I have checked all the recommended trouble shooting issued for the OE Code on the washer. The pump filter is clean, the water outlet hose is clear, I have checked the water pressure hose and is not clogged. I replaced the pressure switch and it has not fixed the problem.
I have noticed that sometimes I feel that the washer is adding too much water into the tub. Could it be the cold water inlet valve malfunctioning? Any suggestions would be very helpful...
If it is the water inlet valve, does that explain why the detergent tray has water in it after the wash cycle is over?
