGE
Frigidaire 2864 GAS RANGE
Frigidaire 2864-80B GAS RANGE
Frigidaire 2869A GAS RANGE
Frigidaire 2871A GAS RANGE
Roper 2872*0A Ranges, Electric*
Frigidaire 2872A GAS RANGE
Roper 2872W0A Ranges, Electric*
Frigidaire 2873 GAS RANGE
Frigidaire 2873B GAS RANGE
Frigidaire 2879A GAS RANGE
Frigidaire 2881 GAS RANGE
Frigidaire 2883 GAS RANGE
Roper 2883*10 Ranges, Electric*
Frigidaire 2883-80A GAS RANGE
Frigidaire 2883-81A GAS RANGE
Frigidaire 2883-81B GAS RANGE
Roper 2883W10 Ranges, Electric*
Frigidaire 2889A GAS RANGE
Frigidaire 2891 GAS RANGE
Frigidaire 2893 GAS RANGE
Roper 2893*0A Ranges, Electric*
Frigidaire 2893-80B GAS RANGE
Roper 2893W0A Ranges, Electric*
Frigidaire 2899A GAS RANGE
Magic Chef 28FA-6CXWV8 RANGE- S/C MWAVE ELE
Magic Chef 28FA-6CXWV8-94 RANGE- S/C MWAVE ELE
  #2 (permalink)
Old 12-27-2016, 09:52 AM
Junior Member
Default
Well, after tinkering with it some more I realized the humming isn't coming from the motor at all. I bypassed the lid switch and energized it with the cover off and realized it's the solenoid fill valves that are humming.
I did some reading on how the spin/agitation cycles work, and I took the pump off and rotated the motor shaft counter clockwise and it moves freely and I can see the agitator doing its job inside the tub. I don't think it's a problem with the gearcase.
I found the motor resistance values and all of my readings were within 1 ohm of the range given.
I'm starting to think it's a control problem related to the timer. Is there a way to test this to make sure? This part is nearly 1/4 of the value of the washer brand new. I'd like to make sure before I pick one up.
One other thing to add, I used an inductive voltage wand and waved it near the motor. It's not getting any AC power when it's in the agitation cycle.
Thanks for your help!
Phil
  #3 (permalink)
Old 12-27-2016, 01:52 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Quote:
Originally Posted by Wirednuke83 View Post
Well, after tinkering with it some more I realized the humming isn't coming from the motor at all. I bypassed the lid switch and energized it with the cover off and realized it's the solenoid fill valves that are humming. Phil
With the water shut off and the timer at the beginning of a cycle. The water valves are going to hum. the water level switch is waiting until the tub is full. Then if the lid switch is closed, the washer can agitate.
The burning smell was probably the clutch overheating from trying to spin with a full load of water. That's a lot of weight and resistance.
It could be the motor or the timer.
BTW your model number won't come up. Please check it. It might have a 110. in front.
  #4 (permalink)
Old 12-27-2016, 01:54 PM
Junior Member
Default
Yep sorry it should have been 110 first. I went ahead and ordered a timer, we'll see what happens.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore 80 series agitation problem ccollinswestdyke Washer Repair 3 11-11-2014 02:58 PM
Issue reassembling a Kenmore 90 Series timbuchinger Washer Repair 2 08-09-2013 01:27 PM
Kenmore Series 90 - Agitation problem jimkNJ Washer Repair 12 03-11-2013 10:22 AM
Kenmore Series 90 Plus 110.28942890 brake issue?? les.warden Washer Repair 12 01-06-2009 05:30 AM
Kenmore 90 Series - No agitation jastek Washer Repair 3 02-20-2008 02:54 PM
