I have seen some posts regarding this issue with different solutions so want to see with my specific model what I should order. I have this top loading washer. The water is running during the initial fill of the machine. The water is also running during the spin cycle which is leaving the clothes very wet. I have had this happen over the past few months but after a couple of loads it reverts back to the appropriate cycle. It isn't reverting back this time so I'm assuming there needs to be a repair. I have read about needing a timer or a fill valve but not sure if I need both, either or something else. Any suggestions would be greatly appreciated. Thanks, Carl
